P1020001
P1020001
    MAKEBLOCK(创客工场)
    MBOT & MBOT RANGER ADD-ON PACK V
P1020001 数据手册
        Variety gizmos add-on pack for mBot & mBot Ranger   SKU: P1020001 Weight: 250.00 Gram  What is the variety gizmos add-on pack for mBot & mBot Ranger? The variety gizmos add-on pack for mBot and mBot Ranger is a brand new add-on pack. It contains six add-on cases for mBot and two for mBot Ranger. It has enriched the cases for motion control and appearance relative to mBot and mBot Ranger. Besides, you can assemble it into more forms on your own idea, and explore more possibilities. User Manual: http://learn.makeblock.com/en/gizmos/   mBot add‐on case 1: Antenna Car A robot car that can detect obstacle through its two micro switch.   mBot add-on case 2: Traffic Gate      mBot add-on case 3: Dancing Cat     mBot add-on case 4: Head-Shaking Cat     mBot add-on case 5: Light-Emitting Cat   mBot add-on case 6: Timer The timer can record the time, and it can be used as the handle of mBlock stage.   mBot Ranger add-on case 1:Sunflower The sunflower always face to the place where there is bright.     mBot Ranger add-on case 2:Magic Stick The color and effects of the light can be changed by shaking the magic stick or touch the micro switch.     Specifications SKU P1020001 Product Name mBot & mBot Ranger add-on pack Variety gizmos Category Add-on Pack Weight 330g (11.64oz) Package Dimension (Height×Width×Length) 209 mm×154 mm×54mm Part List 1× RJ25 Adapter Module 1× RGB LED Module 1× Segment Serial Display 2× Micro Switch B 1× 9g Micro Servo Pack 4× RJ25 Cable 2× Cuttable Linkage 2× Plate I1 2× Bracket 3×3 2× Plate 45° 2× Bracket 120° 3×3 4× M4×25mm Brass Stud 16× M4×8mm Screw 20× M4×14mm Screw 4× M4×22mm Screw 20× M4 Nut 10× Plastic Spacer 4×7×3mm 1× Wrench 5mm&7mm                                                          https://store.makeblock.com/P1020001/2‐7‐19
P1020001 价格&库存
很抱歉,暂时无法提供与“P1020001”相匹配的价格&库存,您可以联系我们找货
