P3030001
P3030001
    MAKEBLOCK(创客工场)
    ME RGB LINE FOLLOWER V1
P3030001 数据手册
       Me RGB Line Follower V1 SKU: P3030001 Weight: 15.90 Gram Description: RGB Grayscale Sensor is specially designed for line detect competition. It contains 4 RGB fill flashes and 4 photodiodes. This sensor can be used to detect line on deep background with light color track and light background deep color track as well. RGB Grayscale Sensor can detect line when grey value is greater than threshold value.( It is advised that the threshold value is greater than 30, that the effect is better.) This module has the functions of fast detection, learn court via button and the advantage of well adapted. The color code of the sensor’s port is blue and white, it means double digital, I2C port, and it needs to link to the port which has blue and with color code on the main board. Features:     Support Arduino IDE programming, and supply runtime library to simplify programming.; It has 4 LED which are used to line detect feedback and new environment learning; Used RJ25 port which can connect easily; Suitable for Makeblock DIY platform metal parts: the white area on the sensor can contact with metal parts; Specification:      Operating Voltage: 5V DC; Detecting Height: As the differences of material and light condition of the track, it is advised that the distance between probe and track is from 5mm to 15mm; Operating Temperature: 0Ԩ~70Ԩ; Signal Mode: I2C communication( blue and white color code); 48 x 72 x 26.5 mm Pack List:  1*Me RGB Line Follower V1                                                 https://store.makeblock.com/me‐rgb‐line‐follower‐v1/2‐7‐19
P3030001 价格&库存
很抱歉,暂时无法提供与“P3030001”相匹配的价格&库存,您可以联系我们找货
