11008
11008
    MAKEBLOCK(创客工场)
    ME SOUND SENSOR V1
11008 数据手册
Me Sound Sensor Overview Based on a microphone, the Me Sound Sensor can be used to detect the ambient sound intensity. Its main component is LM2904 low-power amplifier. The module can be used to build some interactive projects, such as the voice operated switch, and the dance-following robot. Its black ID means that it has an analog port and should be connected to the port with black ID on Makeblock Orion. Technical specifications ● Operating voltage: 5V DC ● Microphone sensitivity (1 Khz): 50-54dB ● Microphone impedance: 2.2 KΩ ● Microphone frequency: 16-20 KHz ● Microphone SNR: 54 db ● Control mode: Single analog port output ● Maximum current: 0.5mA ● Type of power amplifier: LM2906 ● Module size: 51 x 24 x 18 mm (L x W x H) Functional characteristics ● Brightness of onboard LED indicates the intensity of sound ● High sensitivity to the sound ● White area of module is the reference area to contact metal beams ● Anti-reverse protection – connecting the power supply inversely will not damage IC ● Support mBlock GUI programming, and applicable to users of all ages ● Adopt RJ25 port for easy connection ● Provide pin-type port to support most development boards including Arduino series Pin definition The port of Me Sound Sensor has three pins, and their functions are as follows: Wiring mode ● Connecting with RJ25 Since the port of Me Sound Sensor has black ID, you need to connect the port with black ID on Makeblock Orion when using RJ25 port. Taking Makeblock Orion as example, you can connect it to ports No. 6, 7, and 8 as follows: ● Connecting with Dupont wire When the Dupont wire is used to connect the module to the Arduino UNO Baseboard, its AO pin should be connected to analog pin as follows: Guide to programming ● Arduino programming If you use Arduino to write a program, the library Makeblock-Library-master should be invoked to control the Me Sound Sensor. This is a routine to instruct the module to detect the intensity ofambient sound through Arduino programming. Read the detected result from the Me Sound Sensor, and output the result to serial monitor in Arduino IDE in the cycle of 100ms. Upload the code segment to the Makeblock Baseboard and click the Arduino serial monitor, and then you will see the running result as follows: Schematic http://store.makeblock.com/me-sound-sensor 11-15-17
11008 价格&库存
很抱歉,暂时无法提供与“11008”相匹配的价格&库存,您可以联系我们找货
