89014
89014
    MAKEBLOCK(创客工场)
    FLANGE COPPER 4*8*3MM 10PC
89014 数据手册
      Flange Copper Sleeve 4*8*3mm (10-Pack) SKU: 89014 Weight: 15.00 Gram Makeblock Flange Copper Sleeve (4 x 8 x 3mm) has inner diameter of 4mm, outer diameter of 8mm, length of 3mm, and flange diameter of 10mm. Flange copper sleeve is brass-made and has features of high accuracy, smoothness, wear resistance, rust resistance. It can be a replacement of bearing in DIY projects. For example, in Makeblock Timing Pulley 62T, Timing Pulley 90T, Plastic Timing Pulley 62T, Plastic Timing Pulley 90T, Plastic Timing Pulley 62T without Steps and Plastic Timing Pulley 90T without Steps. It can be used as a high-precision moving parts to ensure the stable motion of the above items. Also, it can be used together with copper washer (4* 10*1mm). Part List: 10 x Flange Copper Sleeve 4*8*3mm Features:      Compatible with Timing Pulley and Shaft D4mm in Makeblock; Ensure a stable motion of the moving parts and reach a high-precision requirement; Made of brass; Diameters: 4mm (inside), 8mm (outside); Sold in pack of 10                                            https://store.makeblock.com/flange‐copper‐sleeve‐4‐8‐3mm‐10‐pack/2‐25‐19
89014 价格&库存
很抱歉,暂时无法提供与“89014”相匹配的价格&库存,您可以联系我们找货
