P5010059
P5010059
    MAKEBLOCK(创客工场)
    MCREATE W/O LASER ENGRAVER
P5010059 数据手册
M mCreate 3D printer 2 Education Application Scenarios Positioning Main Features Other Features Specification mCreate VS XYZ Printing Education Application Scenarios Support for courses such as 3D design Support for club events, competitions, and maker activities mCreate turns abstract 3 dimensions into visual and tactile objects, facilitating the cultivation of innovation and creativity in primary and secondary schools. mCreate allows students to make special parts and models for club events, competitions, and other activities, developing their hands-on skills and problem-solving abilities. Support for higher vocational college education mCreate brings creative industrial design from drawing to reality, boosting students' creativity and gearing them up for future careers. Makeblock mCreate Smart leveling versatile 3D printer ‘Genius’ Smart Leveling Patented smart nozzle, Change nozzle in 3s Flexible Magnetic Build Plate Full-color Touch Screen 220*220*295mm Large Build Volume Resume Printing after Power Outage Support STEAM Education mCreate mCreate is a versatile desktop 3D printer featuring the innovative Genius smart leveling technology for accurate printing. Our patented smart nozzle, flexible magnetic build plate and the ability to resume working even after a power outage, enable mCreate to deliver a remarkable print success rate and quality. By quickly switching to the laser engraving mode, the machine meets the needs of a broader range of applications in STEAM education or other creative projects. Built for materializing creativity, mCreate make ideas tangible. Main Features Reliable & High printing success rate New Technologies Help Enhance Printing Success Rate Easy to use, Ready to print STEAM education supported User-Friendly Operations for Beginners Combine with mBuild, Laserbox to create more Main Features Reliable & High printing success rate New Technologies Help Enhance Printing Success Rate Easy to use, Ready to print STEAM education supported User-Friendly Operations for Beginners Combine with mBuild, Laserbox to create more A leveled bed is a prerequisite for an accurate print 98% 87% Failed print caused by the failure of the first layer printing of them are due to the improper bed leveling/unleveled How does other 3D printer do the bed leveling? Manual Bed leveling X complicated and frustrating experience X a risk of human error X tedious and time-consuming Click to watch the video How does other 3D printer do the bed leveling? Automatic Bed leveling X indirect measurement X mechanical errors, influence the measurement accuracy 3D printer with auto-leveling has a switch or proximity sensor near the tip of the print head that “probes” specific points on the platform when the bed leveling process is first initiated. Makeblock mCreate Genius smart leveling creates accurate prints | Avoid errors | Hassle-free | Truly guarantee the success rate of the first layer printing Click to watch the video Patented smart nozzle makes printing better and steadier | AI-enabled sensor, measurement accuracy within 0.01mm | Integrated extruder, Quick nozzle replacement in 3s | Ultra-quiet cooling system, a 360-degree circular airflow pattern to enable even cooling for discharge | Intelligent filament sensor,avoid print failure caused by a material shortage. Patented smart nozzle makes printing better and steadier | AI-enabled sensor, measurement accuracy within 0.01mm | Integrated extruder, Quick nozzle replacement in 3s | Ultra-quiet cooling system, a 360-degree circular airflow pattern to enable even cooling for discharge | Intelligent filament sensor,avoid print failure caused by a material shortage. Click to watch the video Patented smart nozzle makes printing better and steadier | AI-enabled sensor, measurement accuracy within 0.01mm | Integrated extruder, Quick nozzle replacement in 3s | Ultra-quiet cooling system, a 360-degree circular airflow pattern to enable even cooling for discharge | Intelligent filament sensor,avoid print failure caused by a material shortage. Click to watch the video Patented smart nozzle makes printing better and steadier | AI-enabled sensor, measurement accuracy within 0.01mm | Integrated extruder, Quick nozzle replacement in 3s | Ultra-quiet cooling system, a 360-degree circular airflow pattern to enable even cooling for discharge | Intelligent filament sensor,avoid print failure caused by a material shortage. Magnetic flexible printing platform supports various materials and easy