1WA53
1WA53
    APEM(埃斐)
    椭圆形,凸起(圆顶) 触动式 开关盖帽 灰色,浅色 卡入式
1WA53 数据手册
PANEL PCB SWITCHES 1WA/1WD M Ellipse-shaped caps • different top surfaces • two sizes DISTINCTIVE FEATURES 1WA : 6.5 x 12.5 mm 1WD - 8.0 x 15.2 mm 1WA/1WD : h=14.9 mm; convex top surface SWITCH SPECIFICATIONS : see Multimec™ 3F series. 14.9 3F+1WA - SMD 14.9 14.9 3F+1WD - TH W/LED 14.9 W -1 EC D 1W A/ 8 00 -2 The company reserves the right to change specifications without notice. All tolerance if not otherwise specified ±0.2mm. 1 PCB SWITCHES 1WA/1WD Ellipse-shaped caps • different top surfaces • two sizes BUILD YOUR PART NUMBER ILLUMINATED 3F MOUNTING SERIES TH9 through-hole LED CAP 05 blue 1WA 20 green 1WD 40 yellow 65 white 80 red 2040 green/yellow 8020 red/green 8040 red/yellow COLOR 16 frosted white NON-ILLUMINATED 3F MOUNTING SERIES CAP COLOR TH9 through-hole 1WA 03 grey SH9 surface mount 1WD 09 black NOTICE : Other versions : Please refer to www.apem.com for information on the 5G series versions - 1WAS/1WDS/1WPS MOUNTING • Panel cut-out : 1WA : min. 12.9 x 6.9 mm 1WD : min. 15.6 x 8.4 mm • Switch spacing AxB : 1WA : min. 14.2 x 10.3 mm 1WD : min. 16.9 x 10.3 mm • 8 mounting position options : 8 different position options 2 MATERIALS • Cap : - solid color : ABS UL94HB - illuminated : polycarbonate UL94HB Available for Multimec caps STANDARD LEGENDS STANDARD LEGENDS LEGEND 1D09_ 1F096R_ 0 000 000 1 001 001 2 002 002 3 003 003 4 004 004 5 005 005 6 006 006 7 007 007 8 008 008 9 009 009 # 107 107 019 019 1ZB09D_ 1ZB16DLMH_ 1ZC_ 1Z_ 1ZW_ 10R_ & 10RF_ 10RM16_ 10Q_ 10QM16_ 054 054 054 059 059 059 10A_ 10C_ 033 133 034 134 135 135 + 136 123 123 136 123* 136 123 123 ON/OFF 123 123 017 017 STOP 018 018 031 031 038 038 CANCEL 048 048 ENTER 105 105 118 118 START RESET ESC 038 051 ON 116 OFF 117 OK 118* SET 119 MENU 120 FUNC 121 HOME 122 118 118 STANDARD OPTIONS • 1D: pad printed • 10A: pad printed / laser marked • 1F: reverse printed • 10C: pad printed / laser marked • 1ZB: pad printed / laser marked • 10R(F) & 10Q: pad printed / reverse printed • 1ZC: pad printed *reverse printed *laser marked • 10RM & 10QM: metal symbol • 1Z & 1ZW: pad printed / laser marked 1 PANEL PCB SWITCHES Legends PCB SWITCHES Legends Available for Multimec caps HOW TO ORDER POSITIONING OF LEGENDS ON ROCKER-ACTION CAPS LEGEND ILLUMINATION • Option 1 - laser marked: In case of laser marked legends an “LM” is added after the cap colour, before the legend code. We recommend using hard paint (additional “H” ) for increased lifetime of the paint. E.g. 1ZB16DLMH13609 When ordering legends for caps with hinge-type cap retention system, it is important to note the position of the cap. An extra letter (U, D, R or L) needs to be added to the part number to refer to the position of the hinges in relation to the legend. See samples: • Option 2 - reverse printed: In case of reverse printed caps an “R” is added after the cap colour, before the legend code. Especially relevant when standard legends have both negative and positive print options. E.g. 1FS096R00009 Rocker-action caps without a lens: 1A, 1B, 1M, 1ZA and 1ZB ON/OFF UP 1A09U01706 ON/OFF RIGHT 1ZB16RLMH11809 OK ON/OFF • Option 3 - metal symbol: Only available ON/OFF for 10RM andON/OFF 10QM ON/OFF(therefore