81335
81335
    MAKEBLOCK(创客工场)
    GEARMOTOR 223 RPM 12V
81335 数据手册
    36mm Encoder DC Motor SKU: 81335 Weight: 450.00 Gram What Is 36mm Encoder DC Motor ? 36mm Encoder DC Motor is designed to drive all kinds of transmission devices with precise control over the speed and movement. It can be connected with Me High-Power Encoder Motor Driver by using the 6P motor cable. You can control the diver through programming on the computer or connect it with Makeblock Orion mainboard via RJ25 cable. Features of the Encoder Motor ? Control the speed and the movement of the motor precisely; ? Real-time speed and position feedback; ? Comes with overload protection; ? Easy wiring with RJ25 interface; ? Can be connected with encoder motor driver easily by using the 6P encoder motor cable. Demo: Size Charts       Specifications of the 36mm Encoder DC Motor Rated Voltage 12V No Load Current (A) ≤0.650 NO Load Speed (RPM) 223±10% Rated Load Torque (kgf.cm) 7 Rated Current (A) ≤2.500 Rated Load Speed (RPM) 178±10%     Product Information SKU 81335 Product Name 36mm Encoder DC Motor Pack Total Weight 450 g Package Content (Quantity x Part Name)   1 x 36mm Encoder DC Motor 1 x 2.54mm 6P Encoder Motor Cable – 300mm 1 x M4*4*10-Key        https://store.makeblock.com/36mm‐encoder‐dc‐motor/2‐26‐19
81335 价格&库存
很抱歉,暂时无法提供与“81335”相匹配的价格&库存,您可以联系我们找货
