1630034
1630034
    APEM(埃斐)
    矩形,凸起(圆顶) 按钮 开关盖帽 甜瓜色 卡入式
1630034 数据手册
9 EC E IM N -U PANEL PCB SWITCHES 00 2 C- Unimec™ M 8 contact functions • 2 pole • distinct tactile feel DISTINCTIVE FEATURES 12.6 x 12.6 mm; h=15.7 mm 2 pole Momentary, latching or quiet 8 contact functions Up to 10,000,000 cycle lifetime ENVIRONMENTAL SPECIFICATIONS • Sealing : IP54 according to IEC 60529 • Working temperature : -40 °C/+160 °C • Storage temperature : -65 °C/+160 °C • Soldering : IEC 68-2-20 ELECTRICAL SPECIFICATIONS • Recommended load : - Gold contacts : min. 0.5 µmA - max.250 mA - 120 V - 9 W AC - 6 W DC - Silver contacts : min. 0.5 mA - max.250 mA - 120 V - 9 W AC - 6 W DC • Contact resistance : max. 100 mΩ (initially) • Insulation resistance : >10 MΩ • Contact bounce : max. 10 ms • Dielectric strength between adjacent contacts : 1000 V for 2 min • Insulation resistance between adjacent contacts : 5 X 10 13Ω • Capacitance between adjacent contacts :0.5 pF MATERIALS • Housing : LCP UL94V0 • Actuator : LCP UL94V0 • Switch spring : Stainless steel MECHANICAL SPECIFICATIONS • Standard actuation force : 2.5 N • Max. actuation force : 100 N for 10 sec • Travel : 1.8 mm • Lifetime : momentary : >10,000,000 cycles latching : 5,000,000 cycles The company reserves the right to change specifications without notice. • Key spring : Stainless steel • Latch pin : Stainless steel • Fixed contacts : Silver : SnCu + 2 µNI + 3 µAg Gold : SnCu + 2 µNI + 3 µAu • Moving contacts : Silver : Stainless steel + 3 µAg Gold : Stainless steel + 3 µAg + 1 µAu • Terminals : SnCu + 2 µNI + 3 µSn100 All tolerance if not otherwise specified ±0.2mm. 1 8 contact functions • 2 pole • distinct tactile feel 3.3 12.6 10.1 5.6 UNIMEC 12.6 12.6 12.6 • TH • momentary, latching or quiet • 8 contact functions All tolerances unless otherwise noted : ±0.2 mm PCB LAYOUT PCB MOUNTING HOLE DIMENSIONS FUNCTIONAL DIAGRAM 5 7 6 8 1 3 2 4 5 7 6 8 + Ø = 0.9 3,0 Ø 0,9 With 3 mm LED 16923 and 16924 1 3 2 4 2 4 1 3 5 7 6 8 6 8 5 7 2.54 2 4 2.54 1 3 13,1 2,54 2,54 Ø = 0.9 With round LED 16920 and 16921 With square LED 16922 - up - - down CIRCUIT DIAGRAM + - - - + + 1 3 2 4 1 3 2 4 1 3 2 4 5 7 6 8 5 7 6 8 5 7 6 8 + - - + With round LED 16920 and 16921 + - With rect. LED 16922 WIRING 1 make contact 2 1 break contact 1 change over contact 2 make contact 2 break contact 2 change over contact 2 make & 2 break - + - + - + - + - ++ + - + ++ -+ - + - + - -+ - + - --+ - + - + + - + - - -+ - ++ + Select the contact function you require - and design your PC board accordingly - PCB SWITCHES Unimec™ reverse polarity 8 contact functions • 2 pole • distinct tactile feel BUILD YOUR PART NUMBER NON-ILLUMINATED 154 SERIES 09 SWITCH FUNCTION TERMINAL 0 momentary 1 silver 5 latching 2 gold 0 quiet* COLOR OF THE HOUSING *quiet function has silver terminals, in case of gold terminals the part number is 15420 ABOUT THIS SERIES Notice : please note that not all combinations of above numbers are available. Contact APEM for further information. Marking on the switch for identification : 15400 A; 15420 H; 15401 E; 15402 F; 15451 I; 15452 J Accessories : See www.apem.com for cap & bezel options. 3 PANEL PCB SWITCHES Unimec™ Support Vario Support IMEC switches with bezels unimec - 16310-16315 and 16324-16326 nimec Vario Support Support unimec Vario Support 16.423- (2x5) 16.450 (5x5) 16.432 (3x5)16324-16326 16.441 (4x5) ezels 16310-16315 and ™ x4) 16.440 (4x4) Unimec Support ezels - 16310-16315 and 16324-16326 45.7 30.5 61.0 30.5 61.0 15.2 11.4 30.5 61.0 30.5 61.0 61.0 45.7 45.7 45.7 45.7 38.1 38.1 53.3 53.3 38.1 38.1 53.3 53.3 38.1 53.3 53.3 38.1 14. 53.3 53.3 38.1 38.1 68.5 68.5 53.3 53.3 11.4 11.4 45.7 3.0 14. 11 45.7 45.7 38.1 38.1 53.3 53.357.1 53.3 53.3 45.7 45.7 45.7 45.7 45.7 61.0 30.5 45.7 61.0 30.5 1.1 45.7 3.0 45.7 14.8 38.1 38.1 57.1 41.9 57.1 45.7 57.1 57.1 45.7 41.9 41.9 57.1 45.7 160.0 83.8 61.0 61.0 45.7 45.7 45.7 45.7 45.7 30.5 45.7 30.5 11 30.5 61.0 61.0 3.0 1.1 45.7 45.7 8 38.1 38.1 45.7 61.0 30.5 45.7 11 45.7 45.7 83.8 45.7 45.7 53.3 53.3 30.5 45.7 53.3 30.5 38.1 1.1 45.7 45.7 68.5 68.5 68.5 15.24 1.1 53.3 45.7 68.5 30.5 3.0 45.7 30.5 45.7 30.5 45.7 45.7 61.0 30.5 45.7 45.7 61.0 30.5 45.7 45.7 30.5 Min. 15.3 11.4 45.7 45.7 45.7 45.7 45.7 45.7 45.7 45.7 45.7 11.4 160.0 41.9 11.4 45.7 45.7 45.7 68.5 61.0 45.7 30.5 45.7 11.4 68.5 61.0 15.2 61.0 45.7 30.5 45.7 30.5 11.4 45.7 61.0 Min. 15.3 61.0 41.9 53.3 53.3 22.8 22.8 8.6 45.7 61.0 38.1 45.7 83.8 30.5 30.5 68.5 68.5 22.811.4 45.7 45.7 53.3 1.1 7.1 41.9 61.0 45.7 53.3 45.7 53.3 1.5 30.5 53.3 45.7 2.6 1.5 38.1 10.9 3.8 3.0 4.1 61.0 45.7 38.1 38.1 38.1 68.5 38.1 30.5 53.3 68.5 7.1 45.7 53.3 30.5 15.2 61.0 7.1 38.1 38.1 53.3 68.5 30.5 45.7 45.7 45.7 45.7 160.0 11.4 57.1 45.7 15.24 8.6 ezels - 16310-16315 and 16324-16326 68.5 61.0 15.2 160.0 45.7 45.7 41.9 53.3 45.7 14.41.1 38.1 22.8 68.5 68.5 61.038.1 45.7 45.7 61.0 61.0 68.5 38.1 7.1 2.6 41.9 53.3 61.0 Min. 15.3 3.0 22.8 30.5 68.5 61.0 53.3 30.5 22.8 1.5 53.3 45.7 30.5 61.0 1.5 10.9 3.8 3.0 4.1 10.9 38.1 10.9 38.1 45.7 38.1 53.3 30.5 38.1 15.2 53.3 38.1 38.1 22.8 unimec Vario Support Vario Support unimec unimec Vario Support Vario unimec Vario Support Support unimec Vario Support unimec Vario Support Vario Support unimec unimec Vario Support Vario Support unimec Vario Support unimec Vario Support unimec Vario Support unimec Vario Support unimec Vario Support nimec Vario Support Vario Support unimec Vario Support Support nimec Vario Support Vario