1C032
1C032
    APEM(埃斐)
    矩形,凸起(圆顶) 触动式 开关盖帽 灰色,绿色透镜 卡入式
1C032 数据手册
multimec ® 3A + 1B/1C + 2A/2B Technical Data ■ ■ ■ ■ ■ ■ through-hole or SMD 50mA/24VDC single pole/momentary 10.000.000 operations life time IP67 sealing temperature range: low temp: -40/+115°C high temp: -40/+160°C Dimensions (through-hole) Dimensions w/LED in switch (1C/1H) PCB layout Dimensions w/LED PCB mounted (2B) PCB layout (top view) Dimensions (SMD) PCB layout (top view) PCB layout How to order + 3 A Switch Mounting T through-hole S surface mount 3 A + 1 B L 6 low temp. H 9 high temp. Cap 00 02 03 04 06 08 09 L 6 low temp. H 9 high temp. LED 00 blue 20 green 40 yellow 80 red + T Switch blue green grey yellow white red black Mounting T through-hole Switch Mounting T through-hole S surface mount L 6 low temp. H 9 high temp. 00 02 03 04 06 08 09 blue green grey yellow white red black For 1B and 2A only: 30 ultra blue 40 dusty blue 42 aqua blue 32 mint green 33 tele grey 34 melon 38 noble red 00 02 03 04 06 08 09 blue green grey yellow white red black + 1 B Cap 00 02 03 04 06 08 09 + 2 A Bezel Ordering example: 3ATL640 + 1C094 + 2A04 For updates of products and/or changes of specifications please see www.mec.dk 0611 | mec | www.mec.dk 00 02 03 04 06 08 09 blue green grey yellow white red black 2 B 00 02 03 04 06 08 09 blue green grey yellow white red black Lens 1 transparent 2 green 4 yellow 6 frosted white 8 red 2 B X X X LED for 2B bezel Keycaps and bezels shown on this page can also be used on illumec™ switch 4A - see page 9. Part nos. for bezels for 4A are 2C and 2D. metal dark blue metal light grey metal dark grey metal bordeaux + Bezel blue green grey yellow white red black 50 53 57 58 Lens 1 transparent 2 green 4 yellow 8 red 1 C Cap + 3 A 2 A Bezel 20 green 40 yellow 80 red
1C032
1. 物料型号:3A + 1B/1C + 2A/2B 2. 器件简介:该文档描述了一种通过孔或SMD的单极/瞬时开关,具有50mA/24VDC的额定电流和电压,寿命可达1000万次操作,密封等级为IP67,适用于低至-40°C和高达+115°C或+160°C的温度范围。 3. 引脚分配:文档中没有明确提供引脚分配的详细信息,但提到了不同的安装方式,包括通过孔和表面贴装。 4. 参数特性:包括额定电流/电压、操作寿命、密封等级、温度范围。 5. 功能详解:文档提供了不同颜色和材料的开关帽(Cap)、开关座(Bezel)、LED颜色以及透镜(Lens)的选项。 6. 应用信息:适用于需要高寿命和高密封等级的开关应用。 7. 封装信息:提供了通过孔和SMD两种封装方式的尺寸信息。
1C032 价格&库存
很抱歉,暂时无法提供与“1C032”相匹配的价格&库存,您可以联系我们找货
