AN_GPS_GSM_062
AN_GPS_GSM_062
    MASWELL(迈斯维)
    830MHz,1.575GHz,1.94GHz 4G,GPS,GSM,LTE 圆顶 RF 天线 700MHz ~ 960MHz,1.574GHz ~ 1.576GHz,1.71GHz ~ 2.17GH...
AN_GPS_GSM_062 数据手册
LTE version (including 700MHz band) GSM +GPS Combination Antenna screw mount AN_GPS_GSM_062 Mechanical dimension Add:Floor 3, Building 6, No. 88 Zhenbei Road, High-tech District, Suzhou 215153, Jiangsu, China Http ://www.maswelltech.com E-mail:Sales@maswelltech.com LTE version (including 700MHz band) GSM +GPS Combination Antenna screw mount Specifications Item GPS Antenna Specifications Dielectric Center Frequency Antenna Band Width LNA GSM Antenna Mechanical Environmental 1575.42±3MHz CF±5MHz Polarization RHCP Gain 2dBic(Zenith) V.S.W.R <1.5 Impendance 50Ω Axial Ratio 3dB(max) Gain 28±2dB Noise Figure <1.5 Ex-band Attenuation V.S.W.R 12dB@CF+50MHz/16dB@CF50MHz <2.0 Supply Voltage 2.2~5V DC Current Consumption 5~15mA Frequency Range 698~960MHz/1710~2690MHz V.S.W.R <2.0 Polarization Linear Gain 2.0dBi Impendance 50Ω Cable RG174 Connector SMA / MCX / FAKRA或其它 Material ABS Mounting Method Screw Operating Temperature -40℃~+85℃ Relative Humidity Up to 95% Ingress Protection Vibration IP67 (exclude cable outlet) 10 to 55Hz with 1.5mm amplitude 2hours Environmentally Friendly ROHS Compliant Add:Floor 3, Building 6, No. 88 Zhenbei Road, High-tech District, Suzhou 215153, Jiangsu, China Http ://www.maswelltech.com E-mail:Sales@maswelltech.com LTE version (including 700MHz band) GSM +GPS Combination Antenna screw mount Radiation Patterns GPS Antenna Add:Floor 3, Building 6, No. 88 Zhenbei Road, High-tech District, Suzhou 215153, Jiangsu, China Http ://www.maswelltech.com E-mail:Sales@maswelltech.com LTE version (including 700MHz band) GSM +GPS Combination Antenna screw mount Radiation Patterns GSM Antenna Add:Floor 3, Building 6, No. 88 Zhenbei Road, High-tech District, Suzhou 215153, Jiangsu, China Http ://www.maswelltech.com E-mail:Sales@maswelltech.com
AN_GPS_GSM_062 价格&库存
很抱歉,暂时无法提供与“AN_GPS_GSM_062”相匹配的价格&库存,您可以联系我们找货
