84721
84721
    MAKEBLOCK(创客工场)
    SOLID COUPLING 4*6MM (PAIR)
84721 数据手册
      Solid Coupling 4x6mm (Pair) SKU: 84721 Weight: 25.00 Gram Descripton: Makeblock Solid Coupling 4x6mm is frequently used in positive and negative rotation or the transmission needed high sensitivity,can connect the shaft 6mm or T6 lead screw and stepper motor in 3D printer to achieve high quality transmission. Features:    Made from aluminum. Compatible with most 6mm shaft or T6 lead screw. Size: D14*Φ4*Φ6*M3*L25mm. Size Charts(mm): Part List: 2 × Solid Coupling 4x6mm 8× Headless Set Screw M3x3 Demo:                                          https://store.makeblock.com/solid‐coupling‐4x6mm‐pair/2‐20‐1‐9
84721 价格&库存
很抱歉,暂时无法提供与“84721”相匹配的价格&库存,您可以联系我们找货
