87334
87334
    MAKEBLOCK(创客工场)
    F688ZZ 8X16X5 FLANGE BEARING 4PC
87334 数据手册
    F688ZZ 8x16x5 Flange Bearing (4-Pack) SKU: 87334 Weight: 50.00 Gram  8x16x5 flange bearing can operate with 8mm of shaft. It can be mounted to the part of 16mm hole, e.g. U-shaped rack C. Features:  Used with with 8mm shaft. Specifications:       Type: Bearing Material: steel Thickness: 5 mm Outer diameter: 16 mm Inner diameter: 8 mm Flange diameter: 18 mm.               https://store.makeblock.com/f688zz‐8x16x5‐flange‐bearing‐4‐pack/2/27/19
87334 价格&库存
很抱歉,暂时无法提供与“87334”相匹配的价格&库存,您可以联系我们找货
