PANEL
PCB SWITCHES
n
io
at
m
r
fo om
in .c
s
m
ie e
er ap
l s w.
l
fu w
or w
Illumec™ 4F
F
Illuminated switches • slip-on cap
retention system • integrated chip-LEDs
DISTINCTIVE FEATURES
10 x 10 mm ; h=10.4 mm
Illumination with integrated chip-LEDs
Single or bi-color illumination
Momentary NO
Simple slip-on cap retention system
ENVIRONMENTAL SPECIFICATIONS
• Switch sealing : IP67 according to IEC 60529
• Working and storage temperature : -30°C/+85°C
• Soldering :
- through-hole : IEC 68-2-20 8
- surface mount : JEDEC J-STD-020C
ELECTRICAL SPECIFICATIONS
• Recommended load :
- Gold contacts : 0.5µ-50mA 24VDC
- Silver contacts : 0.5-50mA 24VDC
• Contact resistance : 10MΩ
• Contact bounce : 10,000,000 cycles
• Terminals : SnCu + 2µNI + 3µSn100
The company reserves the right to change specifications without notice.
All tolerance if not otherwise specified ±0.2mm.
• Max. actuation force : 100N for 10 sec
369
PCB SWITCHES
Illumec™ 4F
4FSH9XX
To p TVoiepwV ie w
To pTVoipe w
V ie w
• SMD
• NO
• Single or bi-color LEDs
4FTH9XX
To pToVpieVwie w
To p
ToVpieVwie w
• TH
• NO
All tolerances unless otherwise noted : ±0.2 mm
PCB LAYOUT & CIRCUIT DIAGRAM
SINGLE LED
TH
370
BI-COLOR - 2 LEDS
SMD
TH
SMD
BUILD YOUR PART NUMBER
ILLUMINATED
4F
MOUNTING
SERIES
LED
TH9
through-hole
01
blue
SH9
surface mount
22
green
29
high intesity green
42
yellow
61
white
82
red
2242
green/yellow
8222
red/green
8242
red/yellow
ABOUT THIS SERIES
Notice : Refer to www.apem.com for further information.
Accessories : See the website for 4F cap and bezel options
371
PANEL
PCB SWITCHES
Illumec™ 4F
PCB SWITCHES
Illumec™ 4F
MOUNTING
TAPE & REEL
Tape and reel is available for the parts listed and has the
following specifications
SPACE REQUIREMENT - MATRIX MOUNTING
• Reel diameter: Ø330 mm
• Tape width:24 mm
• Pitch: see list
• Tape and reel material : antistatic or better
• Quantity per reel : see list
PART NO.
ORDERING CODE
PITCH
QUANTITY
PER REEL
4FSH901
4FSH901R
4FSH922
4FSH922R
4FSH942
4FSH942R
4FSH961
4FSH961R
4FSH982
4FSH982R
4FSH92242
4FSH92242R
4FSH98222
4FSH98222R
4FSH98242
4FSH98242R
through-hole (TH)
surface mount (SMD)
LED COMPONENT SPECIFICATIONS
Color
Blue
Green
Yellow
White
Red
High Intensity Green
Color Codes
01
22
42
61
82
29
ABSOLUTE MAXIMUM RATINGS (Ta=25°C)
Power
mW
110
75
60
48
65
102.5
Current forward
mA
25
30
25
15
25
25
Forward peak current
mA
100
80
60
100
100
150
Voltage reverse
V
5
5
5
NA
12
5
Operating
temperature
°C
-40/+85
-55/+85
-40/+85
-40/+85
-30/+85
-40/+85
Storage temperature
°C
-40/+85
-55/+85
-40/+90
-40/+85
-40/+85
-40/+85
Soldering temperature
°C
5
245 for max. 10 sec
ELECTRICAL-OPTICAL CHARACTERISTICS (Ta=25°C)
Voltage forward
Typ. V
3.3
2
1.75**
2.85
2
3.3
Max. V
3.7
2.4
2.35
3.1
2.5
4.1
Current reverse (VR=5V)
Max. µA
50
100
10
NA
100
50
Wave length
nm
468
571
591
NA
633
525
25
NA
15
NA
16
30
Spread
nm
Spread angle
degree
120
130
120
150
160
60
Luminous Intensity
Min. mcd
28.5
18
28.5
71
28
500
Typ. mcd
72*
35
72*
224*
180*
1000
Lm/w
NA
NA
NA
36
7
NA
Optical intensity
*/F=20mA, **Pulse width 1ms Duty cycle 1:5, ***/F=50mA, ****Luminous Flux mlm
372
很抱歉,暂时无法提供与“4FTH922”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+68.657901+8.80680
- 10+66.1066010+8.47950
- 50+65.4119050+8.39040
- 100+45.76790100+5.87070
- 500+44.89350500+5.75850
- 1000+43.923301000+5.63410
