98000
98000
    MAKEBLOCK(创客工场)
    MAKEBLOCK ROBOTIC ARM ADD-ON PAC
98000 数据手册
    Robotic Arm Add‐on Pack for Starter Robot  Kit – Blue  SKU: 98000 Weight: 800.00 Gram   Transform Your Starter Robot Arm Add-on Pack serves to transform your Starter Robot Kit to a robotic-arm tank. It contains all parts you need for building a robotic arms, including DC Motor-37, Robot Gripper, beams, timing pulleys, and hardware. (Picture for reference only. please go through part list before purchasing.) Devoted to Bring Fun Composing of easy-to-assemble mechanical parts, color-labelled electronic modules, and a nimble gripper, controlled by IR remoter controller, this pack aims to bring more fun: pick up a bottle of water and get it delivered under your command. Large Open‐Width Gripper The gripper included in this pack is capable of opening an impressive 3" (67mm) wide. It enables you to grip items of various sizes according to your needs. Self‐Protection Design The inner N20 screw motor of the gripper included in this pack will automatically stop running when the gripper is fully open or closed. This protects the screw motor from short-circuits and over-current, ensuring long-time use of the gripper. Resource: We provide manual for assembling the Robotic Arm, click the link below to view: Guide for Assembling the Robotic Arm https://github.com/Makeblock-official/Robotic-Arm-Add-On-Pack-ForStarter-Robot-Kit If you have any questions about this product or you need technical support, please post it in our forum. *Note: The Socket Cap Screw in this pack is button head socket cap screw which shall be used together with 2.5mm HEX Screwdriver (also included in this pack). Button Head Socket Cap Screw, as a new type socket cap screw, has smaller head that can solve most interference problems between components. Part List 1x 1 x Beam 0824-64 Timing Pulley 2 x Nylon lock Nut 4mm 90T 1x 1 x Beam 0824-80 Timing Belt 123T 4 x Countersunk Screw M3x8 3 x Linear Motion 3 x Beam 0824-96 Shaft 12 x Headless Set Screw M3x5 D4x88m m 8 x Shaft 3 x Beam 0808-168 Collar 6 x Plastic Ring 4x7x2mm 4mm 1x 3 x Plate 3x6 Flange Bearing 1 x Me Dual DC Motor Driver 4x8x3mm 16 x Socket 1 x DC Motor-37 Bracket B Cap 2 x 6P6C RJ25 cable-20cm Screw M4x8 14 x Socket 1 x DC Motor-37 12V/50RPM Cap 1 x HEX Screwdriver 2.5mm Screw M4x14 6x Socket 1 x Strong Robot Gripper Cap 1 x HEX Allen Key 1.5mm Screw M4x22 1 x Timing Pulley18T 8 x Nut M4                                                        http://store.makeblock.com/robotic‐arm‐add‐on‐pack‐for‐starter‐robot‐kit‐blue11‐17‐20
98000 价格&库存
很抱歉,暂时无法提供与“98000”相匹配的价格&库存,您可以联系我们找货
