80047
80047
    MAKEBLOCK(创客工场)
    GEARMOTOR 16 RPM 9V
80047 数据手册
       DC Motor-25 9V/16RPM SKU: 80047 Weight: 110.00 Gram What is DC Motor? DC motor is the most commonly used motor on Makeblock platform. It is driven by direct current and is the ideal option to get things moving in all kinds of projects. How to Connect DC motor? By adding DC Motor-25 Bracket, this DC motor can easily connect with other Makeblock structural parts. It can also be connected to the M1, M2 interface of Makeblock Me Orionmainboard directly or connected to Me Dual DC Motor Driver. Building Examples:   Size Chart (mm): Specifications Voltage Ambient Temperature 9.0V(DC) 0 ~+50 Ambient Relative 60%±5% Gross Weight 110g (3.88oz) Package Content (Qty. x Part Name) 1 x PH2.0-2P to Stripped-End Cable - 35cm 1 x DC Motor-25 9V Comparison Chart No Load  Model Load  SKU  Gear Ratio Stall Torque Stall Current Speed  Current Torque  Speed  Current 700RPM 80032  1:10  1.5kg.cm  ≤2.7A  700±10% rpm ≤150mA 0.3kg.cm  580±10rpm ≤600mA 325RPM 80035  1:20  4.5±kg.cm  ≤2.7A  325±10% rpm ≤150mA 1.0kg.cm  280±10rpm ≤600mA 185RPM 80038  1:45  5.8 min  /  185±10% rpm ≤220mA 1.5kg.cm  150±10rpm ≤1.1A  86RPM  80041  1:75  11kg.cm  ≤2.7A  86±10% rpm ≤150mA 3.5kg.cm  75±10rpm ≤550mA 30RPM  80044  1:217  /  ≤2.7A  30±10% rpm ≤150mA 8.0kg.cm  26±10rpm ≤500mA 16RPM  80047  1:217  14.0 kg.cm  ≤0.7A  16±10% rpm ≤100mA 14.0 kg.cm  12±10rpm ≤250mA                         https://store.makeblock.com/index.php?route=product/product&product_id=6708/2‐8‐19
80047 价格&库存
很抱歉,暂时无法提供与“80047”相匹配的价格&库存,您可以联系我们找货
