BB-SD-350B-12
BB-SD-350B-12
    B+BSMARTWORX
    DC/DC CONVERTER 12V
BB-SD-350B-12 数据手册
SD-350 350W Single Output DC-DC Converter series ■ ‧ ‧ ‧ ‧ ‧ ‧ ‧   SPECIFICATION MODEL OUTPUT INPUT PROTECTION SD-350B 5V 12V 24V 48V 5V 12V 24V 48V RATED CURRENT 57A 27.5A 14.6A 7.3A 60A 27.5A 14.6A 7.3A CURRENT RANGE 0 ~ 57A 0 ~ 27.5A 0 ~ 14.6A 0 ~ 7.3A 0 ~ 60A 0 ~ 27.5A 0 ~ 14.6A 0 ~ 7.3A RATED POWER 285W 330W 350.4W 350.4W 300W 330W 350.4W 350.4W RIPPLE & NOISE (max.) Note.2 100mVp-p 120mVp-p 150mVp-p 200mVp-p 100mVp-p 120mVp-p 150mVp-p 200mVp-p VOLTAGE ADJ. RANGE 11 ~ 16VDC 23 ~ 30VDC 43 ~ 53VDC 4.5 ~ 5.5VDC 11 ~ 16VDC 23 ~ 30VDC 43 ~ 53VDC VOLTAGE TOLERANCE Note.3 ±2.0% ±1.0% ±1.0% ±1.0% ±2.0% ±1.0% ±1.0% ±1.0% LINE REGULATION ±0.5% ±0.3% ±0.2% ±0.2% ±0.5% ±0.3% ±0.2% ±0.2% LOAD REGULATION ±1.0% ±1.0% ±1.0% ±1.0% ±1.0% ±1.0% ±1.0% ±1.0% SETUP, RISE TIME 300ms, 50ms at full load VOLTAGE RANGE B:19 ~ 36VDC EFFICIENCY (Typ.) 74% 80% 80% 84% 76% 81% 81% 82% DC CURRENT (Typ.) INRUSH CURRENT (Typ.) 14.4A/24V 16A/24V 17.6A/24V 17.6A/24V 7.6A/48V 8.8A/48V 9.0A/48V 9.0A/48V 5.75 ~ 6.75V 16.8 ~ 20V 31.5 ~ 37.5V 53 ~ 65V C:45A/48VDC D:72 ~144VDC D:45A/96VDC OVER VOLTAGE 5.75 ~ 6.75V 16.8 ~ 20V 31.5 ~ 37.5V 53 ~ 65V Protection type : Shut down o/p voltage, re-power on to recover WORKING HUMIDITY ENVIRONMENT STORAGE TEMP., HUMIDITY TEMP. COEFFICIENT VIBRATION SAFETY STANDARDS SAFETY & WITHSTAND VOLTAGE ISOLATION RESISTANCE EMC EMC EMISSION EMC IMMUNITY MTBF DIMENSION PACKING NOTE C:36 ~ 72VDC 105 ~ 135% rated output power Protection type : Shut down o/p voltage, re-power on to recover WORKING TEMP. OTHERS 4.5 ~ 5.5VDC OVERLOAD OVER TEMPERATURE (Note 4) SD-350C DC VOLTAGE Shut down o/p voltage, recovers automatically after temperature goes down -20 ~ +60℃ (Refer to "Derating Curve") 20 ~ 90% RH non-condensing -40 ~ +85℃, 10 ~ 95% RH ±0.03%/℃ (0 ~ 50℃) 10 ~ 500Hz, 2G 10min./1cycle, 60min. each along X, Y, Z axes IEC60950-1 CB approved by TUV (for D type only), EAC TP TC 004 approved I/P-O/P:1.5KVAC I/P-FG:2KVAC O/P-FG:0.5KVAC I/P-O/P, I/P-FG, O/P-FG:100M Ohms / 500VDC / 25℃/ 70% RH Compliance to EN55032 (CISPR32) Class B, EAC TP TC 020 Compliance to EN61000-4-2,3,4,6,8, light industry level, criteria A, EAC TP TC 020 209.4K hrs min. MIL-HDBK-217F (25℃) 215*115*50mm (L*W*H) 1.1Kg; 12pcs/14.4Kg/0.92CUFT ℃      ℃℃ File Name:SD-350-SPEC 2018-01-12 SD-350 350W Single Output DC-DC Converter series ■ ‧ ‧ ‧ ‧ ‧ ‧ ‧   SPECIFICATION MODEL OUTPUT INPUT SD-350D DC VOLTAGE 5V 12V 24V 48V RATED CURRENT 60A 29.2A 14.6A 7.3A CURRENT RANGE 0 ~ 60A 0 ~ 29.2A 0 ~ 14.6A 0 ~ 7.3A RATED POWER 300W 350.4W 350.4W 350.4W RIPPLE & NOISE (max.) Note.2 100mVp-p 120mVp-p 150mVp-p 200mVp-p VOLTAGE ADJ. RANGE 11 ~ 16VDC 23 ~ 30VDC 43 ~ 53VDC VOLTAGE TOLERANCE Note.3 ±2.0% ±1.0% ±1.0% ±1.0% LINE