AN_GPS_A003 FAKRA
AN_GPS_A003 FAKRA
    MASWELL(迈斯维)
    1.575GHz GPS 模块 RF 天线 1.574GHz ~ 1.576GHz 2dBic SMA 公头 螺钉安装
AN_GPS_A003 FAKRA 数据手册
GPS Active antenna cylinder screw mount AN_GPS_A003 Mechanical Dimension Suzhou maswell communication technology co. Ltd Add:Floor 3, Building 6, No. 88 Zhenbei Road, High-tech District, Suzhou 215153, Jiangsu, China Http ://www.maswelltech.com E-mail:Sales@maswelltech.com GPS Active antenna Specifications Item Antenna LNA Mechanical Environmental Specifications Center Frequency 1575.42±3MHz Band Width CF±5MHz Polarization RHCP Gain 2dBic(Zenith) V.S.W.R <1.5 Impendance 50Ω Axial Ratio 3dB(max) Dimension Φ46.6*14.5mm Gain 28±2dB Noise Figure <1.5dB Filter Insertion Loss <3dB Ex-band Attenuation 12dB@CF+50MHz/16dB@CF-50MHz Supply Voltage 2.2~5V DC Current Consumption <15mA V.S.W.R <2.0 Cable RG174 Connector FAKRA Radome Material ABS Mounting Method Screw Operating Temperature -40℃~+85℃ Relative Humidity Up to 95% Ingress Protection IP65~IP67 (exclude cable outlet) Vibration 10 to 55Hz with 1.5mm amplitude 2hours Environmentally Friendly ROHS Compliant Suzhou maswell communication technology co. Ltd Add:Floor 3, Building 6, No. 88 Zhenbei Road, High-tech District, Suzhou 215153, Jiangsu, China Http ://www.maswelltech.com E-mail:Sales@maswelltech.com GPS Active antenna Radiation Patterns Suzhou maswell communication technology co. Ltd Add:Floor 3, Building 6, No. 88 Zhenbei Road, High-tech District, Suzhou 215153, Jiangsu, China Http ://www.maswelltech.com E-mail:Sales@maswelltech.com
AN_GPS_A003 FAKRA 价格&库存
很抱歉,暂时无法提供与“AN_GPS_A003 FAKRA”相匹配的价格&库存,您可以联系我们找货
AN_GPS_A003 FAKRA
  • 1+160.097321+20.77771
