95016
95016
    MAKEBLOCK(创客工场)
    HARDWARE PACK
95016 数据手册
      Hardware Pack SKU: 95016 Weight: 650.00 Gram  PRODUCT DESCRIPTION Note: Makeblock Socket Cap Screw was replaced by Button Head Socket Cap Screw , and the tool HEX Screwdriver 3mm was replaced by HEX Screwdriver 2.5mm. Button Head Socket Cap Screw is a new kind of Socket Cap Screw, it has smaller head that can solve most problem of interfere with other components. Description: This Hardware Pack contains the most frequently used hardwares in Makeblock platform.The box can be opened in two sides and the size is 160*92*44mm. Part List: 40x Socket Cap Screw M4x8 60x  Socket Cap Screw M4x14 40x  Socket Cap Screw M4x22 20x  Socket Cap Screw M4x35 50x  Nut M4  20x  Nylon lock Nut 4mm 1x  Wrench 7mm  6x  Brass Stud M4*8+6 6x  Brass Stud M4*16  4x  Brass Stud M4*32  30x  Plastic Rivet R4060 30x  Plastic Rivet R4120 30x  Headless Set Screw M3x5 100x  Plastic Ring 4x7x2mm 1x  Plastic Box                                                    https://store.makeblock.com/hardware‐pack/2‐6‐19
95016 价格&库存
很抱歉,暂时无法提供与“95016”相匹配的价格&库存,您可以联系我们找货
