95052
95052
    MAKEBLOCK(创客工场)
    GEARMOTOR 185 RPM 9V
95052 数据手册
        Optical Encoder Motor Pack-25 9V/185RPM SKU: 95052 Weight: 228.00 Gram OVERVIEW   What Is Optical Encoder Motor Pack-25 9V/185RPM? 25mm Encoder DC Motor Pack includes two encoder motors, one encoder motor driver and two cables. In contrast to the DC motor, a photoelectric encoder is added into the encoder motor for detecting speed which is fed back to the signal input terminal for PID control to implement servo control for the motor. Features ? Control the speed and displacement for the motor precisely; ? Users can customize their own PID parameter by self-contained software; ? It provides overload protection. Note Before using, please make sure there is enough distance between the white sensor and the black coding disk as below picture for the white sensor may be damaged by the rotating part. Specifications SKU 95052 Rated voltage 9.0V (DC) Temperature range -20 ~+60 Humidity range 0%-90% No-load current ≦ 200 mA No-load speed 185±10% rpm Rated load 0.9 Kgf.cm Rated current ≦ 550mA Rated speed 135±10% rpm Starting torque 4.5kgf.cm Locked-rotor current ≥ 2.0 A Parts List 1 x Me Encoder Motor Driver 2 x Optical Encoder Motor-25 9V/185RPM 2 x Encoder Motor Wire Package Dimension 200 x 140 x 30mm (7.9 x 5.5 x 1.2inch) Net Weight 222g (7.83oz) Gross Weight 228g (8.04oz)                           https://store.makeblock.com/optical‐encoder‐motor‐pack‐25‐9v‐185rpm/2‐7‐19
95052 价格&库存
很抱歉,暂时无法提供与“95052”相匹配的价格&库存,您可以联系我们找货
