83702
83702
    MAKEBLOCK(创客工场)
    04C 20T SPROCKET
83702 数据手册
  04C 20T Sprocket SKU: 83702 Weight: 60.00 Gram The chain can be used together with the sprocket for transmission of motion and power. Compared with synchronous belt, the chain can transmit more force and drive large load. Features:    It is made of integrated steel, capable of bearing large strength. Through M5x5 of jackbolt, it can firmly combine with 8mm of D-shaped shaft. By surface blackening, it can prevent rusting and increasing rigidity. Specifications:    Type: Shaft Material: Steel Inner diameter: 8 mm                                          https://store.makeblock.com/04c‐20t‐sprocket/2‐6‐19
83702 价格&库存
很抱歉,暂时无法提供与“83702”相匹配的价格&库存,您可以联系我们找货