the “M”). E.g. ON/OFF 10RM16059 ON/OFF ON/OFF ON/OFF ON/OFF 3 1 + ON/OFF - 4 DOWN 2 1B09D01706 2 4 1 + ORIENTATION OF THE SWITCH LEFT 1ZB09L00106 1 3 3 1 1 + ON/OFF ON/OFF + 3 4 + - 1 2 2 4 - 2 UP 4 -2 1 1 + 4 3 + 3 DOWN STANDARD AND CUSTOM LEGENDS 3 • Standard are only certain legends on certain caps. See the table on the previous page. • All standard pad-printed legends are white on black caps. • All standard reverse-printed and laser marked legends are black on frosted white cap. STANDARD LEGENDS CAP CAP COLOR DIRECTION* TYPE* LEGEND LEGEND COLOR* 1D 00 Blue D Down UV UV printed 001 1 00 Blue 1F 02 Green U Up 2 03 Grey ... Grey R Right Laser marked on soft paint 002 03 LM 3 06 White Yellow L Left Laser marked on hard paint 003 04 LMH etc 08 Red 06 White 09 Black 08 Red MC 09 Black Multi color 16 Frosted white ... Etc *Only for hingetype caps R Reverse printed *In case of illumination ... ... Etc *In case of reverse printed and laser marked legends the colour of the paint Notice: The size of the legends listed may not correspond to the actual size. If you decide to use one of the standard legends without any adjustments (without a new cliché or programming) on another cap than designated in the table, then there is no cliché or programming cost, for this to apply the cap has to be black and the print white. For further information on legends please contact APEM. 2 • • • • • • • 1B • • • • • • • 1D • • • • • • • • 1E/1F 36 38 40 42 50 53 57 58 • • • • • • • • • 1GA/1GC • 1H 1K Metal bordeaux / No ral code 1A Metal dark grey / No ral code 08 Metal light grey / No ral code 06 Metal dark blue / No ral code Melon / 1028 04 Aqua blue / 5021 Tele grey / 7046 • 03 Dusty blue / 5014 Mint green / 6029 • 02 CODE Noble red / 3002 Ultra blue / 5002 • 00 CAP Signal white / 9003 Black / 9004 • Red / 3000 34 White / 9010 33 Yellow / 1023 32 Grey / 7004 30 green / 6018 09 Blue / 5012 Colour / RAL Code Available for Multimec caps • 1M • • • • • • • • • • • • 1N 1P • 1Q • • • • • • • • • • • 1R 1S • 1T/1U/1V • • • • • • • • • • 1WA/ 1WD • 1X • • • 1ZA • • • • • • • • • • 1ZB • • • • • • • • • • 1ZC • • • • • • • • • • • 10A • • • AQC • • The RAL Codes mentioned are the codes nearest to the solid colors in the multimec™ range. *3E actuators and Varimec use different materials and therefor have a different color code and are not represented in this table 3 PANEL PCB SWITCHES Solid colors PCB SWITCHES Cap & Bezel Specifications Multimec™ caps ACCERSSORY SPECIFICATIONS 4 MATERIAL PARTS TEMP. LIMIT UL RATING ABS Solid color 1A, 1B, 1D, 1E, 1F, 1H, 1K, 1M, 1N, 1P, 1Q, 1R, 1T, 1U, 1V, 1WA, 1WD, 1X, 1ZA, 1ZB, 1ZC and AQC Bezels 2C, 2D and 2K, reflectors for 1KB, 1KC, 1Y and 1YA Max 65 °C Max 149 °F UL94HB Polycarbonate All lenses and transparent colour caps, lids for 1KB & 1KC Max 85 °C Max 185 °F UL94HB Polyamide 1GA, 1GC, 1S and 2S Max 160 °C Max 320 °F UL94V2 Legends adhesion DS/EN ISO 2409 Class 1 & ASTM D3359 Class 4B 03 EC M U -M M EC I LT PANEL PCB SWITCHES 22 3F Multimec™ 3F High performance tactile switches • robust DISTINCTIVE FEATURES 10 x 10 mm; h=10.4 mm Illuminated RAS option Slip-on cap retention system - great for custom caps ENVIRONMENTAL SPECIFICATIONS • Sealing : IP67 according to IEC 60529 • Working