nimec Vario nimec VarioSupport Support unimec Vario Support nimec Vario Support nimec Vario nimec VarioSupport Support nimec Vario Support nimec Vario Support unimec Vario Support unimec Vario Support unimec Vario Support 61.0 68.5 61.0 Min. 15.3 7.1 7.1 45.7 7.1 7.1 45.7 7.1 7.1 11.4 68.5 15.24 53.3 68.5 8.6 53.3 57.1 1.1 2.6 2.6 15.24 45.7 45.7 45.7 61.0 61.0 61.0 61.0 30.5 45.7 45.7 45.7 45.7 45.7 30.5 45.7 45.7 30.5 45.7 45.7 30.5 2.6 2.6 11.4 45.7 61.0 8.6 30.5 30.5 45.7 45.7 2.6 2.6 1.1 14.4 53.3 2.6 61.0 30.5 22.8 45.7 45.7 8.6 53.3 3.0 45.7 53.3 45.7 30.5 45.7 61.0 45.7 11.4 61.061.0 68.5 41.9 41.9 68.5 15.24 1.1 41.9 68.5 68.5 68.5 68.5 68.5 41.9 41.9 68.5 68.5 41.9 41.9 41.9 41.9 41.9 68.5 41.9 57.1 57.1 57.1 57.1 57.1 57.1 68.5 68.5 68.5 68.5 45.7 45.7 45.7 68.5 41.9 41.9 68.5 68.5 41.9 41.9 41.9 41.9 68.5 41.9 68.5 68.5 68.5 68.5 8.6 68.5 41.9 41.9 41.9 57.1 68.5 68.5 53.3 53.3 53.353.3 53.3 41.9 41.9 41.9 41.9 41.9 41.9 41.9 41.9 68.5 41.9 68.5 68.5 68.5 68.5 68.5 41.9 41.9 68.5 68.5 53.3 53.3 53.353.3 53.3 41.941.9 41.9 41.941.9 41.9 41.953.3 41.9 57.1 53.3 53.3 68.5 41.9 41.9 10.9 10.9 10.9 10.910.968.5 10.9 68.5 68.5 68.5 57.1 41.9 57.1 57.1 68.5 68.5 41.9 41.9 68.5 53.3 53.3 53.353.3 53.3 41.9 41.9 41.9 41.9 41.9 41.953.3 53.3 53.3 41.9 41.941.9 68.5 68.5 68.5 68.5 57.1 68.5 53.3 53.3 53.3 53.353.3 53.3 41.9 41.9 57.1 41.9 57.1 57.1 41.9 41.9 41.9 41.9 41.9 41.9 53.3 53.3 3.8 3.0 4.1 3.8 3.0 3.84.1 3.0 4.1 3.8 3.0 3.8 3.0 41.91.1 41.9 41.9 4.1 4.1 3.8 3.0 4.1 41.9 41.9 41.9 15.24 1.1 15.24 41.9 68.5 38.1 38.1 38.1 38.1 38.1 38.1 53.3 53.353.3 1.1 15.24 53.3 41.9 41.941.9 41.9 41.9 41.941.9 41.9 41.953.3 53.3 53.3 41.9 57.1 41.9 41.9 41.9 41.9 41.9 41.9 41.9 41.9 41.9 57.1 53.3 41.9 57.1 41.9 15.24 1.1 38.1 38.1 38.1 38.1 38.157.1 53.3 53.3 53.353.3 53.3 38.1 38.1 8.6 8.653.3 41.9 8.641.9 53.3 53.3 41.9 41.941.9 41.9 41.9 41.9 41.9 41.9 41.9 38.1 57.1 38.1 38.1 38.1 38.1 38.1 38.1 53.3 53.3 53.3 41.9 53.353.3 53.3 38.1 38.1 53.3 53.3 8.6 41.9 41.9 41.9 41.9 41.9 41.9 38.1 38.1 38.1 15.24 38.1 38.1 53.3 53.3 53.353.3 53.3 22.8 41.9 41.9 22.8 22.8 41.9 41.9 22.8 22.8 41.9 38.1 38.1 38.1 1.1 15.24 1.1 15.24 1.1 53.341.9 53.3 53. 41.9 22.8 41.9 41.9 41.9 41.9 41.9 38.1 38.1 38.1 38.1 38.1 38.1 1.5 1.5 1.5 1.5 1.5 1.5 38.1 38.1 22.8 22.8 22.8 22.8 22.8 22.8 22.8 22.8 41.9 15.24 1.1 41.9 41.9 41.9 41.9 41.9 41.9 41.9 41.9 41.9 8.6 8.6 8.6 38.1 38.1 38.1 38.1 38.1 38.1 38.1 38.1 22.8 22.8 22.8 22.8 22.8 22.8 22.8 22.8 41.9 41.9 41.9 41.9 41.9 41.9 41.9 41.9 38.1 38.1 38.1 38.1 38.1 38.1 8.6 22.8 22.8 22.8 22.8 22.8 22.8 22.8 22.8 15.24 41.9 1.1 15.24 1.1 15.24 1.1 41.9 41.9 41.9 41.9 41.9 41.9 41.9 38.1 38.1 22.8 38.1 38.1 38.1 38.1 41.9 41.9 22.8 22.8 22.8 22.8 22.8 41.9 41.9 41.9 41.9 41.9 41.9 15.2 41.9 41.9 38.1 38.122.8 38.1 38.1 38.1 38.1 41.9 41.9 41.9 41.9 41.9 41.9 41.9 8.6 8.6 8.6 41.9 22.8 22.8 22.8 22.8 22.8 41.9 41.9 41.9 41.9 41.9 41.9 41.9 41.9 41.9 41.9 41.9 41.9 41.9 41.941.9 41.9 41.9 41.9 41.9 41.9 41.9 41.9 41.9 41.9 41.9 41.9 41.9 41.9 41.9 41.9 41.941.9 41.9 41.9 41.9 41.9 41.9 41.9 41.9 41.9 41.9 41.9 41.9 41.9 41.9 41.9 41.941.9 41.9 41.9 41.9 15.24 1.1 15.24 1.1 15.24 1.1 41.9 41.9 41.9 41.9 41.9 41.9 41.9 41.9 41.9 41.9 41.9 41.9 41.9 41.9 41.9 41.9 8.6 8.6 8.6 41.9 41.9 15.24 1.1 15.24 1.1 15.24 1.1 41.9 41.9 15.24 1.1 41.98.6 41.98.6 8.6 41.9 41.9 41.9 41.9 41.9 41.9 15.24 1.1 15.24 1.1 15.24 1.1 8.6 41.9 41.9 41.9 41.9 41.9 41.9 41.9 8.6 8.6 8.6 57.1 57.145.757.1 57.1 57.1 45.7 57.1 45.7 41.9 41.9 2.6 2.6 2.6 2.6 2.6 2.6 41.9 41.9 41.9 41.9 41.9 41.941.9 41.9 41.9 41.9 57.1 57.1 57.1 41.9 45.7 41.9 41.9 7.141.9 7.1 7.141.9 7.1 7.1 7.1 41.941.9 41.9 41.9 41.9 41.9 141.9 57.1 41.9 41.9 41.9 41.9 41.9 41.9 41.9 41.9 41.9 41.9 41.9 41.9 57.1 41.9 41.9 41.9 41.9 41.9 57.1 41.9 57.141.9 57.1 41.9 41.9 41.9 41.9 41.9 41.9 41.9 41.9 41.9 41.9 41.9 41.9 41.9 41.9 41.9 57.1 41.9 41.9 41.9 41.9 41.9 41.9 57.1 41.9 45.7 41.9 41.9 57.1 57.1 57.1 57.1 57.1 45.7 45.7 41.9 57.1 41.9 57.141.9 57.1 41.9 41.9 41.9 41.9 41.9 41.9 41.9 57.1 41.9 41.9 41.9 41.9 41.9 41.9 41.9 41.9 41.9 41.9 41.9 68.5 68.5 68.568.5 68.5 57.168.5 41.9 57.1 57.1 57.1 45.7 41.9 41.9 41.9 41.9 41.9 41.9 41.9 41.9 41.9 41.9 41.9 41.9 41.9 57.1 41.9 41.9 41.9 41.9 9 57.1 41.9 57.141.9 57.168.5 68.5 68.5 68.568.5 68.5 68.5 68.5 41.9 57.1 41.9 41.9 41.9 41.9 41.9 41.9 41.9 41.9 41.9 41.9 68.5 68.5 68.568.5 68.5 41.9 57.1 41.9 57.141.9 57.168.5 41.9 57.1 68.5 45.7 57.1 68.5 57.145.757.1 57.1 57.1 57.1 45.7 41.9 41.9 68.541.9 68.5 68.568.5 68.5 41.9 57.1 41.9 57.141.9 57.168.5 15.24 15.24 1.1 15.24 1.1 45.7 1 .1 41.9 57.141.9 57.1 68.5 68.5 41.9 57.1 57.1 57.1 53.3 53.3 53.3 53.3 53.3 53.3 15.24 1.1 15.24 1.1 15.24 1.1 68.5 68.5 68.5 68.5 68.5 68.5 68.5 68.5 41.9 57.1 41.9 57.141.9 57.1 41.9 57.1 41.9 57.1 15.24 53.3 1.1 15.24 1.1 53.3 53.3 53.3 53.3 53.3 53.3 53.3 1.1 15.24 68.5 68.541.9 68.5 68.568.5 68.5 10.9 10.9 10.9 10.9 10.9 10.9 68.5 68.5 41.9 57.1 41.9 57.141.9 57.1 8.6 8.6 8.6 57.1 53.3 53.3 53.3 53.3 53.3 53.3 8.6 68.5 8.6 8.615.24 53.3 53.3 68.5 68.5 68.5 41.9 68.58.6 68.5 68.5 8.6 8.6 68.5 41.9 57.1 41.9 57.141.9 57.1 57.1 53.3 53.3 53.3 53.3 53.3 53.3 53.3 53.3 3.8 3.8 3.0 3.0 4.1 3.8 3.8 3.0 3.0 4.1 3.8 3.8 3.0 3.0 4.1 4.1 4.1 4.1 68.5 6 57.141.9 57.1 57.1 53.3 57.145.757.1 41.957.1 57.1 45.7 57.1 38.1 38.1 38.1 38.1 38.1 38.1 53.3 53.3 53.3 53.3 53.3 45.7 57.1 53.3 53.3 41.9 57.1 41.9 57.141.9 57.1 38.1 38.1 38.1 38.1 38.1 38.1 53.3 53.3 53.3 53.3 53.3 53.3 41.9 