80087
80087
    MAKEBLOCK(创客工场)
    GEARMOTOR 185 RPM 9V
80087 数据手册
  Optical Encoder Motor-25 9V/185RPM SKU: 80087 Weight: 108.00 Gram What Is Optical Encoder Motor-25 9V/185RPM? In contrast to the DC motor, a photoelectric encoder is added into the encoder motor for detecting speed which is fed back to the signal input terminal for PID control to implement servo control for the motor. Features ? Control the speed and displacement for the motor precisely; ? Users can customize their own PID parameter by self-contained software; ? It provides overload protection. Note Before using, please make sure there is enough distance between the white sensor and the black coding disk as below picture for the white sensor may be damaged by the rotating part. Specifications SKU 80087 Rated voltage 9.0V (DC) Temperature range -20 ~+60 Humidity range 0%-90% No-load current ≦ 200 mA No-load speed 185±10% rpm Rated load 0.9 Kgf.cm Rated current ≦ 550mA Rated speed 135±10% rpm Starting torque 4.5kgf.cm Locked-rotor current ≥ 2.0 A Parts List 1 x Optical Encoder Motor-25 9V/185RPM 1 x Encoder Motor Wire Package Dimension 150 x 110 x 30mm (5.9 x 4.3 x 1.2inch) Net Weight 105g (3.7oz) Gross Weight 108g (3.8oz)                                                       https://store.makeblock.com/optical‐encoder‐motor‐25‐9v‐185rpm/2‐26‐19
80087 价格&库存
很抱歉,暂时无法提供与“80087”相匹配的价格&库存,您可以联系我们找货
