95067
95067
    MAKEBLOCK(创客工场)
    100MM MECANUM WHEEL SET WITH 4MM
95067 数据手册
  100mm Mecanum Wheel Set with 4mm Shaft Connector (SPCC) SKU: 95067 Weight: 2150.00 Gram What is 100mm Mecanum Wheel? The 100mm Aluminum Mecanum Wheel Set (2 x Left, 2 x Right) includes 2 right wheels and 2 left wheels. Each wheel is composed of 9 rollers and can be driven independently. Mecanum wheels allow your robot to not only travel forward and backward, but also side to side. With 4 mecanum wheels, you can build a car/robot that can move in all direction. Each wheel of this pack comes with a compatible mounting hub - 4mm shaft connector, hence it will mate with our encoder motor or stepper motor easily. Note: For Makeblock Mecanum Wheels with 8mm mounting hub, please visit: SKU 84790 Features ? Mecanum wheels allow a robot to achieve omni-directional movement while supporting large weights; ? Complete set of mecanum wheels with 4mm shaft connector; ? Work with encoder motor or stepper motor; ? Compatible with 4mm and 8mm motor shaft; ? Cold rolled SPCC steel made, strong rigidity and high impact resistance; ? Easy to assemble. Demo: Size Chart: Specifications SKU 95067 Product Name 100mm Mecanum Wheel Set with 4mm Shaft Connector (SPCC) Gross Weight 2150g (75.84oz) Diameter 4 inches (100mm) Width 52mm Rollers 9 x Rubber Roller Plates 2 x SPCC Plate Load Capacity 30KG Package Content (Quantity x Part Name) 2 x Right Mecanum Wheel 2 x Left Mecanum Wheel 4 x 4mm shaft connector 8 x Screw M4 x 14mm 8 x Headless Set Screw M3 x 5mm       https://store.makeblock.com/100mm‐mecanum‐wheel‐set‐with‐4mm‐shaft‐connector‐spcc/2‐7‐19
95067 价格&库存
很抱歉,暂时无法提供与“95067”相匹配的价格&库存,您可以联系我们找货
