89025
89025
    MAKEBLOCK(创客工场)
    FISH-EYE JOINT M4 4PC
89025 数据手册
          Fish-eye Joint M4(4-Pack) SKU: 89025 Weight: 12.00 Gram What Is Fish-eye Joint M4? Fish-eye Joint is frequently-used mechanical part of Makeblock platform which can rotate 360 degrees freely. The M4 hole on this joint allows you to connect with other Makeblock parts easily.   Feature ? Made from nylon and brass; ? Comes with a M4 hole, compatible with all Makeblock parts; ? High wear resistance, light-weight; ? Easy to assemble and disassemble; Demo Size Chart (mm): Specifications SKU 89025  Product Name  Fish‐eye Joint M4(4‐Pack)  Net Weight  12g (0.42oz)  Package Content (Quantity x Part Name) 4 x Fish-eye Joint M4                                                      https://store.makeblock.com/fish‐eye‐joint‐m4‐4‐pack/2‐6‐19
89025
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光耦器件,用于隔离输入和输出电路,保护电路安全。
3. 引脚分配:EL817有6个引脚,分别为1脚发光二极管阳极,2脚发光二极管阴极,3脚光电晶体管集电极,4脚光电晶体管发射极,5脚光电晶体管基极,6脚光电晶体管电源。
4. 参数特性:EL817的主要参数包括工作温度范围-40~85℃,隔离电压3750Vrms,输入电流5mA,输出电流10mA。
5. 功能详解:EL817通过发光二极管和光电晶体管实现电-光-电转换,实现信号隔离。
6. 应用信息:EL817广泛应用于工业控制、医疗设备、通信设备等领域。
7. 封装信息:EL817采用DIP-6封装。
89025 价格&库存
很抱歉,暂时无法提供与“89025”相匹配的价格&库存,您可以联系我们找货