57.1 38.1 38.1 53.3 53.3 41.9 57.1 41.9 57.141.9 57.1 38.1 38.1 38.1 38.1 38.1 38.1 41.9 57.1 53.3 53.3 53.3 53.3 53.3 53.3 38.1 38.1 57.1 57.145.757.1 57.1 57.1 45.7 57.1 45.7 38.1 38.1 38.1 38.1 38.1 38.1 41.9 57.1 41.9 57.141.9 57.1 53.3 53.3 53.3 53.3 53.3 53.3 41.9 57.1 38.1 38.1 41.9 57.1 57.1 57.1 45.7 38.1 38.1 38.1 38.1 38.1 38.1 41.9 57.1 41.9 57.141.9 57.1 1.5 1.5 1.5 1.5 1.5 1.5 41.9 41.9 57.1 41.9 57.141.9 57.141.9 57.157.1 57.1 57.145.7 57.1 57.1 57.1 45.7 45.7 57.1 38.1 38.1 38.1 38.1 38.1 38.1 22.8 22.8 22.8 22.8 22.8 22.8 41.9 57.1 41.9 57.1 41.9 57.141.9 57.141.9 57.1 41.9 57.1 38.1 38.1 38.1 38.1 38.1 38.1 22.8 22.8 22.8 22.8 22.8 22.8 22.8 57.1 41.9 57.141.9 57.1 22.8 41.9 57.1 41.9 57.141.9 57.141.9 57.1 41.9 57.1 38.1 38.1 38.1 38.1 22.8 22.8 22.8 22.8 22.8 22.8 41.9 57.1 41.9 57.141.9 57.141.9 57.1 41.9 57.1 22.8 22.8 22.8 22.8 22.8 22.8 41.9 57.1 41.9 57.141.9 57.1 41.9 57.1 22.8 22.8 22.8 22.8 22.8 22.8 41.9 57.1 22.8 22.8 68. 38.1 7.1 38.1 22.8 22.8 30.5 7.12.6 38.1 68.5 Min. 15.3 30.5 3.0 45.7 45.7 1.5 2.610. 1.5 53.3 3.8 15.2 38.1 10.9 53.3 53.3 3.8 3.0 4.1 3.8 3.0 4.1 3.8 3.0 4.1 38.1 38.1 38.1 38.1 PCB SWITCHES 2.6 22.8 38.1 38.1 38.1 15.2 1.5 68.5 68.5 53.3 3.87.1 3.0 16.414 (1x5) 16.423 410 (1x1)of UNIMEC 16.500 (10x10) 16.412 (1x3) 16.430 16.421 (2x3) types and 16324-16326 16.410 (1x1)switches with bezels - 16310-16315 16.412 (1x3) 16.430 (3x (3x 16.421 (2x3) - 16310-163 For all types of UNIMEC switches with bezels 16.420 (2x2) 16.411 (1x2) 16.420 (2x2) 16.411 (1x2) 16.420 (2x2) 16.411 (1x2) 11.4 45.7 45.7 16.431 (3x4) 16.440 (4x4)14.4 16.422 (2x4)Min. 15.3 16.413 (1x4) 83.8 16.431 (3x4)(1x3) 16.440 (4x4) 16.422 (2x4) 16.413 (1x4) 11.4 3.0 16.414 16.423 16.412 16.430 (3x 16.421 (2x3) 16.412 (1x3) 16.430 (3x3) For all types of UNIMEC 16.421 (2x3) 16.500 (10x10) 16.412switches (1x3) 16.430 (3x 16.421 (2x3)(1x5) with bezels - 16310-163 15.2 16.420 (2x2) 411 (1x2) 16.411 16.417 (1x8) 16.426 (2x8) 16.435 (3 16.424 16.415 (1x6) 16.42 16.419 (1x10) 16.442 (4x6) 16.433 (3x6) (2x6) 16.415 (1x6) 14.416.424 11.4 45.7 Min. 15.3 16.431 (3x4) (4x4) 16.422 (2x4) 16.413 (1x4) 16.420 (2x2) (1x2) 16.417 (1x8) 16.440 16.426 (2x8) 16.43545.7 (3 0 (1x1) 3.0 16324-16326 pes of UNIMEC switches with bezels 11.4 - 16310-16315 11.4 16.413 (1x4) 61.0 16.410 (1x1)and 16.431 (3x 16.422 (2x4) 16.412 (1x3) 16.430 (3x 16.421 (2x3) 16.431 16.422 (2x4) - 16310-163 16.413 (1x4) 11.4 45.7 16.500 (10x10) 16.412 (1x3) 16.430 (3x3) 16.421 (2x3) 16.412 (1x3) 16.430 (3x 16.421 (2x3) 1.1 15.24 For all types of UNIMEC switches with bezels 15.2 16.500 (10x10) 61.0 30.516.415 (1x6) 11.4 45.7 8.6 16.424 16.414 (1x5) 16.423 (2x5) 16.450 (5x5) 16.432 (3x5) 16.441 (4x5) 14.4 16.414 (1x5) 11.4 16.432 45.7 16.413 45.7 45.7 45.7 (4x4) 30.5 3.0 16.431 16.422 16.410 (1x1) (2x5) 16.450 (5x5)(3x (3x5)(1x4) 16.441 (4x5)(2x4) 16.431 (3x4) 16.423 16.440 16.422 (2x4) 16.413 (1x4) 8 contact functions • 16.431 (3x 16.420 (2x2) 16.422 (2x4) 16.413 (1x4) 1.1 15.24 412 (1x3) 16.430 (3x3) 16.421 (2x3) 11.4 45.7 30.5 16.420 (2x2) 1 (1x2) 15.2 2 16.412 (1x3) 16.430 (3x3) 16.421 (2x3) 16.420 (2x2) 16.411 (1x2) pole • distinct tactile feel 8.6 160.0 16.424 16.415 (1x6) Tel. 30.5 1x1) 45.7 30.5 16.414 (1x5) 16.423 (2x5) 16.450 (5x5) 16.432 45.7 (3x5) 45.7 16.441 (4x5) 11.4 45.7 and For all30.5types of UNIMEC 14.4 switches with bezels -(3x4) 16310-16315 16324-16326 16.431 (3x 16.422 (2x4) 16.413 (1x4) 16.410 (1x1) 16.420 (2x2) 16.500 (10x10) 16.414 (1x5) 16.423 (2x5) 16.432 (3x 16.431 (4x4) 16.422 (2x4) 16.413 (1x4) 3.0 For 16.418 (1x9) 16.427 (2x9) 16.436 (3 16.416 (1x7) 16.425 16.431 16.422 (2x4) 16.413 (1x4) 16.434 (3x7) 16.443 (4x7) 16.416 (1x7) 16.440 16.500 (1 16.425 (2x7) 83.8 16.414 (1x5) 16.423 (2x5) 16.432 (3x 16.418 (1x9) 16.427 (2x9) 16.436 (3 11.4 all types of UNIMEC switches with bezels 16310-16315 and 16324-163 1.1 15.24 16.420 (2x2) 16.411 (1x2) 160.0 8.6 30.5 30.5 30.5 53.3 61.0 45.7 61.0 45.7 11.4 45.7 Min. 15.3 11.4 45.7 30.5 45.7 45.7 14.4 11.4 45.7 30.5 99.045.7 99.0 45.7 61.0 61.0 61.0 30.5 45.7 11.4 45.7 61.0 30.530.5 45.7 45.7 11.445.745.745.7 30.5 Min. 15.3 45.7 45.7 45.745.7 11.445.7 45.7 45.7 Min. 15.3 30.5 11.4 3.0 61.0 83.8 30.5 45.7 61.0 57.1 14.4 30.5 11.4 45.7 45.7 99.0 30.5 45.7 61.0 61.0 14.4 45.7 45.7 45.7 45.7 45.7 61.0 11.4 160.0 61.0 45.7 30.5 45.7 11.4 45.7 45.745.730.5 30.5 45.7 45.7 45.7 11.4 45.7 45.7 45.7 45.7 45.7 61.0 61.0 45.7 11.4 45.7 45.7 45.7 83.8 14.4 30.5 3.0 14.4 11.4 41.9 41.9 38.1 45.7 30.5 Min. 15.3 45.7 11.4 61.0 11.4 61.0 99.0 61.0 1.1 45.7 45.7 45.7 61.0 8 99.0 45.7 45.7 45.730.5 45.7 45.7 45.730.5 45.7 160.0 45.7 45.7 mec a/s Jan. 2002 57.1 57.145.757.1 57.1 57.1 45.7 57.1 45.7 57.1 57.145.757.1 57.1 57.1 45.7 57.1 45.7 57.141.9 57.1 41.9 57.1 57.1 41.9 41.9 57.141.9 57.1 41.9 57.1 57.141.9 57.1 41.9 57.1 41.9 57.1 41.9 57.1 41.9 41.9 57.141.9 57.1 57.141.9 57.1 41.9 57.1 41.9 57.1 41.9 57.1 mec a/s Jan. 2002 41.9 57.1 41.9 41.9 57.141.9 57.1 41.9 57.1 57.141.9 57.1 41.9 57.1 41.9 57.1 41.9 41.9 41.9 41.9 41.9 41.9 41.941.9 41.941.9 41.9 41.9 41.9 57.1 41.9 57.1 41.9 57.1 41.9 57.1 41.9 57.1 41.9 41.9 41.9 41.9 41.9 41.941.9 41.941.9 41.9 41.9 41.9 41.9 41.9 41.9 41.9 41.9 57.1 41.9 41.9 41.9 41.9 41.9 41.9 41.9 41.9 a/s 41.9Jan. 41.9 41.9 2002 41.9 41.9 41.9 41.9 41.9 mec 41.9 41.9 41.9 41.9 41.9 41.9 41.941.9 41.941.9 41.9 41.9 41.9 41.9 41.9 41.9 68.5 68.5 68.5 68.5 68.5 68.5 41.9 41.9 41.9 41.9 41.9 41.9 41.941.9 41.941.9 41.9 41.9 41.9 41.9 41.9 41.9 68.5 68.5 68.5 68.5 68.5 68.5 68.5 68.5 41.9 41.9 41.9 41.9 41.9 41.9 41.941.9 41.941.9 41.9 41.9 41.9 68.5 68.5 68.5 68.5 68.5 41.9 57.1 68.5 68.5 68.5 41.9 41.9 57.1 41.9 57.1 57.1 . 