P1020002
P1020002
    MAKEBLOCK(创客工场)
    MBOT & MBOT RANGER ADD-ON PACK P
P1020002 数据手册
            Perception gizmos add-on pack for mBot & mBot Ranger SKU: P1020002 Weight: 350.00 Gram  What is the perception gizmos add-on pack for mBot &mBot Ranger?   The perception gizmos add-on pack for mBot and mBot Ranger is a brand new add-on pack. It contains five add-on cases for mBot and two for mBot Ranger. It has enriched the cases for motion control and appearance relative to mBot and mBot Ranger. Besides, you can assemble it into more forms on your own idea, and explore more possibilities. mBot add-on case 1:Range finder Range finder can measure the range by handheld device. Off-line operation is available.     mBot add-on case 2: Sound control lamp The lamp would be turned on in dark area when sound reach at certain value.     mBot add-on case 3: Weather station It can measure temperature and humidity and show the value on the LED screen.     mBot add-on case 4: Knob Robot It is a robot that can play number guessing game.   mBot add-on case 5:Energy-saving fan The fan would be turned on when you get close to it, and it would be turned off when you leave it.       mBot Ranger add-on case 1:Roly-poly The robot can return to vertical state after shaking. And it can do specific action and expression by programming.     mBot Ranger add-on case 2:Music Box The music box would be switched on by controlling lights. When the music starts, the doll beginning to spin, and the LED lighting up.     Specifications SKU P1020002 Product Name mBot & mBot Ranger add-on pack Perception gizmos Category Add-on Pack Weight 350g (12.35oz) Package Dimension (Height×Width×Length) 209 mm×154 mm×54mm Part List 1× Temperature and Humidity Sensor 1× Sound Sensor 1× Potentiometer 1× LED Matrix 8×16 1× 130 Motor Pack 4× RJ25 Cable 2× Beam 0824-096 2× Beam 0808-072 2× Bracket 3×3 2× Plate 45° 1× Wrench 5mm&7mm 4× M4×25mm Brass Stud 16× M4×8mm Screw 20× M4×14mm Screw 4× M4×22mm Screw 20× M4 Nut 10× Plastic Spacer 4×7×3mm                                                      https://store.makeblock.com/P1020002/2‐7‐19
P1020002 价格&库存
很抱歉,暂时无法提供与“P1020002”相匹配的价格&库存,您可以联系我们找货
