NL1013T-01AC
NL1013T-01AC
    II-VI
    Peltier 模块 4.8W @ 27°C 1 A 85°C
NL1013T-01AC 数据手册
Technical Data Sheet For NL1013T Single-Stage Thermoelectric Module PRODUCT FEATURES • • • • • RoHS EU Compliant Rated operating temperature of 85°C. Maximum processing temperature of 120°C. Ceramic Material: Aluminum Oxide. Metallized Exterior Surfaces are Au flash, suitable for soldering. II-VI MARLOW www.marlow.com CONTACT US marlow.sales@ii-vi.com– Dallas, TX USA 214-340-4900 – 877-627-5691 DOC #: 102-10012 REV: A01 NOMINAL PERFORMANCE IN VACUUM Hot Side Temperature (°C) Δ Tmax (°C): Qmax (watts): Imax (amps): Vmax (vdc): AC Resistance (ohms): OPERATION CAUTIONS 27 61 4.8 1.0 8.5 0.77 50 69 5.4 1.0 9.6 -- ORDERING OPTIONS Model Number NL1013T-01AC NL1013T For maximum reliability, storage and operation below 85°C in a non-condensing environment is recommended. To minimize thermal stress, use linear/proportional temperature control or a similar method rather than an ON/OFF method. INSTALLATION Description Top and Base Metallized Exterior Recommended mounting methods: Bonding with thermal epoxy or soldering with metallized ceramics. For additional information, please refer to our TEM Installation Guide. TYPICAL PERFORMANCE CURVES ENVIRONMENT: 10^-5 TORR VACUUM 0.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 T (C) 60 40 20 VOLTAGE (VDC) 0 8 6 4 2 0 0.0 Q=0 T=0 0.2 0.4 0.6 0.8 CURRENT (AMPS) 1.0 80 HEAT LOAD (WATTS) 0.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 60 T (C) 80 Hot Side Temperature 50°C HEAT LOAD (WATTS) 40 20 0 VOLTAGE (VDC) Hot Side Temperature 27°C 8 6 4 Q=0 T=0 2 0 0.0 0.2 0.4 0.6 0.8 CURRENT (AMPS) 1.0 For performance information in a vacuum or with hot side temperatures other than 27°C or 75°C, contact one of our Applications Engineers at 877-627-5691. DOC #: 102-10012 MI Form 005-0685 Rev A REV: A01 2/3 NL1013T MECHANICAL CHARACTERISTICS 0.20±0.13, 4X (+) Leads: 28 AWG, Buss, Solid Tinned Copper 13.16 (-) 13.16 2.41±0.13 Cold Side, Tc 50.80±6.35 0.13 A 0.03 0.03 Hot Side, Th A 0.20±0.13, 4X All units are in millimeters unless otherwise stated. For customer support or general questions please contact a local office or visit our website at www.marlow.com. Marlow reserves the right to make product changes without notice. DOC #: 102-10012 MI Form 005-0685 Rev A REV: A01 3/3
NL1013T-01AC 价格&库存
很抱歉,暂时无法提供与“NL1013T-01AC”相匹配的价格&库存,您可以联系我们找货