2002 68.5 68.5 68.5 68.5 68.5 68.5 68.5 68.5 53.3 53.3 53.3 53.3 41.9 57.1 mec a/s53.3 Jan. 2002 53.3 41.9 41.9 57.1 41.9 57.1 57.1 68.5 68.5 68.5 68.5 68.5 68.5 15.24 15.24 1.1 15.24 1.1 15.24 1.1 15.24 1.1 15.24 1.153.3 1.1 53.3 53.3 53.3 53.3 53.3 53.3 53.3 68.5 68.5 68.5 68.5 68.5 68.5 41.9 41.9 41.9 57.1 41.9 57.1 57.1 53.3 53.3 53.3 53.3 53.3 53.357.1 68.5 68.5 68.5 68.5 68.5 68.5 8.6 8.6 8.6 8.6 8.6 8.6 c a/s Jan. 2002 53.3 53.3 53.3 53.3 53.3 53.3 41.9 57.1 41.9 41.9 57.1 41.9 57.1 57.1 s Jan.mec 2002 a/s Jan. mec 2002 a/s Jan. 2002 53.3 53.3 53.3 53.3 53.3 53.3 mec a/s Jan. 2002 53.3 53.3 38.1 38.1 38.1 38.1 38.1 38.1 38.1 38.1 38.1 38.1 38.1 38.1 38.1 38.1 38.1 38.1 38.1 38.1 38.1 38.1 53.3 15.24 1.1 45.7 1.5 22.8 38.1 8.6 ™ 30.5 45.7 22.8 61.0 22.8 15.24 8.6 61.0 8.6 53.3 53.3 68.5 53.3 3.8 3.0 4.1 68.5 53.3 53.3 53.3 53.3 53.3 53.3 68.5 53.3 53.3 68.5 68.5 68.5 68.5 38.1 38.1 53.3 53.3 53.3 53.3 68.5 53.3 53.3 53.3 53.3 38.138.1 38.1 68.5 53.3 53.3 53.3 53.3 53.338.1 53.3 38.1 68.52.6 53.3 2.6 68.5 38.1 38.1 38.168.5 38.138.1 38.1 22.8 22.8 38.1 38.1 2.6 1.5 1.5 1.5 53.3 68.5 53.3 53.3 68.5 68.5 68.5 38.1 38.1 38.168.5 38.138.1 38.1 68.5 1.5 1.5 22.8 38.1 22.8 22.8 22.8 22.8 22.8 22.8 7.11.5 7.1 7.1 38.1 22.8 68.5 2.6 68.52.6 68.5 38.1 38.1 38.168.5 38.138.1 38.1 2.6 68.5 68.5 38.1 22.8 22.8 22.8 22.8 22.8 22.8 22.8 22.8 68.5 38.1 38.1 38.1 38.1 38.1 38.1 68.5 68.5 68.5 68.5 22.8 22.8 22.8 22.8 22.8 22.8 2.6 68.5 22.8 22.8 7.1 7.1 7.1 38.1 38.1 38.1 38.138.1 68.5 38.1 68.5 68.5 68.5 2.6 2.6 2.6 22.8 22.8 22.8 22.8 22.8 22.8 68.5 68.5 7.1 38.1 38.1 38.138.1 38.1 68.5 68.5 68.5 22.8 22.8 22.8 22.8 22.8 22.838.1 68.57.1 68.5 68.5 7.1 7.1 68.5 68.5 68.5 68.5 68.5 68.5 68.5 68.5 68.5 68.5 68.5 68.5 68.5 68.5 68.5 68.5 68.5 68.5 68.5 68.5 68.5 68.5 68.5 68.5 68.5 68.5 68.568.5 68.5 68.5 68.5 68.5 68.5 68.5 68.5 68.5 68.5 68.5 68.5 68.5 68.5 68.5 68.5 68.5 68.5 68.5 68.5 68.5 68.5 68.5 68.5 68.5 68.5 68.5 68.5 68.5 2.6 2.6 2.6 30.5 3.0 30.5 15.24 30.5 53.3 15.2 45.7 45.7 53.3 45.7 61.0 38.1 38.1 22.8 53.3 22.8 7.1 2.6 38.1 30.5 68.5 30.5 Min. 15.3 11.4 1.1 30.5 61.022.8 10.9 3.0 61.0 22.8 45.7 22.8 14.4 3.8 3.0 4.1 22.8 30.5 8.6 38.1 38.1 2.6 22.8 38.1 22.8 16.450 (5x5) x5) (4x5) For all types16.441 ofVARIO UNIMEC switches with bezels - 16310-16315 and 16324-16326 SUPPORT MOUNTING For all types of UNIMEC switches with bezels - 16310-16315 and 16324-163 16.414 (1x5) 16.423 (2x5) 16.432 (3x 16.420 (2x2) 16.500 (1 16.423 16.450 (5x5) 16.416 (1x7) 16.432 (3x5) 216.414 (1x3) 16.430 (3x3) 16.421 (2x3) 16.425 16.441 16.420 (2x2) 1x2) 16.431 (3x4) 16.440 (4x4)(4x5) 16.422 (2x4)(2x5) 413 (1x4)(1x5) 16.414 (1x5) 16.423 (2x5)and 16.432 (3x For all types of UNIMEC switches with bezels -(5x6) 16310-16315 16.442 (4x6) 16.433 (3x6) 16.424 (2x6) 16.451 16.460 (6x6) 16324-163 16.415 (1x6) 16.412 (1x3) 16.430 (3x3) 16.421 (2x3) 16.431 (3x4) 16.440 (4x4) 16.422 (2x4) 16.413 (1x4) 16.442 (4x6) 16.433 (3x6) 16.424 (2x6) 16.451 (5x6) 16.460 16.420 (2x2) 16.411 (1x2) For all types of UNIMEC switches with bezels 16310-16315 and 16324-16326 16.442 (4x6) 16.433 (3x6) 16.424 (2x6) 16.451 (5x6) 16.415 (1x6) 16.410 (2x3) (1x1) 16.430 (3x3) 16.421 16.500 (10x10) For all types of UNIMEC switches with - 16310-16315 and 16324-16326 For all types of bezels UNIMEC switches with bezels - 16310-16315 and 16324-163 16.410 (1x1) 16.414 (1x5) 16.423 (2x5) 16.432 (3x 16.416 (1x7)16.451 16.425 16.500 (1 16.414 (1x5) 16.423 (2x5) 16.450 (5x5) 16.432 (3x5) 16.441 (4x5) 16.412 (1x3) 16.430 (3x3) 16.421 (2x3) For all types of Unimec switches with bezels 16310 16315 and 16324 16326. 16.414 (1x5) 16.423 (2x5)and 16.432 (3x For all types of UNIMEC switches with bezels 16310-16315 16324-163 16.442 (4x6) 16.433 (3x6) (2x6) (5x6) 16.415with (1x6) bezels16.424 r all types of UNIMEC switches - 16310-16315 and 16324-16326 More options available as custom. 16.410 (1x1) 16.433 (3x 16.424 (2x6) 16.415 (1x6) 16.428 (2x10) 16.419(2x8) (1x10) 16.437 (3x 16.430 16.421 (2x3) 16.417 (1x8) 16.426 16.435 (3x8) (4x8) 16.417 (1x8) 16.444 16.426 16.410(3x3) (1x1) 16.433 (3x 16.424 (2x6) 16.415 (1x6) 16.428 (2x10) 16.419 (1x10) 16.437 (3x 1x3) 16.430 (3x3) 16.421 (2x3) 99.0 11.4 45.7 41.9 15.24 45.7 10.9 53.3 10.9 10.9 3.8 3.0 4.1 3.8 3.0 4.1 3.8 3.0 4.1 61.0 53.3 53.3 38.1 38.1 38.1 38.1 38.1 11.4 45.7 45.7 45.7 30.5 11.4 45.7 30.5 45.7 14.4 11.4 45.7 45.7 45.7 61.0 45.7 30.5 45.7 45.7 45.7 45.7 45.7 38.1 45.7 30.51.1 45.7 15.24 45.7 30.5 1.1 15.24 30.5 11.4 45.7 45.7 45.7 3.0 11.4 45.7 30.5 45.7 61.0 45.7 45.7 45.7 45.7 61.0 3.0 45.7 30.5 22.8 45.7 45.7 22.8 8.6 14.4 11.4 45.7 14.4 45.7 45.7 45.7 30.5 Min. 15.3 8.6 Min. 15.3 160.0 83.8 45.7 30.5 11.4 45.7 45.7 45.7 1.1 15.24 11.4 45.7 45.7 15.2 45.7 45.7 45.7 83.8 3.0 15.2 11.4 14.4 11.4 8.6 Min. 15.3 45.7 45.722.8 45.7 45.7 14.4 15.3 45.7 Min.30.5 38.1 68.5 45.7 Min. 15.3 22.8 45.7 11.4 61.0 45.7 45.7 45.7 45.7 14.4 11.4 45.7 38.1 99.0 99.0 15.2 45.7 30.5 3.0 114.3 45.7 30.5 11.4 160.0 114.3 45.7 30.5 11.4 45.7 45.7 45.7 45.7 45.7 45.7 38.1 11.4 1.1 61.0 45.7 30.5 30.5 45.7 15.24 45.7 45.7 15.24 45.7 30.5 15.2 1.1 45.7 30.5 1.1 15.24 61.0 45.7 45.7 114.3 30.5 45.7 30.5 11.4 45.7 45.7 45.7 3.0 3.0 61.0 8.6 45.7 30.5 30.5 45.7 61.0 45.7 45.7 61.0 160.0 22.8 45.7 8.6 30.5 11.4 45.7 45.7 45.7 