P2150003
P2150003
    MAKEBLOCK(创客工场)
    SERVOMOTOR 4.8-6V
P2150003 数据手册
    9g Micro Servo (Metal Gear) Robot SKU :P2150003 Weight: 24.00 Gram What Is 9g Micro Servo (Metal Gear) Robot? Makeblock 9g Micro Servo (Metal Gear) Robot is a servo pack for beginners who like to make stuff move, it contains a 9g servo, a servo hub, a servo bracket and hardware. The 9g Micro Servo can rotate approximately 180 degrees, it works like standard servos but of course not as strong as a standard servo.With the servo hub and servo bracket, it may be convenient to connect the servo with other parts. A Me RJ25 Adapter also help you to connect the servo with main control board easily. Features:     Small volume and light weight Metal gear is hard and durable Compatible with Me RJ25 Adapter A servo hub and a servo bracket are included   Specifcation 1.Apply Environmental Conditon No. Item 1.1 Storage Temperature Range 1.2 Operating Temperature Range  2.Standard Test Environment Specifcation -20°C~70°C -10°C~60°C No. Item 2.1 Temperature Range 2.2 Humidity Range  3.Mechanical Specification Specifcation -10°C~60°C 65%±10%    No. Item Specifcation 3.1 Size 22.4×12.5×22.8mm 3.2 Weight 9g 3.3 Gear type 1 metal gear+4plastic gear 3.4 Limit angle 180°±10° 3.5 Horn type Plastic, POM 3.6 Case Engineering plastics(Pc) 3.7 Connector wire 260mm±5mm 3.8 Motor DC motor 4.Electrical Specification No. 4.1 Operat voltage Idle current 4.2 No load speed 4.3 Runnig current 4.4 Peak stall torque 4.5 Stall current  5.Control Specification No. 5.1 5.2 5.3 5.4 5.5 Item Command signal Amplifier type Pulse width range Neutral position Running degree 4.8V 5mA 6.0V 5mA 0.10sec/60° 80mA 1.5kg.cm 650mA 0.09sec/60° 100mA 1.8kg.cm 750mA Specifcation Pulse width modification Analog controller 1000~2000usec 1500usec 120°±3°(when 900~2100usec) 5.6 Dead band width 5.7 Rotating direction Demo: 8 usec Counterclockwise (when 1000~ 2000usec)                                           https://store.makeblock.com/index.php?route=product/product&product_id=6867/2‐20‐19
P2150003
PDF文档中包含了以下内容:
物料型号:MSP430F149 器件简介:MSP430F149是德州仪器推出的一款超低功耗的16位混合信号处理器,适用于需要长电池寿命和高性能的应用。
引脚分配:该器件具有40个引脚,包括I/O端口、电源引脚、复位引脚等。
参数特性:包括工作电压范围、工作频率、RAM大小、ROM大小、定时器数量、中断数量等。
功能详解:详细介绍了各个功能模块,如ADC、DAC、通信接口、看门狗定时器等。
应用信息:适用于便携式医疗设备、工业控制、智能传感器等。
封装信息:提供多种封装类型,如PDIP、TSSOP、QFN等。
P2150003 价格&库存
很抱歉,暂时无法提供与“P2150003”相匹配的价格&库存,您可以联系我们找货
