84743
84743
    MAKEBLOCK(创客工场)
    SHAFT CLAMPING HUB 8MM-C
84743 数据手册
    Shaft Clamping Hub 8mm-C SKU: 84743 Weight: 14.00 Gram   What Is Shaft Clamping Hub? This shaft clamping hubs is designed to use together with the 36mm encoder DC motor. Driven by the encoder motors, this hub sends the power to the executive device (e.g. wheel). It comes with one 4mm threaded hole and two 4mm holes, allowing you to connect with encoder motors easily. Features ? Suitable for connecting with 8mm shaft; ? Compatible with encoder motor shaft; ? Comes with two hexagon socket button head screws and oneS hexagon socket cap screws. Size Chart (mm):   Specifications SKU 84743  Product Name  Shaft Clamping Hub 8mm‐C  Weight  14 grams  Package Content (Quantity x Part Name)  1 x Shaft Clamping Hub 8mm‐C  2 x screw M4*14(Hexagon socket button head screws)  1 x screw M4*14(Hexagon socket cap screws)                                       https://store.makeblock.com/shaft‐clamping‐hub‐8mm‐c 8‐8‐18
84743 价格&库存
很抱歉,暂时无法提供与“84743”相匹配的价格&库存,您可以联系我们找货