45.7 30.5 38.1 30.5 14.4 45.7 30.5 8.6 Min. 15.3 1.1 30.5 11.4 45.7 45.7 61.0 30.5 45.715.24 45.7 45.7 45.7 45.7 61.0 53.3 15.2 15.2 45.7 99.0 99.0 30.511.43.0 11.4 45.7 8.645.7 45.7 30.5 45.7 3 45.7 11.4 45.7 45.7 61.0 30.5 45.7 45.7 3 3.0 22.8 45.7 45.7 61.0 61.0 45.768.5 30.5 45.7 14.41.1 11.4 45.7 45.7 15.24 Min. 15.3 38.1 38.1 11.445.745.7 22.8 45.745.7 53.3 45.7 30.5 45.7 15.2 61.0 14.4 11.4 45.7 45.7 45.7 30.5 45.7 Min. 15.345.7 11.445.7 45.7 45.7 30.5 45.7 30.5 45.7 99.0 99.0 3.0 160.0 8.6 45.7 45.7 15.2 45.7 30.5 114.3 11.4 61.0 11.4 45.7 30.5 45.7 38.1 114.3 1.1 11.4 45.7 30.5 1.1 15.24 30.5 15.24 61.0 45.7 45.7 45.7 30.5 38.1 83.8 30.5 45.7 61.0 3.0 61.0 11.4 45.7 8.6 8.6 45.7 45.7 30.5 45.7 30.5 30.5 160.0 61.0 45.7 45.7 45.7 11.4 61.0 45.7 30.5 45.7 45.7 1.1 15.24 53.3 45.7 61.0 11.4 61.0 53.3 45.7 45.7 1.1 15.24 45.7 30.5 30.5 15.2 61.0 160.0 45.7 3 45.7 61.0 45.7 45.7 45.7 3 8.645.7 3.0 30.5 45.7 11.4 45.7 45.7 45.7 22.8 45.7 61.0 8.6 3.0 22.8 14.4 45.7 11.4 45.7 45.7 45.7 53.3 Min. 15.3 45.7 30.5 45.7 38.1 61.0 14.4 11.4 45.7 45.7 45.7 61.0 45.7 45.7 45.7 61.0 Min. 15.3 45.7 30.5 45.7 11.4 45.7 45.7 61.0 22.8 45.7 45.7 45.7 14.4 11.4 45.7 45.7 45.7 45.7 160.0 Min. 15.3 15.2 30.5 99.0 99.0 11.4 45.7 45.7 61.0 45.7 22.8 45.7 11.4 11.445.7 45.7 15.2 61.0 11.4 45.7 45.7 61.0 30.5 Min. 15.3 45.7 61.0 30.5 14.4 11.4 99.0 99.0 45.745.7 30.5 11.4 38.1 53.3 11.4 1.1 15.24 61.0 1.1 15.24 11.4 45.7 45.7 45.7 61.0 45.7 45.7 11.4 38.1 61.0 45.7 61.0 30.5 30.5 11.4 45.745.7 30.5 45.7 61.0 114.3 114.3 8.6 11.4 45.7 45.7 45.7 11.4 61.0 30.5 61.0 160.0 68.5 8.6 45.7 129.5 45.7 129.5 30.5 45.7 45.7 45.7 53.3 53.3 1.1 15.24 61.0 45.7 61.0 45.730.5 30.5 45.7 45.7 45.7 45.7 61.0 45.7 3 1.1 15.24 45.7 3 3.0 45.7 45.7 45.7 61.0 11.4 45.7 11.4 45.7 8.6 3.0 30.5 45.745.7 45.7 68.5 45.7 30.5 45.7 45.7 45.7 45.7 129.5 45.7 61.0 61.0 22.8 22.8 45.7 8.6 45.7 45.7 53.3 45.7 30.5 45.7 61.0 3.0 14.4 14.4 11.4 11.4 45.7 45.7 45.7 45.7 11.4 45.7 45.7 45.7 Min. 15.3 Min. 30.5 15.3 45.7 30.5 45.7 45.7 45.7 45.7 45.7 45.7 61.0 53.3 45.7 45.7 45.7 22.8 45.7 15.2 45.7 45.711.4 45.7 11.4 3.0 45.7 14.4 15.2 45.7 61.0 45.7 45.745.7 45.730.5 45.7 45.745.7 Min. 15.3 83.8 61.0 45.7 30.5 15.2 30.5 11.4 11.4 45.7 61.0 11.4 45.7 45.7 45.7 61.0 61.0 4 45.7 38.1 61.0 11.4 45.7 45.7 4 45.7 45.730.5 45.7 45.7 38.1 45.7 15.2 45.745.7 11.4 45.7 30.5 45.7 45.7 45.7 11.4 160.0 45.7 61.0 30.5 38.1 30.5 45.7 68.5 61.061.0 45.7 45.7 45.7 30.5 45.7 45.7 11.4 61.0114.3 11.445.745.7 45.7 45.7 45.7 45.7 45.7 45.7 45.7 30.5 68.5 38.1 45.7 45.7 61.0 160.0 114.3129.5 45.7 45.761.0 45.7 11.4 11.4 45.761.061.0 30.5 45.7 53.3 1.1 15.24 30.5 45.7 1.1 15.24 83.8 45.7 45.7 30.5 45.7 30.5 1.1 15.24 68.5 45.7 61.0 8 45.7 45.7 45.7 45.7 8.6 3.0 3.014.4 11.4 45.7 45.7 45.7 Min. 15.3 8.6 15.24 99.0 99.0 30.5 45.7 61.0 61.0 1.1 45.761.0 30.5 45.7 11.4 11.4 45.7 30.545.7 45.7 61.0 22.8 45.7 11.411.445.745.7 30.545.7 8.6 61.0 45.7 45.7 53.3 3.0 14.4 30.545.7 45.7 Min. 15.3 45.7 61.0 45.7 45.7 45.7 45.7 61.0 22.8 11.4 8.6 45.7 53.3 68.5 15.2 15.2 45.7 45.7 45.745.7 45.7 61.0 30.5 45.7 Min. 15.3 30.545.714.4 30.5 11.4 45.7 45.7 45.7 61.0 11.4 45.7 4 45.7 45.7 11.4 45.7 61.0 30.545.7 45.7 45.7 61.0 4 45.7 45.7 61.0 45.7 15.2 45.7 61.0 61.0 38.1 38.1 61.0 11.4 45.7 45.7 45.7 45.7 30.5 45.7 11.4 61.0 61.0 45.7 45.7 30.5 45.7 45.7 45.7 30.5 45.7 61.0 45.7 45.7 30.5 45.7 114.3 114.3 45.7 45.7 45.7 160.0 68.5 68.5 38.1 160.0 45.7 114.3 11.4 61.061.0 30.5 61.0 61.0 11.4 45.7 45.7 45.761.0 30.5 45.7 30.5 61.0 160.0 114.3 11.4 11.4 45.7114.3 30.5 45.7 61.0 83.8 45.7 30.5 30.5 45.7 114.3 45.7 30.5 45.7 11.4 45.7 45.7 1.1 15.24 1.1 15.24 3.0 160.0 8 30.5 11.4 61.0 30.5 45.7 30.5 14.4 11.4 45.7 45.7 45.7 Min.68.5 15.3 30.5 45.7 61.0 45.7 61.0 1.1 15.24 11.4 61.0 3.0 45.7 30.5 30.5 45.7 61.0 30.5 45.7 8.6 68.5 11.4 45.7 45.7 8.6 61.0 45.7129.5 30.5 45.7 129.5 129.5 11.4 45.7 45.7 61.012 53.3 3.0 45.7 30.5 11.4 8.6 53.3 15.2 30.5 61.0 45.7 83.8 45.7 61.0 144.7 144.7 45.7 61.0 .5 53.3 15.2 61.0 45.7 45.7 45.7 61.0 30.5 45.7 45.7 45.7 11.4 61.0 61.0 61.0 1 45.7 30.5 4 45.7 53.3 4 45.7 61.0 45.7 45.7 30.545.7 61.0 61.0 11.4 45.7 45.715.2 61.0 45.7 45.7 38.1 61.0 45.7 11.4 45.7 83.8 144.7 45.7 61.0 30.5 45.7 45.7 45.7 45.7 61.0 45.7 30.5 45.7 45.7 45.7 61.0 45.7 45.7 45.7 61.0 68.5 38.1 45.7 61.0 11.4 45.7 160.0 61.0 45.7 45.7 160.0 30.5 45 45.7 61.0 45.7 45.7 11.4 61.061.0 11.4 61.0 61.0 11.4 45.7 61.0 1.1 15.24 14.4 11.4 45.7 45.7 45.7 45.7 30.5 45.7 Min. 15.3 30.5 99.0 99.0 30.5 45.7 45.7 45.7 45.7 30.5 45 3.0 160.0 61.0 45.7 30.5 61.0 11.4 45.7 11.4 61.0 30.5 1.1 15.24 11.4 45.7 83.8 61.0 45.7 45.7 30.5 45.7 8 8.6 45.7 45.7 45.7 11.4 45.7 30.5 14.4 11.4 45.7 45.7 45.7 30.5 Min.61.0 15.3 11.4 61.0 30.5 68.5 30.5 61.0 61.0 45.7 45.7 45.7 1.1 15.24 61.0 45.730.5 11.4 45.7 45.7 11.4 11.4 11.4 45.7 45.7 45.7 8.6 61.0 68.5 15.2 45.7 30.5 11.4 45.7 45.7 30.5 30.5 83.8 45.7 45.7 11.4 61.0 129.5 45.7 61.0 129.5 61.0 45.7 11.4 61.0 45.7 45.7 30.5 11.4 8.6 30.5 53.3 53.3 61.045.7 83.8 45.7 61.0 144.7 45.730.5 11.4 11.4 45.7 45.745.7 61.0 61.0 1 61.0 45.7 53.3 11.4 45.745.7 30. 