MASTER
MASTER HEAT GUN®
MASTER VARITEMP®
HEAT GUN
A LA SORTIE.
DU BEC OPÉRER À ‘COLD’
AVANT DE FERMER
-CAUTIONHIGH TEMPERATURE AT
NOZZLE. RUN ON ‘COLD’
BEFORE TURNING OFF.
-ADVERTENCIAALTA TEMPERATURA EN LA
BOQUILLA. ANTES DE
APAGAR LA HERRAMIENTA.
Instruction Manual
Models HG- 502D, 502T, 302D, 302T,
202D, 202T, VT-752D
Original Instructions
Please read, understand and keep this manual for future reference.
Traduction des instructions d'origine
Veillez à lire, comprendre et conserver ce mode d'emploi pour
pouvoir vous y reporter ultérieurement.
Traducción de las Instrucciones originales
Lea, entienda y guarde este manual para futuras consultas.
Übersetzung der Originalanweisungen
Bitte lesen Sie dieses Handbuch aufmerksam durch und bewahren
Sie es zur späteren Zuhilfenahme auf.
Assembled in USA
Assemblé aux États-Unis
Ensamblado en EE. UU.
Montiert in den USA
Important Safety Instructions
Heat guns are a source of extremely high-temperature flameless heat (up to 1300˚F / 704˚C). Extreme
caution should be observed when using these
products. READ and FOLLOW these instructions.
230V/8A
230V/8A
When using an extension cord,
use only a 3-prong grounded cord
rated equal to or greater than the
appliance.
Connect to properly grounded outlets
only.
Use only on properly-rated electrical
circuits.
only.
Disconnect from power source during
service and when replacing parts.
If the supply cord is damaged, it must
be replaced by the manufacturer, its
service agent or similarly qualified
persons in order to avoid a hazard.
To reduce risk of fire or electric
shock, do not expose heat gun to
rain or moisture.
Store indoors.
Keep away from children and persons
with reduced physical, sensory
or mental capabilities or lack of
experience or knowledge.
Do not use near flammable materials
or where fumes, gases or dust are
present.
Do not use in presence of explosive
atmosphere.
Do not direct air stream at people
or pets.
Keep nozzle at least 1”/2.5 cm from
work surface.
Do not apply to the same place for a
long time.
Be aware that heat may be conducted
to combustible materials that are out
of sight.
Introduction
Our Master Heat Gun® and Master Varitemp® Heat Gun feature heavy-duty, industrial quality
design, with industry leading heat and airflow, that gets any job done faster.
ONE YEAR LIMITED WARRANTY
Master Heat Tools are carefully tested and inspected before being shipped from the factory. We warrant
our product to be free from defects in materials and workmanship, under normal use and service, for
one year from the date of purchase. In the event of defect in materials or workmanship we will either
repair or replace, at our option, without charge any part which in our judgement shows evidence of such
defect.
Warranty does not apply to wearable items such as attachments, motor brushes or heating elements,
which require periodic replacement, nor does it apply if the heat tool has been misused, abused,
tampered with or altered.
At the end of the warranty period, Master Appliance shall be under no further obligation, expressed or
implied. Master Appliance assumes no responsibility for, and this warranty shall not cover, any incidental
or consequential damages from any defects in products or their use.
The warranty gives you specific rights. You may also have other rights which may vary from state
to state. Warranty information is included within the Instruction Manual for each product or may be
obtained by contacting Master’s Customer Service Department.
Wear safety glasses at all times.
Use in well-ventilated area.
Use caution in confined areas.
Do not touch nozzle until cool.
Do not leave heat gun unattended
when it is switched on.
Always hold gun or place on its stand
(see below) when in use.
Recycle properly.
Place heat gun on its stand (built-in
or external) after use and allow it to
cool down before storage.
2
Introduction & Product Warranty
Master Appliance Corp.
2420 18th Street
Racine, WI 53403-2381
USA
262-633-7791
800-558-9413 (USA)
sales@masterappliance.com
www.masterappliance.com
WARNING: This product, when used for
soldering and similar applications, can expose
you to LEAD, which is known to the State of
California to cause cancer and birth defects
and other reproductive harm. For more
information go to www.P65Warnings.ca.gov
3
1600/2600 Surface Temperature Control
HG
Model
Heat
Gun Operating instruction
Heat
VT
Model
A LA SORTIE.