and storage temperature : - non-illuminated : -40 °C/+160 °C (-40 °F to +320 °F) - illuminated : -40 °C /+85 °C (-40 °F to +185 °F) • Soldering : - through-hole : IEC 60068-2-20 8 - surface mount : JEDEC J-STD-020E ELECTRICAL SPECIFICATIONS • Recommended load : - Gold contacts : 0.5µ-50 mA 24 VDC - Silver contacts : 0.5-50 mA 24 VDC • Contact resistance : 10 MΩ • Contact bounce : 10,000,000 cycles • Terminals : SnCu + 2 µNI + 3 µSn100 The company reserves the right to change specifications without notice. All tolerance if not otherwise specified ±0.2 mm. • Max. actuation force : 100 N for 10 sec 1 6,4 10,4 High performance tactile switches • robust 3F - SMD 14 Ø 6,5 10 6,4 10,4 10 7,62 14 0,8 Ø 6,5 6,4 10,4 0,8 7,62 3F - TH Min 10,16 Max 12,5 0,3 Ø 6,5 10 6,4 10,4 10 0,8 0,3 Min 10,16 Max 12,5 7,62 Ø 6,5 0,8 7,62 3F - TH W/LED 10 10 2,54 2,54 3F - RAS 10 7,62 12 5,08 7,62 2 10 7,62 12 PCB SWITCHES Multimec™ 3F 5,08 7,62 PANEL PCB SWITCHES Multimec™ 3F 5,5 6,0 10 12 High performance tactile switches • robust 5,08 2,54 3F - RAS W/LED 7,62 20,1 6,0 10 12 ±0,3 17,8 5,5 7,62 5,08 2,54 2,54 7,62 20,1 ±0,3 17,8 PCB LAYOUT & CIRCUIT DIAGRAM 7,62 2,54 4 2,5 Ø1,0(3x) 3 Ø1,0(3x) 2,54 1 3 Ø1,0(3x) 2,54 7,62 7,62 5,08 Ø1,0(4x) 7,62 5,08 7,62 3 +3 2,5 5,08 + Ø1,0(4x) 7,62 7,62 5,08 7,62 2,54 ø1.0 (4X) RAS bi-color illuminated 7,62 2,54 ø1.0 (4X) 3 2,54 4 7,62 Ø1,0(4x) 3 +3 5,08 7,62 2,54 1 5,08 7,62 3 1,2 3 3 +34 2,5 2,54 Ø 0,9 7,62 [0,300] 4 2,54 [0,100] 4 + 7,62 1 - 7,62 1 1 1 7,62 3 12,50 -2 1 - 5,08 1,2 2,5 1 -2 RAS illuminated 7,62 10,16 2 7,62 2 10,16 [0,400] 2,54 2,54 [0,100] 1 Ø 0,9 RAS TH bi-color illuminated 0 44 33 2,5 Ø 0,9 12,50 10,16 [0,400] 7,62 2 2,54 4 1 7,62 [0,300] 4 3 1 7,62 3 2,5 Ø 0,9 -22 11 2,54 44 3 Ø 0,9 10,16 12,50 2 1,2 7,62 1,2 4 2 7,62 7,62 1 1,2 1 7,62 7,62 7,62 22 2,54 [0,100] 10,16 12,50 10,16 12,50 1 7,62 10,16 2 TH illuminated 1,2 2,54 [0,100] SMD non-ill. 5,08 TH Non-ill. PCB SWITCHES Multimec™ 3F High performance tactile switches • robust BUILD YOUR PART NUMBER ILLUMINATED 3F MOUNTING SERIES TH9 LED through-hole OPTIONAL 06 blue Q quiet contact 20 green G gold contacts 40 yellow RAS 65 white 80 red 2040 green/yellow 8020 red/green 8040 red/yellow 24 high intensity green 46 high intensity yellow 87 high intensity red right angle NON-ILLUMINATED 3F MOUNTING SERIES TH9 through-hole SH9 surface mount OPTIONAL Q quiet contact RAS right angle (with TH only) R tape & reel (with SMD only) G gold contacts ABOUT THIS SERIES Caps and accessories : for the full range of accessories for Multimec™ 3F please see the website. 4 High performance tactile switches • robust OPERATING FORCE TAPE & REEL Tape and reel is available for the parts listed and has the following specifications FORCE 10 • Reel diameter: Ø330 mm 9 • Tape width: 24 mm • Pitch: see list 8 • Tape and reel material: antistatic or better • Quantity per reel: see list 7 ORDERING CODE PITCH QUANTITY PER REEL 3FSH9 3FSH9R 20 250 6 F(N) PART NO. 5 3,5N 3.5 N 4 3 2 1 TRAVEL 0 0 0,2 0,4 0,6 0,8 1 L(mm) 1,2 1,4 1,6 1,8 2 MOUNTING MOUNTING TOOLS FOR MULTIMEC™ THROUGH-HOLE SWITCHES Part No. 9861000 1 2 3 4 5 5 PANEL PCB SWITCHES Multimec™ 3F PCB SWITCHES Multimec™ 3F High performance tactile switches • robust MOUNTING (CONTINUED) SPACE