87384
87384
    MAKEBLOCK(创客工场)
    PLANE BEARING TURNTABLE D34X24MM
87384 数据手册
    Plane Bearing Turntable D34x24mm SKU: 87384 Weight: 65.00 Gram Description: Makeblock plane bearing turntable can be used as motion joint or rotatable turntable in the high load and high precision designs. It has plane bearing for motion stability and smoothing. It also can be used in Makeblock mDrawbot. Features:  The max diameter is 34mm, the height is 24mm.  M4 holes in turntable can be compatible with most parts and structures in Makeblock. Size Charts(mm): 1 - Plane Bearing51103 2 - Turntable D34-A 3 - Turntable D34-B 4 - Micro Plane Bearing F4-10 5 - Socket Cap Screw M4*16mm-Button Demo:                               https://store.makeblock.com/plane‐bearing‐turntable‐d34x24mm/2‐11‐19
87384 价格&库存
很抱歉,暂时无法提供与“87384”相匹配的价格&库存,您可以联系我们找货
