86508
86508
    MAKEBLOCK(创客工场)
    MINI GRIPPER
86508 数据手册
      Mini Gripper   SKU: 86508 Weight: 40.00 Gram What is Mini Gripper? Mini Gripper is a small-volume, simple gripper perfect for "getting a grip" in lightweight projects. Made of light-weight acrylic material, this gripper also equipped with a 9g servo which ensures fast gripping speed.   Features ? Fast gripping speed; ? Made of transparent acrylic material, smallvolume and lightweight; ? 9g Servo will not burn out when stalled, ensuring long-time use of the gripper itself; ? M4 mounting whole at the end of the gripper for   easy assembling;   ? Perfect for lightweight projects.   What Can You Grip With This Gripper?     This mini gripper is suggested to use in lightweight projects. It is perfect to grab and carry small items with the diameter between 22mm and 60mm, and with the weight under 60 grams, for instance, a ping pong ball, a plastic bottle, a paper cup etc.     Note Please make sure you grip an item by using the phalanx of the gripper instead of the fingertip since using the phalanx can grip items firmly.      Building Examples: Size Chart (mm): Specifications Rated Voltage 12V DC  Operating Voltage Range  5V‐12V DC  Speed of Grip  0.2 sec  Load for Gripper  60g max      Gripper Dimension(L*W*H)  84 x 57 x 35mm (3.30 x 2.24 x 1.37inch)  Net Weight  35g (1.23oz)  Gross Weight  40g (1.41oz)  Part List  1 × Mini Gripper        https://store.makeblock.com/mini‐gripper 8‐3‐18
86508 价格&库存
很抱歉,暂时无法提供与“86508”相匹配的价格&库存,您可以联系我们找货
