72378
72378
    MAKEBLOCK(创客工场)
    COPPER WASHER 4*10*1MM 10PC
72378 数据手册
      Copper Washer 4*10*1mm(10-Pack) SKU: 72378 Weight: 10.00 Gram  Description: Makeblock Copper Washer (4* 10 * 1mm) has an inner diameter of 4mm, outer diameter of 10mm and a thickness of 1mm. Copper washer is brass-material-made and has features of high precision, smoothness, good wear resistance and rust resistance. It can be used in all DIY projects. In Makeblock Plastic Timing Pulley 62T, Plastic Timing Pulley 90T, Plastic Timing Pulley 62T without Steps, and Plastic Timing Pulley 90T without Steps, Makeblock Copper Washer can be used as a high-precision moving part to ensure a stable motion of the above items. Also, it can be used together with the flange copper sleeve (4 * 8 * 3mm) Part List: 10 x Copper Washer 4*10*1mm Features:      Perfect for adding to Timing Pulley and Shaft D4mm; Ensure a stable motion of the moving parts and reach a requirement of high precision; Made of brass; Diameters: 4mm (inside), 10mm (outside); Sold in pack of 10. Size Chart (mm):        https://store.makeblock.com/copper‐washer‐4‐10‐1mm‐10‐pack/2‐26‐19
72378 价格&库存
很抱歉,暂时无法提供与“72378”相匹配的价格&库存,您可以联系我们找货
