83452
83452
    MAKEBLOCK(创客工场)
    PLASTIC GEAR 56T(PAIR)
83452 数据手册
      Plastic Gear 56T (Pair) SKU: 83452 Weight: 20.00 Gram    What is Plastic Gear 56T? Plastic Gear 56T is a kind of gear drives. It can mesh with other gears to drive various parts. The gear has two bosses for positioning Makeblock parts. Gears also can be overlaid with each other through the bosses in order to make parts connected more stably.   Features ? Number of teeth: 56T; Module: 1.0 ? Material: Nylon, light weight ? A 8mm-diameter wheel inside which is compatible with junction box ? Little fiction force, high efficiency of driving ? Low noise Demo:       Size Charts Specifications SKU 83452 Material Nylon Color Black Dimension 80x130x15mm (3.1x5.1x0.6 inch) Net Weight 18g (0.63oz) Gross Weight 20g (0.71oz)                                      https://store.makeblock.com/plastic‐gear‐56t‐pair/2‐19‐1‐9
83452 价格&库存
很抱歉,暂时无法提供与“83452”相匹配的价格&库存,您可以联系我们找货
