81042
81042
    MAKEBLOCK(创客工场)
    42BYG STEPPER MOTOR
81042 数据手册
    42BYG Stepper Motor SKU:81042 Weight:290.00 Gram      Specifications: PHASE : 2PHASE STEP ANGLE : 1.8+-5%°/STEP RATED VOLTAGE : 12V CURRENT : 1.7A/PHASE RESISRANCE : 1.5+-10%/PHASE INDUCRANCE : 2.8+-20%mH/PHASE HOLDING TORQUE : 40N.cm Min DETENT TORQUE : 2.2N.cm Max INSULATION CLASS : B LEAD STYLE : AWG26 UL1007 ROTOR TORQUE : 54G.cm2 Size Charts: Demo: The Stepper Motor Braket is not included. Connection Type May you are confusing about which color cable on the stepper motor should be connected to which port on the driver (A+,A-, B+,B-), Here is a guide of it 1. Ourstepper motorhas two phase. So it doesn't matter you change the connection order between phase A and phase B. Which I mean Black and Green could be connected to A orB, Red and Blue could be connected to B or A. And yes, it would change the motor direction. 2, And, A+:Black A+:Green A-:Green or A-: Black Both of the connection type are OK. 3, There is only one rule you need to follow, which is you can't mix them together. For example, this kind of connection type is wrong, it would make damage to the motor. A+:Red A-: Black B+:Blue B-:Green        http://store.makeblock.com/42byg‐stepper‐motor 11‐17‐17
81042 价格&库存
很抱歉,暂时无法提供与“81042”相匹配的价格&库存,您可以联系我们找货