REGULATION ±0.5% ±0.3% ±0.2% ±0.2% LOAD REGULATION ±1.0% ±1.0% ±1.0% ±1.0% SETUP, RISE TIME 300ms, 50ms at full load VOLTAGE RANGE B:19 ~ 36VDC EFFICIENCY (Typ.) 78% 83% 87% 89% DC CURRENT (Typ.) 6A/96V 6A/96V 6A/96V 6A/96V INRUSH CURRENT (Typ.) C:45A/48VDC 31.5 ~ 37.5V 53 ~ 65V 4.5 ~ 5.5VDC C:36 ~ 72VDC D:72 ~144VDC D:45A/96VDC 105 ~ 135% rated output power OVERLOAD PROTECTION OVER VOLTAGE OVER TEMPERATURE WORKING TEMP. WORKING HUMIDITY ENVIRONMENT STORAGE TEMP., HUMIDITY TEMP. COEFFICIENT VIBRATION SAFETY STANDARDS SAFETY & WITHSTAND VOLTAGE ISOLATION RESISTANCE EMC (Note 4) EMC EMISSION OTHERS NOTE Protection type : Shut down o/p voltage, re-power on to recover 5.75 ~ 6.75V 16.8 ~ 20V Protection type : Shut down o/p voltage, re-power on to recover Shut down o/p voltage, recovers automatically after temperature goes down -20 ~ +60℃ (Refer to "Derating Curve") 20 ~ 90% RH non-condensing -40 ~ +85℃, 10 ~ 95% RH ±0.03%/℃ (0 ~ 50℃) 10 ~ 500Hz, 2G 10min./1cycle, 60min. each along X, Y, Z axes IEC60950-1 CB approved by TUV (for D type only), EAC TP TC 004 approved I/P-O/P:1.5KVAC I/P-FG:2KVAC O/P-FG:0.5KVAC I/P-O/P, I/P-FG, O/P-FG:100M Ohms / 500VDC / 25℃/ 70% RH Compliance to EN55022 (CISPR22) Class B, EAC TP TC 020 EMC IMMUNITY Compliance to EN61000-4-2,3,4,6,8, light industry level, criteria A, EAC TP TC 020 MTBF 209.4K hrs min. DIMENSION PACKING 215*115*50mm (L*W*H) 1.1Kg; 12pcs/14.4Kg/0.92CUFT MIL-HDBK-217F (25℃) ℃      ℃℃ File Name:SD-350-SPEC 2018-01-12 SD-350 350W Single Output DC-DC Converter Mechanical Specification Case No. 912B series Unit:mm 117.5 32.5 150 177.5 27.5 19 95 50 4-M4 L=5mm 32.5 6-M3 L=3mm 37.5 50.5 47.5 16 10 9.5 8.3 135 9 8 7 6 5 4 3 2 1 115 36.7 LED +V ADJ. 15 215 32.5 150 Terminal Pin No. Assignment : Air flow direction 50 25 CL 13max. Pin No. 1 2 3 Assignment DC INPUT V+ DC INPUT VFG Pin No. Assignment 4,5,6 DC OUTPUT V7,8,9 DC OUTPUT V+ 6-M4 L=6mm Block Diagram fosc : 100KHz RECTIFIERS & FILTER EMI FILTER I/P FILTER RECTIFIERS & FILTER POWER SWITCHING +V -V (ONLY D SERIES) FAN FG O.V.P. O.L.P. O.T.P. Derating Curve DETECTION CIRCUIT PWM CONTROL Static Characteristics 100 others 100 90 80 80 SD-350B,C,D-5 70 LOAD (%) LOAD (%) 60 40 20 -20 60 50 40 0 10 20 30 40 50 AMBIENT TEMPERATURE (℃) 60 (HORIZONTAL) B:19 C:36 D:72 24 48 96 36 72 144 INPUT VOLTAGE (V) File Name:SD-350-SPEC 2018-01-12
BB-SD-350B-12
1. 物料型号:型号为EL817,是一款光耦器件。 2. 器件简介:EL817是一款高性能光耦器件,具有高速响应和高隔离电压特性。 3. 引脚分配:EL817共有6个引脚,其中1脚为发光二极管阳极,2脚为发光二极管阴极,3脚为输出晶体管集电极,4脚为输出晶体管发射极,5脚为输出晶体管基极,6脚为Vcc。 4. 参数特性:EL817的主要参数包括最大正向电流100mA,最小正向电压1.2V,最大反向电压5V等。 5. 功能详解:EL817通过光电效应实现电信号隔离,发光二极管和光敏晶体管之间通过光信号传输,实现电信号的隔离传输。 6. 应用信息:EL817广泛应用于通信、工业控制、医疗设备等领域,用于实现信号隔离和电平转换。 7. 封装信息:EL817采用DIP-6封装,尺寸为9.1mm x 3.6mm x 4.9mm。
BB-SD-350B-12 价格&库存
很抱歉,暂时无法提供与“BB-SD-350B-12”相匹配的价格&库存,您可以联系我们找货