REQUIREMENT - MATRIX MOUNTING Through-hole (TH) Surface mount (SMD) MULTIMEC™ SPACING EXAMPLES 13.6 13.6 12.7 12.7 1V+1T+1V 1N+1N+1N SPACE REQUIREMENT - SWITCH/CAP Cap dimensions Switch spacing Panel cut-out 6 CAP SERIES RECOMMENDED MIN.SWITCH SPACING AxB NOMINAL CAP DIMENSION WxH RECOMMENDED MIN. PANEL CUT-CUT 1D/1E/1F 1GA 12.7x11.3 Ø9.6 Ø10.0 12.7x11.3 Ø11.0 Ø11.4 1GC 15.3x15.3 Ø15.0 Ø15.4 1K/1KB/1KC 14.6x14.6 14.3x14.3 14.7x14.7 1N 13.6x11.3 Ø9.8/ 14.9 Ø10.2/15.1 1P/ 1Q/1R 12.8x10.3 6.5x12.5 7.0x13.0, R max. 1.0 1S 12.7x10.3 Ø6.5 Ø7.0 1T 12.7x12.3 10.6x10.6 11.0x11.0 1U 12.7x12.3 Ø10.6 Ø11.0 1V 15.95x12.1 10.6x13.25 11.0x13.65 1WA 14.2x10.3 12.5x6.5 12.9x6.9 1WD 16.9X10.3 15.2x8.0 15.6x8.4 1X 12.7x10.3 9.4x7.4 9.8x7.9 1ZC 14.6x14.6 Ø14.3 Ø14.7 High performance tactile switches • robust LED COMPONENT SPECIFICATIONS LED COMPONENT SPECIFICATIONS Color B G Y W R G/Y R/G R/Y G Y R Color Codes 06 20 40 65 80 2040 8020 8040 24 46 87 120 120 60 110 100 100/60 100/100 75/75 60 60 60 ABSOLUTE MAXIMUM RATINGS (Ta=25°C) Power mW Current forward mA 30 30 20 30 30 30/20 30/30 30/30 25 25 25 Forward peak current mA 150 90** 80** 100 90** 120/80 120/120 160/140 60 60 60 Voltage reverse V 5 3 5 5 3 5 5 5 5 5 5 Operating temperature °C -40/+85 -55/+100 -40/+85 -55/+100 -55/+100 -55/+100 -40/+85 -40/+85 -40/+85 -40/+85 Storage temperature °C -40/+85 -55/+100 -40/+100 -55/+100 -55/+100 -55/+100 -40/+85 -40/+100 -40/+100 -40/+100 Soldering temperature °C 260 for max 3 sec 260 for max 2 sec 260 for max 5 sec ELECTRICAL-OPTICAL CHARACTERISTICS (Ta=25°C) Voltage forward Typ. V 3.3 2.1 2.1 3.0 2.0 2.1/2.1 2.0/2.1 2/2.1 2.0* 2.0 2.0*** Max. V 4.0 2.6 2.6 4.0 2.6 2.6/2.4 2.6/2.6 2.5/2.5 2.4* 2.4 2.4*** Current reverse (VR=5V) µA Max. 50 100 100 100 100 100 100 2 10 10 10 Wave length nm 460 569 588 NA 625 565 621/569 617/588 573 589 624 25 40 35 NA 40 30/35 40/30 45/35 20 NA 20 Spread angle Spread degree nm 30 60 60 25 60 80/60 200 60 100 40 40 Luminous Intensity Min. mcd 900 5.6 1.7 715 2.5 3.7/2.5 2.2/2.2 6/4 10 630 400 5.6 max 2850 8.7 12.6/8.7 4.8/4.8 14/8 20 1250 800 Typ. mcd Orientation 1600 12.6 The longer pin is the anode, the shorter is the cathode. For bi-color LEDs the anode for the first color (ex. 8020) is the longer pin. */F=20mA, **1/10 duty cycles 0.1ms pulse width, ***/F=50mA, ****Luminous Flux mlm 7 PANEL PCB SWITCHES Multimec™ 3F PCB SWITCHES Multimec™ 3F High performance tactile switches • robust USAGE GUIDELINES HOW TO GET THE BEST RESULTS WITH MEC SWITCHES ? These guidelines are offered to users of MEC Switches as an aid to ensure successful and reliable switch operation. Please see the technical specifications for details on operating and storage temperatures and soldering guidelines to make sure you select the best switch for your application. When reflow soldering is taking place, MEC strongly recommend that the temperature profile is analyzed and compared with the temperature rating of the switch. It is also important to monitor the accumulated heat buildup from both the pre-heat zones and the solder zone. Most standard accessories for multimec™ 3 series switches are made from ABS plastic with a maximum operating temperature of 65 °C. It is strongly recommended that accessories are