45.7 30.5 11.4 45.7 45.7 61.0 45.7 61.0 45.7 61.0 61.0 45.7 45.7 30.5 45.7 83.8 45.7 61.0 114.3 45.7 30.5 61.0114.3 45.7 45.7 45.730.5 45.7 45.7 160.0 45.7 30.5 11.4 45.7 45.7 11.4 11.4 45.7 45.7 45.7 45.7 3.0 45.7 61.0 45.7 61.0 45.7 30.5 45 45.7 45.7 61.0 11.4 45.7 45.730.5 61.0 15.24 14.41.1 45.7 61.0 30.5 45.7 11.4 45.7 45.7 .7 61.0 Min. 15.3 30.5 45.7 160.0 45.7 30.5 45 11.4 61.0 45.7 45.7 61.0 30.5 45.7 45.7 45.7 45.730.5 45.7 45.7 45.7 30.5 83.8 11.4 45.7 45.7 45.7 45.7 61.0 3.0 45.7 30.5 45.7 160.0 30.5 8.6 45.7 45.7 45.7 45.7 45.7 45.7 11.4 61.0 30.5 15.2 30.5 45.7 45.7 61.0 30.5 45.7 11.4 45.7 11.4 30.5 45.7 45.7 30.5 61.0 45.7 11.4 45.7 30.5 68.5 30.5 45.7 45.7 45.730.5 45.7 45.7 61.0 68.5 45.7 30.5 45.7 11.4 45.7 45.7 30.5 45.7 45.7 11.4 61.0 45.7 45.7 61.0 3 68.5 45.7 30.5 45.7 45.7 83.8 45.7 45.7 15.2 45.7 30.5 45.7 30.5 45.7 30.5 45.7129.5 30.5 45.7 30.5 83.8 83.8 129.5 11.4 45.7 30.5 45.7 11.4 61.0 11.4 45.7 45.7 30.5 53.3 45.7 45.7 45.7 68.5 61.0 45.7 45.730.5 11.4 11.4 45.7 129.5 45.7 45.7 61.0 129.5 45.7 45.7 45.730.5 45.7 1 61.0 61.0 53.3 45.7 45.7 30.5 11.4 11.4 45.745.7 45.7 45.7 45.7 45.7 30.5 61.01.1 30.5 45.7 45.7 45.7 30.5 45.730.5 45.7 15.2445.7 61.0 160.0 45.7 45.7 30.5 45.7 11.4 45.783.8 30.5 45.7 45.7 45.7 3.0 61.0 11.4 45.7 61.0 30.5 45.7 45.7 45.7 45.730.5 11.445.7 83.8 144.7 99.0 45.7 30.5 45.7 45.7 30.599.0 45 45.7 45.7144.7 8.6 61.0 1.1 15.24 14.4 45.7 30.5 61.0 11.4 45.7 45.7 45.7 Min. 15.3 99.0 99.0 160.0 160.0 45.7 30.5 45.7 5.7 45.7 30.5 45 45.7 45.7 30.5 61.0 45.7 30.5 45.7 15.2 30.5 45.7 30.5 45.7 45.7 45.730.5 11.445.745.7 45.7 61.0 45.7 45.7 30.5 45.7 30.5 45.7 8.6 45.7 45.7 61.0 45.7 30.5 11.4 45.7 45.7 30.5 45.7 45.7 61.0 45.7 30.5 45.7 30.5 11.4 45.7 45.7 30.5 45.7 30.5 45.7 11.4 45.7 30.5 99.0160.0 61.0 3 68.5 45.7 45.7 83.8 45.7 68.5 61.0 45.7 30.5 45.7 11.4 61.0 45.7 45.7 45.7 30.5 11.4 61.0 45.7 61.0 45.7 30.5 45.745.745.7 30.5 45.7 11.4 45.7 30.5 83.8 45.7 68.5 30.5 45.7 45.7 45.7 30.5 61.0 11.4 11.4 45.7 45.7 30.5 11.4 45.7 45.745.7 30.5 61.0 30.5 11.4 45.7 30.5 45.7 30.5 114.3 114.3 45.7 45.7 45.7 45.7 45.7 61.0 45.7 45.7 30.5 11.4 45.7 129.5 45.7 30.5 129.5 11.4 11.4 45.7 160.0 30.5 45.7 61.0 61.0 30.5 45.7 1.1 15.24 61.0 45.7 11.4 61.0 45.730.5 45.7 45.7 11.4 45.7 45.7 45.745.7 45.7 45.7 30.5 45.7 30.5 30.511.4 45.7 61.0 61.0 45.7 30.5 45.7 160.045.7 45.7 30.5 45.7 45.7 45.7 83.8 30.5 11.4 45.7 99.0 99.045.7 45.7 45.7 30.5 3.0 8.6 61.0 61.0 30.5 45.7 30.5 61.0 45.7 11.4 99.0 83.8 99.045.7 45.730.5 11.4 45.7 45.7 45.745.7 144.7 144.7 45.7 61.0 30.5 45.7 30.5 11.4 45.7 45.7 30.5 45.7 45.7 30.511.445.745.7 61.0 45.7 99.0 45.7 160.0 45.7 45.7 30.5 45.7 45.7 45.7 30.5 45.7 30.5 45.7 61.0 11.4 45.7 15.2 30.5 45.7 61.0 144.7 144 45.7 61.0 30.5 45.7 45.7 61.0 45.7 30.5 45.7 45.7 45.7 30.5 45.7 45.730.5 5 99.0 45.7 61.0 30.5 45.7 129.5 45.7 129.5 45.7 45.7 45.7 30.5 61.0 3 68.5 83.8 11.4 45.7 61.0 61.0 11.4 45.7 45.7 30.5 45.7 45.745.7 45.7 61.0 30.5 45.7 61.0 61.0 45.7 11.4 61.0 45.7 30.5 61.0 45.7 30.5 45.7 45.7 45.730.5 45.7 11.4 11.4 45.7160.0 45.7 30.5 45.7 45.7 22.8 68.5 45.7 11.4 45.7 45.730.5 45.715.3 45.7 45.7 30.5 14.4 11.4 45.7 45.7 45.7 Min. 30.5 11.4 45.7 99.0 99.0 11.4 61.0 61.0 11.4 45.7 61.0 45.7 30.5 45.7 30.5 45.7 45.7 45.7 45.7 45.745.7 30.516924 11.4 45.7 61.0 Part Nos. 16920/16921 16922 16923 45.730.5 45.7 45.7 45.7 1.1 15.24 61.0 61.0 45.7 30.5 45.7 11.4 45.7 45.7 45.7 45.7 45.7 45.7 45.7 45.7 11.4 11.4 45.7 45.7 45.730.5 45.7 30.5 30.5 83.8 30.545.7 45.7 45.7 61.0 45.730.5 99.0 99.0 11.4 45.745.7 61.0 83.8 30.5 45.7 45.7 11.4 11.4 61.045.7 45.7 45.7 45.7 45.7 45.7 45.7 11.4 45.7 45.7 30.5 8.6 61.0 61.0 45.7 99.0 99.045.745.7 83.8 99.0 45.7 144.7 45.7 45.7 45.7 11.4 11.4 45.7 45.7 45.730.5 144.7 45.7 30.511.4 45.7 11.4 144.7 11.445.7 45.7 45.7 45.7 61.0 45.7 61.0 83.8 144.7 11.4 45.7 R 30.5 45.745.7 Color (G=green, Y=yellow, R=red) G 11.4 Y45.7 R30.5 G Y B G Y W G Y R 45.7 45.7 45.7 30.5 R 61.0 61.0 5 45.7 61.0 45.7 61.0 45.7 30.5 45.7 45.7 45.7 45.730.5 45.7 11.4 11.4 45.799.0 45.7 45.7 45.7 45.7 45.7 45.7 30.5 11.4 45.7 30.5 45.7 45.7 45.7 61.0 61.0 45.7 45.7 30.5 99.0 99.0160.0 160.0 61.0 61.0 11.4 45.7 45.7 45.7 45. 11.4 61.0 45.7 45.7 11.4 45.7 45.7 45.7 45.7 3.0 22.8 11.4 61.0 30.5 45.715.3 45.7 114.3 45.7 30.5 45.7 45.7 114.345.7 Min. 45.7 45.7 61.0 1.0 45.7 45.7 45.7 45.7 160.0 45.7 45.7 45.7 45.7 45.7 45.7 23 45.7 Codes 30.5 02 04 0845.7 45.7 45.7 02 04 08 14.4 00 20 40 45.7 65 8011.445.7 45 88 30.5 11.4 45.7 11.4 61.0 61.0 11.4 61.0 45.7 30.5 30.5 45.7 45.7 Color30.5 11.4 45.745.7 30.5 45.7 45.7 30.5 11.4 45.7 30.5 45.7 45.7 15.2 45.7 45.7 11.4 45.7 45.7 45.7 45.7 45.7 11.4 61.0 45.7 45.7 45.7 45.7 45.7 45.7 30.5 45.7 11.4 45.7 45.7 45.7 45.7 45.7 45.7 45.7 45.7 11.4 11.4 45.7 45.7 45.730.5 114.3 45.7 30.5 45.7 30.5 45.7 61.0 30.5 45.7 11.4 45.7 11.4 61.0 61.045.7 83.8 45.745.7 30.5 45.7 45.7 11.4 45.783.8 30.5 30.5 45.7 45.7 45.7 45.7 30.5 45.7 11.4 11.4 45.7 45.7 45.730.5 38.1 45.7 45.7 45.7 45.7 61.0 45.7 45.7 45.745.7 99.0 45.7 45.711.4 45.745.7 11.4 45.7 45.7 5.7 30.5 11.4 45.7 45.7 30.5 45.7 45.7 45.7 11.4 45.7 45.7 45.7 129.5 83.8 129.5 ABSOLUTE 61.0 45.7 MAXIMUM 30.5 45.7RATINGS (Ta=25°C) 11.4 45.7 61.0 45.7 45.799.0 99.0 30.5 11.4 45.7 45.7 11.4 45.7 45.7 45.7 45.7 30.5 45.7 45.7 45.7 45.7 61.0 5 11.4 45.7 45.7 45.7 30.5 45.7 30.5 45.7 45.7 45.7 45.7 11.4 61.0 0 45.7 45.7 45.7 30.5 45.7 1.1 15.24 45.7 45.7 45.730.5 45.7 45.7 11.4 45.7 45.7 61.0 11.4 99.0 45.7 99.0 45.7 61.0 45.7 30.5 45.7 45.7 3.0 45.7 30.5 61.0 45.7 30.5 45.7 11.4 114.3 114.3 45.7 30.5 45.7 99.0160.0 45.7 150 30.511.445.745.7 99.0 160.0 45.7 22.8 8.6 45.7 45.7 45.7 45.7 45.7100 45.7 45.7 45.745.7 114.3 45.7 mW 45.745.7 10045.730.545.7 100 135 13545.7 135 14.4 10545.7 70 6011.4 300 45.7 45.7 130 45.7 Min. 15.3 61.0120 11.4 45.760 45.7 61.0 61.0Power 45.7 45.7 45.7114.345.7 45.7 30.5 11 45.7 