81062
81062
    MAKEBLOCK(创客工场)
    42BYG THROUGH-TYPE LEAD SCREW ST
81062 数据手册
        42BYG Through-type Lead Screw Stepper Motor SKU: 81062 Weight: 380.00 Gram Description: Makeblock 42BYG Through-type Lead Screw Stepper Motor is a special linear stepper motor equipped with a 312mm long T8 lead screw. The motion of the motor will be along a straight line when the T8 lead screw is meshing with the screw thread inside the motor. When the lead screw is fixed, the motor will achieve a linear motion which will simplify the XY style motion structure. When the motor is fixed, the lead screw will start a linear motion, for instance, a pull-out structure created by the lead screw working with a cylinder. 42BYG Through-type Lead Screw Stepper Motor is widely used in all projects that require a high-precision motion. Features:   High-precision linear motion; Simple structure and multi-function; Specification:        Phase Number: 2; Wire Number: 4; Screw Lead: 2mm; Step Angle: 1.8°; Rated Current: 1.5A; Rotor Rotational Inertia: 57g.cm?; Insulation Class: B. Size Chart (mm) : Demo: Part List: 1 x 42BYG Through-type Lead Screw Stepper Motor 1 x Lead Screw T8*312mm                                   https://store.makeblock.com/42byg‐through‐type‐lead‐screw‐stepper‐motor/2‐26‐19
81062 价格&库存
很抱歉,暂时无法提供与“81062”相匹配的价格&库存,您可以联系我们找货
