3FTL68020
3FTL68020
    APEM(埃斐)
    顶部触动 触摸开关 SPST-NO 通孔
3FTL68020 数据手册
26 multimec ® 3F + 1GA/1GC Technical Data through-hole or SMD 50mA/24VDC single pole/momentary 10.000.000 operations life time IP67 sealing temperature range: low temp: -40/+115°C high temp: -40/+160°C Dimensions (w/extender) Dimensions (SMD) Height 2Sxx.x Dimensions (through-hole) PCB layout Total height (H) = 12.5+2Sxx.x ■ ■ ■ ■ ■ ■ H=17.5 18.5 19.5 20.5 21.5 22.5 PCB layout PCB layout How to order + 3 F Switch Mounting T through-hole S surface mount L 6 low temp. H 9 high temp. 1 G A 0 9 + 2 S 0 9 Extender black Cap black 1 G C 0 9 Cap black 2S09-05.0 2S09-06.0 2S09-07.0 2S09-08.0 2S09-09.0 2S09-10.0 12.5 17.5 18.5 19.5 20.5 21.5 22.5 H1 H2 A Foil H1 1GA/1GC 1GA/1GC Example H2 Variable Extender H (height) mm H3 Keycap (Optional) Adds 5-10 mm to total height. PCB H3 H = Overall height Overall heights below 12.5 mm - Please see Multimec® versions 3C and 3E. All 2S09 extenders are stackable giving the possibility to match most overall heights. A = We recommend you to allocate enough space for travel of the foil and leave the area free from adhesive. Switch travel = 1 mm. H = We recommend you to calculate this dimension from the top of the PCB to the inner top of the panel. Ordering example: 3FTL6 + 1GA09 or 3FTL6 + 2S09-07.0 + 1GC09 For updates of products and/or changes of specifications please see www.mec.dk mec | www.mec.dk . 0 Height 05.0 06.0 07.0 08.0 09.0 10.0 Panel
3FTL68020
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光耦器件,用于隔离输入和输出电路,保护电路不受外部干扰。
3. 引脚分配:EL817共有6个引脚,分别为1脚阳极,2脚阴极,3脚输出,4脚集电极,5脚发射极,6脚地。
4. 参数特性:工作电压范围为3-24V,隔离电压为2500Vrms。
5. 功能详解:EL817通过光电效应实现信号传输,具有高速响应和低功耗特点。
6. 应用信息:广泛应用于工业控制、仪器仪表等领域。
7. 封装信息:采用DIP6封装。
3FTL68020 价格&库存
很抱歉,暂时无法提供与“3FTL68020”相匹配的价格&库存,您可以联系我们找货
