83454
83454
    MAKEBLOCK(创客工场)
    PLASTIC GEAR 72T(PAIR)
83454 数据手册
         Plastic Gear 72T(Pair) SKU: 83454 Weight: 29.00 Gram What is Plastic Gear 72T? Plastic Gear 72T is a kind of gear drives. It can be matched with other gears to drive various parts. The gear has two bosses for positioning Makeblock parts. Gears also can be overlaid with each other through the bosses in order to make parts connected more stably. Features ? Number of teeth: 72T; Module: 1.0 ? Material: Nylon, light weight ? A 8mm-diameter wheel inside which is compatible with junction box ? Little fiction force, high efficiency of driving ? Low noise Building Examples: Size Charts Specifications SKU 83454 Material Nylon color Black Package Dimension 110x150x15mm (4.3x5.9x0.6inch) Net Weight 27g(0.95oz) Gross Weight 29g(1.02oz)        https://store.makeblock.com/plastic‐gear‐72t‐pair/2‐26‐19
83454 价格&库存
很抱歉,暂时无法提供与“83454”相匹配的价格&库存,您可以联系我们找货