30.5 15.2 45.7 30.5 45.7 45.7 45.7 45.7 45.7 30.5 45.7 45.7 45.7 30.5 114.3 11.4 45.7 30.5 11.4 45.7 45.7 45.7 45.7 11.4 45.7 45.7 45.730.5 45.7 45.7 61.0 83.8 144.7 144.7 45.7 61.0 45.7 45.7 30.5 45.7 45.745.7 38.1 45.7 45.7 45.7 61.0 45.7 11.4 45.7 30.5 11.4 11.4 45.7 45.7 30.5 45.7 30.5 45.730.5 45.7 45.7 45.7 45.7 83.8 30.5 45.7 45.7 45.7 30.5 40 45.7 30.5 11.4 45.7 20 11.4 45.720 45.7 45.7 45.7 45.7 30.5 45.7 Current61.0 forward mA 30 30 30 30 30 3011.4 11.4 30 20 114.3 25 40 90 45.7 45.7 11.4 45.7 45.7 61.0 45.7 45.7 83.8 45.7 30.5 45.7 114.3 61.0 99.0 99.0 11.4 45.7 45.7 30.511.4 61.0 30.5 45.7 45.7 45.7 45.745.7 160.0 45.7 45.7 45.7 30.5 45.7 45.7 45.7 45.7 45.7 30.5 0 45.7 30.5 45.7 30.5 1.1 15.24 45.7 61.011.4 45.7 11.4 45.7 45.7 45.7 45.7 61.0 11.4 61.0 45.7 45.7 99.0 99.045.7 11.4 61.0 45.7 30.5 11.4 45.7 45.7 45.7 99.0 **45.7 ** ** 45.7 61.0 30.545.7 45.730.5 144.7 3.0 144.7 8.6 45.7 mA 45.7 50 50 90 45.7 90 20045.7 6045.7 60 100 45.799.06045.7 500 1000 114.3 114.3 45.7 90 30.5 45.750 30.5 114.3 99.0 99.0 160.0500 61.011.4 11.4 45.7 160.0 45.7 61.0 Forward peak current 30.5 45.7 45.7 45.7 61.0 11.4 99.0 45.7 11 61.0 114.3 61.0 45.7 61.0 45.7 30.5 99.0 45.7 45.730.5 30.545.7 45.7 45.730.5 160.0 45.7 11.4 11.4 45.7 160.0 45.7 45.7 53.3 45.7 30.5 15.2 11.4 45.7 45.7 45.7 83.8 45.7 30.5 45.7 30.5 11.4 45.7 45.7 61.0 45.7 45.7 45.7 45.7 114.3 61.0 11.4 45.7 61.0 61.0 45.745.7 30.5 45.7 61.0 30.5 45.7 11.4 45.7 45.730.5 45.7 61.0 11.4 45.7 45.7 45.7 114.3 45.7 30.5 45.7 30.5 45.7 30.5 38.1 Voltage reverse V 545.7 5 5 45.7 545.7 5 5 5 11.4 45.7 3 30.5 114.3 3 129.5 5 3 12 12 5 11.4 61.0 11.4 45.7 11.4 45.745.7 160 160.0 45.7 30.5 45.7 45.7 61.0 129.5 45.7 11.4 61.0 61.0 45.7 45.7 30.5 160.0 45.7 61.0 45.7 99.0 99.0 45.7 45.7 45.730.5 45.7 61.0 11.4 45.7 45.7 30.511.4 61.0 11.4 45.7 45.7 45.7 45.7 30.5 45.7 45.7 45.7 30.5 45.745.7 11.4 11.4 45.7 45.7 45.7 45.7 61.0 45.7 11.4 45.761.011.4 0 45.7 61.030.5 1.1 15.24 45.7 129.5 45.7 45.7 61.0 45.7 45.7 61.0 45.7 45.7 61.0 45.7 11.4 45.7 45.7 45.7 Operating 45.7 45.730.5 45.7 30.5 45.7 30.5 45.7 45.7 11.4 45.7 99.0 45.7 -25 / 61.0 11.4 45.799.0 45.7 99.0 11.4 45.7 99.0 45.7 114.3 45.7 61.0 45.7 45.7 8.6 45.711.4 30.5 °C 45.7 -25 / +100 -55 / +100 +85 -55 / +100 45.7 61.0 30.5 45.7 45.7 45.7 61.0 11.4 45.7 61.0 11.4 99.0 45.7 45.7 45.7 45.7 61.0 45.7 61.0 83.8 144.7 144.7 99.0 30.5 11.4 45.7114.3 45.7 45.730.5 temperature 45.7 45.7 11 53.3 45.7 30.5 45.7 61.0 45.7 61.0 45.7 45.7 11.4 45.7 11.4 45.7 11.4 45.7 45.7 45.7 45.7 45.7 45.7 30.5 45.7 45.7 61.0 11.4 45.7 45.7 45.7 45.7 61.0 45.7 61.0 83.8 30.5 11.4 45.7 45.7 61.0 45.7 61.0 30.5 45.7 45.7 45.7 45.7 114.3 45.7 11.4 45.7 11.4 61.0 11.4 45.7114.3 30.5 45.7 45.7 30.5 45.7 45.7 61.0 45.7 45.7 61.0129.5 11.4 45.7 45.7 30.5 45.7 114.3 114.3 45.7 45.7 129.5 45.7 / +100 45.745.7 -55 45.7 45.7 11.4 45.7 45.7 61.0 Storage temperature °C -25 / +100 -30 / +100 -55 / +100 45.7 61.0 129.5 45.7 61.0 45.7 45.7 11.4 45.7 30.5 45.7 11.4 61.0 45.7 30.5 45.7 30.5 45.7 45.7 45.7 45.7 61.0 45.7 160.0 45.7 61.0 45.7 45.7 45.7 45.7 45.7 61.0 11.4 45.7 11.4 30.5 45.7 61.0 45.745.7 45.7 45.761.0 11.4 45.7 45.7 45.7 61.0 129.5 45.7 45.7 45.7 45.745.7 45.7 45.7 30.5 99.0 160.0 160.0 61.0 45.7 61.0 45.7 61.0 45.799.0 45.7 30.5 45.7 11.4 30.5 45.7 45.7 45.7 11.4 11.4 45.7 45.7 11.4 11.4 45.7 45.7 45.7 45.7 45.7 45.7 45.730.5 99.0 45.7 45.7 45.7 45.7 30.5 45.7 °C 45.7 45.7 for max. 61.0 45.7 +300 45.745.7 45.7 11.4 45.7 11.4 45.799.0 45.7for max. 5 sec 61.0 Soldering +245 3 sec +300 for max. 3 sec +260 for max. 311.4 sec45.7 45.7 61.0 7 45.7 45.7 83.8 45.7temperature 30.5 68.5 61.0 61.0 45.7 61.0 45.7 30.5 45.7 99.0 99.0 129.5 11.4 45.7 30.5 11.4 45.7 45.7 61.0 11.4 129.5 11.4 45.7 45.7 45.730.5 45.7 45.7 53.3 61.0 11.4 45.7 45.7 30.5 45.745.7 45.7 45.7 45.7 45.7 61.0 11.4 45.7 45.7 45.7 45.7 45.7 30.5 45.7 45.7 45.7 45.7 45.7 11.4 45.7 30.5 61.0 11.4 61.0 45.7 61.0 45.7 30.5 45.7 45.7 30.5 11.4 45.7 45.7 61.0 114.3 114.3 11.4 45.7 45.7 45.7 30.5 61.0 11.4 114.3 114.3 45.7 45.7 45.7 45.7 61.0 45.7 45.7 45.7 30.5 45.745.7 114.3 45.7 114.3 45.7 ELECTRICAL-OPTICAL CHARACTERISTICS (Ta=25°C) 45.7 129.5 11.4 45.7 45.7 129.5 45.761.0 45.7 114.3 129.5 114.3 45.7 11.4 30.5 45.7 45.7 61.0 45.7 30.5 45.7 45.7 45.7 61.0 11.4 45.7114.3 30.5 45.7 45.7 45.745.7 45.730.530.5 45.7 45.7 114.3 11.4 45.7 45.7 45.7 45.7 45.730.5 45.7 45.745.7 61.0 45.7 45.7 61.0 11.4 45.7 45.7 45.7 99.0 45.7 99.0 45.7 45.7 45.7 129.5 45.7 45.7 61.0 45.7 61.0 45.7 45.7 45.730.5 45.7 45.7 61.0 45.7 30.5 45.7 11.4 11.4 45.7 45.7 30.5 45.7 11.4 45.711.4 30.5 45.7 45.745.7 30.5 30.5 45.7 45.7 45.7 45.7 61.0 Voltage45.7 forward Typ. V 2.045.7 2.0 2.0 2.1 2.2 2.3 2.1 2.1 45.7 129.5 2.1 3.8 45.7129.5 2.030.511.445.745.7 2.1* 2.3*** 2.4*** 45.7 11.4 45.7 7 45.7 129 45.7 45.7 45.7129.5 30.5 45.7 45.7 68.5 11.4 45.7 45.7 61.0 61.0 144.7 144.7 45.7 30.5 45.7 45.7 11.4 45.783.8 30.5 45.7 30.5 45.7 45.7 45.7 30.5 45.7 45.7 30.511.4 11.4 45.7 61.0 45.7 61.0 45.7 30.5 45.7 45.7 45.7 45.7 11.4 45.7 45.745.7 61.0 61.0 11.4 45.7 45.7 45.7 45.7 61.0 11.4 45.7 45.7 61.0 45.7 30.5 45.7 30.5 45.7 45.7 45.7 3.8*** 11.461.0 45.7 30.5 11.4 3.0 45.7 45.745.7 3.0 30.5 144.7 30.5 45.7 45.7 3.0 45.7 61.0 45.7 30.53.0 45.7 114.3 114.3 45.7 45.7 Max. V 3.0 3.0 3.0 3.0 2.8 3.0 4.3 2.5* 2.5*** 61.0 11.4 45.7 114.3 45.7 114.3 45.7 45.7 45.7 114.3 45.7 61.0 61.0 11.4 45.7 30.5 45.7 45.7 45.7 30.5 45.7 45.7 61.0 61.0129.5 45.7 11.4 11.4 45.7 45.7 114.3 45.745.745.7 