4FTH942
4FTH942
    APEM(埃斐)
    顶部触动 触摸开关 SPST-NO 通孔
4FTH942 数据手册
PANEL PCB SWITCHES : n io at m r fo om in .c s m ie e er ap l s w. l fu w or w Illumec™ 4F F Illuminated switches • slip-on cap retention system • integrated chip-LEDs DISTINCTIVE FEATURES 10 x 10 mm ; h=10.4 mm Illumination with integrated chip-LEDs Single or bi-color illumination Momentary NO Simple slip-on cap retention system ENVIRONMENTAL SPECIFICATIONS • Switch sealing : IP67 according to IEC 60529 • Working and storage temperature : -30°C/+85°C • Soldering : - through-hole : IEC 68-2-20 8 - surface mount : JEDEC J-STD-020C ELECTRICAL SPECIFICATIONS • Recommended load : - Gold contacts : 0.5µ-50mA 24VDC - Silver contacts : 0.5-50mA 24VDC • Contact resistance : 10MΩ • Contact bounce : 10,000,000 cycles • Terminals : SnCu + 2µNI + 3µSn100 The company reserves the right to change specifications without notice. All tolerance if not otherwise specified ±0.2mm. • Max. actuation force : 100N for 10 sec 369 PCB SWITCHES Illumec™ 4F Illuminated switches • slip-on cap retention system • integrated chip-LEDs 4FSH9XX To p TVoiepwV ie w To pTVoipe w V ie w • SMD • NO • Single or bi-color LEDs 4FTH9XX To pToVpieVwie w To p ToVpieVwie w • TH • NO • Single or bi-color LEDs All tolerances unless otherwise noted : ±0.2 mm PCB LAYOUT & CIRCUIT DIAGRAM SINGLE LED TH 370 BI-COLOR - 2 LEDS SMD TH SMD Illuminated switches • slip-on cap retention system • integrated chip-LEDs BUILD YOUR PART NUMBER ILLUMINATED 4F MOUNTING SERIES LED TH9 through-hole 01 blue SH9 surface mount 22 green 29 high intesity green 42 yellow 61 white 82 red 2242 green/yellow 8222 red/green 8242 red/yellow ABOUT THIS SERIES Notice : Refer to www.apem.com for further information. Accessories : See the website for 4F cap and bezel options 371 PANEL PCB SWITCHES Illumec™ 4F PCB SWITCHES Illumec™ 4F Illuminated switches • slip-on cap retention system • integrated chip-LEDs MOUNTING TAPE & REEL Tape and reel is available for the parts listed and has the following specifications SPACE REQUIREMENT - MATRIX MOUNTING • Reel diameter: Ø330 mm • Tape width:24 mm • Pitch: see list • Tape and reel material : antistatic or better • Quantity per reel : see list PART NO. ORDERING CODE PITCH QUANTITY PER REEL 4FSH901 4FSH901R 20 250 4FSH922 4FSH922R 20 250 4FSH942 4FSH942R 20 250 4FSH961 4FSH961R 20 250 4FSH982 4FSH982R 20 250 4FSH92242 4FSH92242R 20 250 4FSH98222 4FSH98222R 20 250 4FSH98242 4FSH98242R 20 250 through-hole (TH) surface mount (SMD) LED COMPONENT SPECIFICATIONS Color Blue Green Yellow White Red High Intensity Green Color Codes 01 22 42 61 82 29 ABSOLUTE MAXIMUM RATINGS (Ta=25°C) Power mW 110 75 60 48 65 102.5 Current forward mA 25 30 25 15 25 25 Forward peak current mA 100 80 60 100 100 150 Voltage reverse V 5 5 5 NA 12 5 Operating temperature °C -40/+85 -55/+85 -40/+85 -40/+85 -30/+85 -40/+85 Storage temperature °C -40/+85 -55/+85 -40/+90 -40/+85 -40/+85 -40/+85 Soldering temperature °C 5 245 for max. 10 sec ELECTRICAL-OPTICAL CHARACTERISTICS (Ta=25°C) Voltage forward Typ. V 3.3 2 1.75** 2.85 2 3.3 Max. V 3.7 2.4 2.35 3.1 2.5 4.1 Current reverse (VR=5V) Max. µA 50 100 10 NA 100 50 Wave length nm 468 571 591 NA 633 525 25 NA 15 NA 16 30 Spread nm Spread angle degree 120 130 120 150 160 60 Luminous Intensity Min. mcd 28.5 18 28.5 71 28 500 Typ. mcd 72* 35 72* 224* 180* 1000 Lm/w NA NA NA 36 7 NA Optical intensity */F=20mA, **Pulse width 1ms Duty cycle 1:5, ***/F=50mA, ****Luminous Flux mlm 372
4FTH942 价格&库存
很抱歉,暂时无法提供与“4FTH942”相匹配的价格&库存,您可以联系我们找货
4FTH942
  • 1+62.249701+7.98480
  • 10+51.6372010+6.62350
  • 50+48.6666050+6.24250
  • 100+46.21110100+5.92750
  • 200+42.52190200+5.45430
  • 500+40.94080500+5.25150
  • 1000+39.108201000+5.01640