A LA SORTIE.
AVANT DE FERMER
AVANT DE FERMER
-CAUTION-
-CAUTION-
HIGH TEMPERATURE AT
HIGH TEMPERATURE AT
BEFORE TURNING OFF.
BEFORE TURNING OFF.
-ADVERTENCIA-
-ADVERTENCIA-
BOQUILLA. ANTES DE
BOQUILLA. ANTES DE
5
4 3 2
1
9
8
7
6
FULL HEAT
COOL
HG Model
Operating Instructions
HEAT
1) Plug heat gun into properly
rated outlet
rated outlet
2) For COOL temperature
press the switch to the center
position (I)
position (I)
3) For HEAT press the switch to
the high position (II)
COOL
4) For OFF, press switch to the
O position
OFF
OFF
4
VT Model
3) For VARIABLE HEAT press
the switch to the high position
(II). Rotate dial to desired
temperature
O position
5
Master Heat Gun®
Temperature
°F
°C
Voltage
Amps
Watts
Replacement
Element
600
900
1300
316
482
704
230
230
230
3
6
9
690
1380
2070
30088
30086
30084
Model
HG-202D/T
HG-302D/T
HG-502D/T
Features and Specifications
Master Heat Gun®
Temperature
Model
HG-202D/T
HG-302D/T
HG-502D/T
°F
°C
Voltage
Amps
Watts
Replacement
Element
600
900
1300
316
482
704
230
230
230
3
6
9
690
1380
2070
30088
30086
30084
Temperature
Model
VT-752D
°F
°C
Voltage
Amps
Watts
Replacement
Element
1300
706
230
9
2070
30084
51542
Glass
Protector
Voltage
A-160-HG
A-170-HG
Shrink
Tube
Amps
51543
Spreader
Watts
51544
Replacement
7/8 Reducer
Element
230
9
2070
30084
30202
51309
Temperature
Solder
Pinpoint
Preform
Model
°F
°C
Model
VT-752D
1300
706
HG-202D/T
HG-302D/T
HG-502D/T
VT-752D
Master Heat Gun® Replacement Parts (HG/VT Models)
Item No.
1
2
2
3
4
4
5
6
7
7
8
8
8
9
10
11
12
13
14
Part No.
35153
30071
30072
30074
30075
30076
30077
30078
30097
30098
30084
30086
30088
30089
30091
30092
30094
30095
30096
Description
Blower wheel
Stand kit (D Models)
Stand kit (T Models)
Motor 220-240V
Switch Bezel Kit (3 pos)
Switch Bezel Kit (MC)
Nozzle Shield Kit
Grille Kit
Cordset Kit 220-240V EU -03
Cordset Kit 220-240V UK -04
Element Kit, HG-502D/ VT-752D (230V)
Element Kit, HG-302D (230V)
Element Kit, HG-202D (230V)
Element Connector
Handle Kit VT-752D (230V)
VT- Knob Kit
Circuit Board Kit VT-752D (230V)
Housing Plastic (T Models)
Grounding Kit (T Models)
12
2
10
14
REPAIR AND MAINTENANCE INSTRUCTIONS
All repairs and maintenance recommended in this instruction manual must be performed by
a qualified repair technician who is experienced with the repair of electric tools, a qualified
service organization, or Master Appliance Corp.’s Repair Department.
Please contact Master’s Customer Service Department for genuine Master Appliance
replacement parts or for repair service.
262-633-7791
8
11
9
13
1
5
6
LD
E.
RTI À ‘CO
SO
A
C
DU
BE
R
ER
ME
ÉR
FER IONAT
RE
UT
-CA RATU LD’
PE
‘CO
ON OFF.
H TEMRUN
ING
E.
RN
ZZL
IA- LA
NO RE TU
NC EN
FO
RTE RA DE
BE
VE TU
LA
OP
T DE
AN
AV
HIG
TA.
IEN
-AD PERAANTES
AM
RR
TEMILLA.
HE
A
LA
ALTBOQU
R
GA
APA
4
7
3
WARNING: Always unplug your tool before performing any maintenance or repairs.
Use only identical Master Appliance brand replacement parts.
6
7
2420 18th St.
USA
2420 18th St.
USA
Phone: 262-633-7791
Fax 262-633-9745
P/N 58356 REV A
很抱歉,暂时无法提供与“HG-202D-04”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 3+2079.730163+269.06861