pickup of output | The magnetic cover is heated evenly which enhanced the adhesion of the 3D print as well as preventing edge warping and curling. | After printing, you can take off the magnetic cover and easily remove the output without needing a scraper. Click to watch the video Resume printing after a power outage The nozzle will rise instantly during a power outage, protecting the semi-finished print. After the power is back on, the nozzle will return to its initial position to heat up and then continue printing. This feature effectively minimizes print material and time losses due to power interruptions. Click to watch the video Aircraft-grade aluminum, Improve success rate comprehensively mCreate has a solid body that minimizes resonance, making printing more stable. The stylish body design is also corrosion-resistant and durable. Large Build Volume, expands what is possible to create mCreate provides a super-sized printing volume that allows you to print multiple models in one go and print the works with high height, serving the needs of large classes. 295mm 220mm 220mm Main Features Reliable & High printing success rate New Technologies Help Enhance Printing Success Rate Easy to use, Ready to print User-Friendly Operations for Beginners STEAM education supported Combine with mBuild, Laserbox to create more Main Features Reliable & high printing success rate New Technologies Help Enhance Printing Success Rate Easy to use, ready to print User-Friendly Operations for Beginners STEAM education supported Combine with mBuild, Laserbox to create more Versatile and user-friendly operating tools 3D printing Preset default slicing value Run the 3D slicing software called Cura, then install the plugin for mCreate, and select "Makeblock" as the print device; the printing parameters will then be configured automatically. Wh en Cura finishes slicing your model, it is ready for printing. Full-color touchscreen for better workflow visualization • 3.5 inch full-color screen • Clear and intuitive function icons • Real-time display of device status and job status • Direct launch of printing jobs or update of firmware • Support file search and preview • Default OS languages are English & Chinese yet can be set to two other OS languages Main Features Reliable & high printing success rate New Technologies Help Enhance Printing Success Rate Easy to use, ready to print User-Friendly Operations for Beginners STEAM education supported Combine with mBuild, Laserbox to create more Integration of hardware and software, designed for education mCreate helps students learn from their practice on idea materialization and thinking training. With mBuild electronic modules, students can use mCreate to program their creative ideas into smart home prototype designs, robot design and building, etc. Click to watch the video Other Features Clog detection Multiple connection modes Check whether the nozzle is clogged. Support third-party materials to allow more creative possibilities. Open filament system USB connected to mCreate or a file sent through Cura/Laserbox to mCreate. Specification 3D printing Additive Manufacturing Process Build Volume(L × W × D) Layer Resolution Software (Slicing Application) Supported File Type(s) File Extension Supported Materials Nozzle Temperature Heated Bed FDM 220 × 220 × 295 mm 50-300μm Cura STL, OBJ, X3D, 3MF, JPG, PNG, GIF, BMP, etc. GCODE PLA and derivatives、ABS and derivatives, TPU, PC,. Nylon, PET, ASA, HIPS, PP, PVA, etc 260°C(Max.) 100°C(Max.) 295mm 220mm 220mm Makeblock mCreate Smart leveling versatile 3D printer $799 3D printing only XYZprinting da Vinci Jr. 1.0 Pro Makeblock mCreate Picture Product Dimension Better look, better design 420 x 430 x 380 mm 445 x 485 x 550 mm Type Close Open(sheild on the way for close design) Printing Technology Fused filament fabrication Fused deposition modeling Max. Building Size X/Y Positioning Precision Z Positioning Precision Layer Resolution Max. Moving Speed Filamentt Diameter Material Compatibility Max. Nozzle Temperature Makeblock Advantages 150 x 150 x 150 mm 220 x 220 x 295 mm 0.0125mm 0.01mm 0.0004mm 0.002mm 20-400μm 50-300μm 160mm/s 150mm/s 1.75mm 1.75mm PLA, Antibacterial PLA / PETG / Tough PLA / Wood / *Premium Metallic PLA PLA and derivatives, TPU, PP, PVA, etc. 240°C 260°C Open&close structure switchabe. Open structure can provide better view of the printing process Providing much larger building space at with almost same size High temperature with high material compatibility Thanks
P5010059 价格&库存
很抱歉,暂时无法提供与“P5010059”相匹配的价格&库存,您可以联系我们找货
