83450
83450
    MAKEBLOCK(创客工场)
    PLASTIC GEAR 8T 4PC
83450 数据手册
  Plastic Gear 8T (4-Pack)   SKU: 83450 Weight: 4.00 Gram What is Plastic Gear 8T? Plastic Gear 8T is a kind of gear drives. It usually works with motor shaft as a drive mechanism. There is interference fit between Plastic Gear 8T and motor shaft, therefore the gear should be pressed into the motor shaft with effort while assembling, and has to be disassembled by nut wrench according to the building samples. If the gear has to bear great load and be connected with motor shaft tightly, you need to use glue such as 502 glue. Features ? Number of teeth: 8T; Module: 1.0; ? Material: Nylon, light weight; ? Easy to assemble without screw to fix; ? Little fiction force, high efficiency of driving; ? Low noise. Building Examples:   Schematic Diagram: Specifications SKU 83450 Material Nylon Color Black Package content 4 x Plastic Gear 8T Dimension 160x90x15mm (6.3x3.5x0.6 inch) Net Weight 3g (0.11oz) Gross Weight 4g (0.14oz)        https://store.makeblock.com/plastic‐gear‐8t‐4‐pack/2‐25‐19
83450 价格&库存
很抱歉,暂时无法提供与“83450”相匹配的价格&库存,您可以联系我们找货
