87056
87056
    MAKEBLOCK(创客工场)
    100MM MECANUM WHEEL 4MM SHAFT CO
87056 数据手册
     100mm Right Mecanum Wheel with 4mm Shaft Connector (SPCC) SKU: 87056 Weight: 560.00 Gram  What Is 100mm Mecanum Wheel? Makeblock Mecanum wheels allow your robot to not only travel forward and backward, but also side to side. With 4 mecanum wheels, you can build a car/robot that can move in all direction. This wheel is supposed to work together with other 3 Mecanum wheels (1 right, 2 left). Features ? Mecanum wheels allow a robot to achieve omni-directional movement while supporting large weights; ? with all Makeblock parts; ? Work with encoder motor or stepper motor; ? Compatible with 4mm and 8mm motor shaft; ? Cold rolled SPCC steel made, strong rigidity and high impact resistance; ? Easy to assemble; Demo: Size Chart: Specifications SKU 87056 Product Name 100mm Right Mecanum Wheel with 4mm Shaft Connector (SPCC) Gross Weight 560g (19.75oz) Diameter 4 inches (100mm) Width 52mm Rollers 9 x Rubber Roller Plates 2 x SPCC Plate Load Capacity 30KG Package Content (Quantity x Part Name) 1 x Right Mecanum Wheel 1 x 4mm shaft connector 2 x Screw M4*14 2 x Headless Set Screw M3*5                          https://store.makeblock.com/100mm‐left‐mecanum‐wheel‐with‐4mm‐shaft‐connector‐spcc/2‐8‐19
87056 价格&库存
很抱歉,暂时无法提供与“87056”相匹配的价格&库存,您可以联系我们找货
