85010
85010
    MAKEBLOCK(创客工场)
    THREADED SHAFT ANGULAR SENSOR
85010 数据手册
  Threaded Shaft for Angular Sensor SKU: 85010 Weight: 3.00 Gram What is Threaded Shaft for Angular Sensor? Threaded Shaft is the connection part between linkages and Angular sensor. You can measure the angle of linkages together with the threaded shaft and Angular sensor. The threaded shaft is unable to turn as connected to the linkage, so you just need to fix the threaded shaft on the linkage with a nut. The angle of the shaft is adjustable by 90 degrees a time, so you can adjust the initial angle of the angular sensor. Features of the Threaded Shaft for Angular Sensor ? Material: SUS304 ? Total length: 23mm ? D shaft (at one end): 15mm ? M4 thread shaft (at the other end): 6mm ? Square flange (in the middle): 8x8x2mm Building Examples Size Charts (mm) Specifications SKU 85040 Material SUS304 Color Silver Package Dimension 60x100x10mm (2.4x3.9x0.4 inch) Product Dimension 8x8x23mm (0.3x0.3x0.9 inch) Net Weight 3g (0.11oz) Gross Weight 4g (0.14oz)                                                 https://store.makeblock.com/threaded‐shaft‐for‐angular‐sensor/2‐26‐19
85010 价格&库存
很抱歉,暂时无法提供与“85010”相匹配的价格&库存,您可以联系我们找货
