AN_GPS_A002
AN_GPS_A002
    MASWELL(迈斯维)
    1.585GHz GPS 模块 RF 天线 1.561GHz ~ 1.610GHz 2dBic SMA 公头 磁性
AN_GPS_A002 数据手册
GPS Active Antenna AN_GPS_A002 Mechanical Dimension Suzhou maswell communication technology co. Ltd Add:Floor 3, Building 6, No. 88 Zhenbei Road, High-tech District, Suzhou 215153, Jiangsu, China Http ://www.maswelltech.com E-mail:Sales@maswelltech.com GPS Active Antenna Specifications Item Antenna LNA Mechanical Environmental Specifications Center Frequency 1561.098~1610MHz Band Width CF±5MHz Polarization RHCP Gain 2dBic(Zenith) V.S.W.R <1.5 Impendance 50Ω Axial Ratio 3dB(max) Dimension 25*25*4mm Gain 28±2dB Noise Figure <1.5 Filter Insertion Loss <3dB Ex-band Attenuation 12dB@CF+50MHz/16dB@CF-50MHz Supply Voltage 2.2~5V DC Current Consumption 5~15mA V.S.W.R <2.0 Cable RG174 Connector SMA/MCX/FAKRA or others Radome Material ABS Mounting Method Magnet/Adhesive Operating Temperature -40℃~+85℃ Relative Humidity Up to 95% Ingress Protection IP65~IP67 Vibration 10 to 55Hz with 1.5mm amplitude 2hours Environmentally Friendly ROHS Compliant Suzhou maswell communication technology co. Ltd Add:Floor 3, Building 6, No. 88 Zhenbei Road, High-tech District, Suzhou 215153, Jiangsu, China Http ://www.maswelltech.com E-mail:Sales@maswelltech.com GPS Active Antenna Radiation Patterns Suzhou maswell communication technology co. Ltd Add:Floor 3, Building 6, No. 88 Zhenbei Road, High-tech District, Suzhou 215153, Jiangsu, China Http ://www.maswelltech.com E-mail:Sales@maswelltech.com
AN_GPS_A002 价格&库存
很抱歉,暂时无法提供与“AN_GPS_A002”相匹配的价格&库存,您可以联系我们找货
AN_GPS_A002
  • 1+187.451481+24.32778
  • 10+149.7279110+19.43195
  • 25+140.2995225+18.20832
  • 100+129.93707100+16.86346
  • 250+124.99620250+16.22223
  • 500+122.01977500+15.83594
库存:30