mounted after soldering of the switch. If this is not possible care must be taken not to overheat the accessories during the soldering process. The 1S and 1GA/1GC caps are, however, made of high temperature materials and will meet the same temperature specifications as the switches. For accessories made from other plastic materials please see multimec™ 3 cap & bezel technical specifications. offers a high level of sealing, however, with aqueous solvent solutions care must be taken to avoid the worst case situation with water jets, complete immersion into a liquid with a temperature below the board or surface tension reducing additives. Recommended cleaning methods are demineralized water. Any surface tension reducing agents, such as soap, must not be used as they risk causing a potential leakage of the switch. SOLDERING - THROUGH HOLE VERSIONS Hand soldering: max. 350 °C for max. 3 sec Wave soldering: heat built up in the switch during pre-heating and soldering must not exceed the maximum operating temperature of the switch. Peak temperature must not exceed 260 °C, and soldering time is max 10 sec. (IEC 60068-2-20 8) SOLDERING - SURFACE MOUNT VERSIONS LEDs have their own temperature specifications. When fitted in a 3F switch the LED will determine the max. operating temperature, i.e. 3FTH924 has an upper temperature limit of 85 °C! For all methods - infrared, convection and vapor phase. The upper limit 240 °C/40 sec must be observed. The soldering temperature profile must have moderate temperature gradients. (JEDEC J-STD020E) MOUNTING AND DISMOUNTING ROHS COMPLIANCE If switches are to be mounted in rows it is essential that the recommendations regarding spacing are followed. PC board thickness should be 1.4 ±0.2 mm and terminal hole diameter should be 0.9 mm. As of 1 July 2006 MEC has completed the conversion to RoHS compliance. For more info please see our homepage www.apem.com All multimec™ caps and bezels are easily slid onto the switch modules and can be changed at a later time . TEMPERATURE LIMITS Care must be taken when inserting the 3FT switch and LED assembly into the PC board. Do not press direct on the LED. This will force the LED down into the actuator and risks to cause the switch contacts to remain in the closed position. To correct the fault, the LED must be raised slightly and centered in the actuator to assure unrestricted movement of the actuator. Switch LEDs Accessories A mounting tool is available for through hole multimec 3 series switches. ™ SOLDERING AND CLEANING MULTIMEC™ 3 SERIES Multimec™ 3 series switches are fully sealed to IP67 specifications to prevent solder flux and aqueous based cleaning solutions from entering the switch and contaminating the contacts. The switches can be placed on the PC board with other components and reflow soldered. Multimec™ 3 series 8 160 °C 80/85/100 °C 65/85/160 °C PACKAGING Multimec™ 3 series switches are packed in rigid tubes of 50 pieces each. A box contains 1.000 pcs. The surface mount versions of multimec™ 3 series switches with a height up to 12.5 mm can also be delivered on tape/reel. Each reel contains 250/500 pcs. Right angle swithces are packed in trays. A tray contains 100 pcs.
1WA53 价格&库存
很抱歉,暂时无法提供与“1WA53”相匹配的价格&库存,您可以联系我们找货
