P3050001
P3050001
    MAKEBLOCK(创客工场)
    ME TFT LCD SCREEN - 2.4 INCH V1
P3050001 数据手册
         Me TFT LCD Screen - 2.4 Inch V1 SKU: P3050001 Weight: 28.50 Gram What is Me TFT LCD Screen - 2.4 Inch V1? This module can display geometric figures and characters. You can send commands through serial port to display. Me TFT LCD Screen - 2.4 Inch V1 is controlled through serial port, and backlight can be adjusted. It has M4 mounting holes at intervals of 16mm, and it is compatible with Makeblock beams. The 2.54mm pin holes is used to connect with Dupont wire. The 6P6C RJ25 interface is easy for wiring. Basic graphic display such as dots, lines, circle, rectangle, and filled rectangle are supported. It also has build-in fonts and variety of pictures which can be directly used by command. Arduino library is easy for programming. Clear and Bright This Screen enables you to show your animations or characters clearly and brightly. Great Compatibility Specially designed M4 through holes on Me TFT LCD Screen - 2.4 Inch V1enables you to assembly with other Makeblock items just by tightening the screws. Programmable by mBlock Drag-and-customized your own emotion, animation, scrolling-captions with mBlock which is a graphical programming environment based on Scratch 2.0 Open Source Code. It makes programming projects and interactive applications easier thru simply dragging and dropping function block. Know more here http://www.mblock.cc/?noredirect=en_US   Have Fun with mBot This Me TFT LCD Screen - 2.4 Inch V1 is frequently-used together with mBot. Add this Me TFT LCD Screen - 2.4 Inch V1 to your mBot to color your experience of playing with the robot. It's highly welcomed by mBot users. Just take a look at these brilliant projects: Specifications Size 78*51.2mm(3.07*2.02inch) Weight 28.5g Connectivity Bluetooth Software and programming Makeblock app for iOS and Android Part List 1×Me TFT LCD Screen - 2.4 Inch 1×4*7*2 Plastic Spacer(4-Pack)                          https://store.makeblock.com/index.php?route=product/product&product_id=6866/2‐7‐19
P3050001 价格&库存
很抱歉,暂时无法提供与“P3050001”相匹配的价格&库存,您可以联系我们找货
