85009
85009
    MAKEBLOCK(创客工场)
    THREADED SHAFT 4*22MM (PAIR)
85009 数据手册
      Threaded Shaft 4*22mm(Pair) SKU: 85009 Weight: 5.00 Gram  What is Threaded Shaft 4*22mm(Pair)? This threaded shaft can be used as the revolving shaft of rotational joint in linkage mechanism. It is made of stainless steel – SUS304 and consists of a M4 thread shaft (at one end), a shaft shoulder (in the middle), and a linear shaft (at the other end). You can fix the shaft on a beam, bracket or plate by twisting a screw on. Also, the linear shaft can match with a 4mm shaft sleeve. Size Charts Demo:   Specifications SKU Product Content 85009 Threaded Shaft 4*22mm*2 Nut 4mm*2 Length of Thread Shaft 6mm Length of Linear Shaft 12mm Diameter of Shaft Shoulder 6mm Net Weight 5g (0.18oz)                                                     https://store.makeblock.com/threaded‐shaft‐4‐22mm‐pair/2‐26‐19
85009 价格&库存
很抱歉,暂时无法提供与“85009”相匹配的价格&库存,您可以联系我们找货