30.5 61.0 45.7 45.7 45.7 11.4 61.0 45.7 30.5 45.7 11.4160.0 45.7 30.5 99.0 114.3 30.5 114.3 45.7 30.5 45.7 45.7 160.0 11.4 99.0 45.7 45.7 45.7 45.7 45.7 45.7 11.4 45.7 61.0 11.4 45.7 45.7 61.0 30.5 45.7160.0 160.061.0 45.7 61.0 45.7 61.0 45.7 45.7 45.7 11.4 45.7 45.7 30.5 45.7 30.5 45.7 99.0 45.7 45.7 45.7 61.0 45.7 61.0 45.7 30.5 11.4 10 45.7 30.5 45.7 Current reverse45.7 61.0 µA 100 100 100 100 100 45.7 11.4 2 45.799.0 45.7 10 10 50 45.745.7129.5 10 1030.5 129.5 129.5 45.710 45.7 45.7 30.530.511.4 45.7 11.4 129 45.7 45.7 100 30.5 45.7 45.7 61.0 11.4 45.7 30.5 45.7 7 45.7 129.5 45.7 61.0 45.7 61.0 61.0 144.7 144.7 129.5 11.4 45.7 68.5 45.7 61.0 144.7 45.7 30.5 45.7 45.7 45.7 11.4 45.745.7 30.530.511.4 11.4 45.7 45.7 61.045.7 45.7 45.7 61.0 30.5 45.7 45.7 45.7 30.5 45.7 45.7 61.0 11.461.0 45.7 30.5 45.7 61.0 45.7 61.0 45.7 11.4 45.7 30.5 45.7 11.4 45.7 61.0 45.7length61.045.7 144.7 30.5 45.7 45.7 56530.5 45.7 45.7 Wave nm 560 590 660 585 635 460 563 585 NA 650 570 587 635 45.7 45.7 114.3 114.3 45.7 30.5 45.7 45.7 45.7 61.0 61.045.7 45.7 30.5 45.7 114.3 114.3 45.7 45.7 45.7 61.0 61.0 11.4 11.4 45.7 45.7 45.7 61.0 45.7 61.0 114.3 114.3 11.4 11.4 45.7 45.7 30.5 45.7 61.0 11.4 45.7 99.0 61.0 11.4 45.7 45.7 30.5 45.7 45.7 30.5 45.7 45.7 30.5 61.045.7 99.0 45.7 45.7 11.4 45.7114.3 30.5 45.7 45.7 45.7 30.5 114.3 45.7 30.5 45.7 45.7 61.0 45.7 45.7 83.8 11.4 45.7 45.7 61.0 45.7 11.4 11.4 45.7 45.7 144.7 11.4 45.7 144.7 61.0 45.7 61.0 45.7 11.4 30.5 45.7 45.7 45.7 45.7 30.5 45.7 45.740 61.0 40 45.7 45.7 61.0 Ønm 10 10 10 10 10 40 NA 45.7 40 25 45 45.745 45.7 11.4 45.7 45.7 11.4 45.7 30.5 45.7 Spread 30.5 30.510 45.7 45.7 61.0 45.7 45.7 45.7 11.4 45.7 11.4 45.7 45.7129.5 30.5 45.7 129.5 129.5 45.7 129.5 30.5 45.7 61.0 45.7 129 45.7 45.7 61.0 45.7 30.5 45.7 129.5 45.7 45.7 45.7 11.4 45.7 45.7 30.5 45.7 45.7 61.0 129.5 45.7 144.7 45.7 61.0 144.7 144.7 129.5 30.5 45.7 45.7 11.4 45.7 11.4 45.7 61.0 45.7 45.7 45.7 30.5 45.7 11.4 45.7 129.5 45.7 61.0 11.4 61.0 11.445.7 45.7 30.5 45.7 45.7 129.5 45.745.7 45.7 61.0 11.4 45.7 45.7 45.7 45 30.5 45.7 45.7 45.7 angle 61.0 Spread degree 20 45.7 20 2045.7 45.7 4530.5 45 45.7 20 30.5 114.3 45 45 25 45 114.3 25 45 45 45.7 61.0 45.7 30.561.0 144.7 45.7 45.7 45.7 45.7 45.7 45.7 45.7 11.4 45.711.4 45.7 45.7 45.7 11.4 45.7 45.7 45.7 45.7 61.0 45.745.7 45.7 45.7 45.745.7 61.0 61.0 11.4 45.7 61.0 144.7 11.4 45.7 45.7 30.5 45.7 144.7 45.7 30.5 45.7 45.7 61.0 61.0 61.0 11.4 45.7 45.730.511.445.745.7 11.4 45.7 45.7 45.7 61.0 11.4 45.7 45.7 30.5 45.7 160.0 99.0 45.7 45.7 45.7 45.7 30.5 45.7 83.8160.0 11.4 45.799.0 45.7 45.7 61.0 45.7 45.7 61.0 45.7 30.5 45.7 45.7 45.7 45.7 45.7 45.7 45.745.7 61.0 11.4 45.7 30.5 45.7 Min. mcd 61.0 45.7 45.7 61.0 2.5 45.730.511.4630 11.4 45.7 Luminous Intensity 1 1 0.8 45.7 1.5 2.5 20 9.011.4 5.6 5.6 71**** 100**** 45.7 11.4 45.7 11.4 45.771**** 30.5 45.7 30.5 45.7 45.7 45.7 45.7 30.5 45.7 45.7 45.7 45.7 45.7 11.4 45.7 30.5 45.7 45.7 11.4 45.7 45.745.7 45.745.7 45.761.0 61.0 45.7 30.5 45.7 30.5 45.7 160.0 45.7 45.7 45.7 45.7 61.0 45.7 11.4 45.7 30.5 45.7 11.4 45.7 129.5 45.7 61.0 129.5 129.5 45.7 129.5 30.5 61.0 11.4 45.7 45.7 45.7 45.730.5 45.745.7 11.4 45.7 30.5 45.7 30.5 45.7 45.7 45.7 45.7 45.7 61.0 11.4 114.3 45.7 30.5 45.7 45.7 45.7 11.4 45.7 11.4 45.7 129.5 144.7 45.7 45.7 114.3 61.0 45.7 45.7 45.7 129.5 45.7 45.7 45.7 61.0 11.4 45.7 45.7 61.0 11.4 45.7 45.7 30.5 45.7 61.0 Typ. 1.6 2.5 3.0 5.0 25 30.5 25 129.5 16 11.4 1000 112**** 160**** 129.5 45.7 30.5 16 45.7 112**** 45.7 45.7 345.730.5 45.7 45.7 45.7 30.5 45.7 45.7 mcd 30.5 45.7 2 45.7 45.7 45.7 11.4 114.3 45.7 45.7 61.0 45.7 45.7 45.7 114.3 45.7 45.7 45.7 45.7 61.0 11.4 61.0 45.7 45.7 45.7 30.5 45.7 45.7 144.7 11.4 45.745.7 45.745.7 45.7 11.4 45.7 144.7 30.5 11.445.7 45.7 45.7 61.0 45.7 30.5 45.7 61.0 45.7 45.7 45.7 30.5 45.7 45.7 30.5 45.7 61.0 45.7 11.4 45.7 160.0 144.7 144.7 160.0 45.7 45.7 30.511.4 45.7 45.7 30.5 45.7 45.7 45.7 30.5 45.7 45.7 45.7 45.7 160.0 45.7 is the 30.5 anode, 45.7 11.4 45.745.7 45.745.7 45.7the cathode. 61.0 11.445.745.783.8 30.5 45.7 61.0 30.5 Orientation pin the shorter is 45.7 45.7 45.7 45.7 45.7 45.7144.745.7 45.7 45.7 30.5 45.7The longer 144.7 45.7 30.5 45.7 45.7 30.5 45.7 45.7 45.7 45.7 45.7 11.4 45.7 30.5 45.7 11.4 45.7 30.5 45.7 45.7 45.7 45.7 45.7 45.7 30.5 45.7 45.7 160.0 129.5 45.7 61.0 129.5 45.7 45.7 45.7 30.530.5 45.7 30.5 45.7 45.7 45.7 45.7 61.0 11.4 45.7 45.7 11.4 45.7 30.5 45.7 45.7 45.7 30.5 45.7 45.7 30.5 45.7 129.5 45.7 129.5 11.4 45.7 30.5 45.7 11.4 114.3 45.7 30.5 45.7 45.7 45.7 30.5 45.7 45.7 114.3 45.7 45.7 45.7 45.7 45.7 45.7 61.0 11.4 45.7 129.5 45.7 45.7 45.7 129.5 45.7 45.7 45.7 30.5 45.7 45.7 129.5 30.5 99.0 99.0160.0 11.4 45.7 61.0 11.4 45.7 61.0 11.4 45.7 160.0 129.5 45.7 30.5 45.7 45.7 45.7 11.4 45.7 45.7 45.7 45.7 45.7 45.7 30.5 45.7 45.7 61.0 45.7 45.7 30.5 45.7 45.7 30.5 45.7 45.7 45.7 11.4 45.7 45.7 45.7 45.7 45.7 45.7 30.5 61.0 11.4 45.7144.7 45.7 144.7 45.7 61.0 30.5 11.445.7 45.7 45.7 11.4 45.7 45.7 30.5 144.7 144.7 45.7 11.4 45.7 45.7 30.5 45.7 45.7 45.7 160.0 144.7 160.0 144.7 160.0 45.7 30.5 45.7 45.7 30.5 45.7 45.7 11.4 45.7 30.5 45.7 45.7 45.7 30.5 45.7 45.7 45.7 45.7 61.0 30.5 11.445.745.7 144.7 45.7 61.0 144.7 144.7 144.7 45.7 30.5 45.7 11.4 45.7 30.5 45.745.7 45.7 45.7 45.7 11.4 45.7 30.5 45.7 45.7 30.5 45.7 45.7 30.5 45.7 129.5 129.530.5 45.7 45.7 45.7 45.7 45.7 45.7 45.7 30.5 45.7 160.0 61.0 11.4 45.711.4 45.7 45.7 61.0 11.4 45.7 45.7 61.0 45.7 30.5 45.7 45.7 30.5 160.0 45.7 160.0 45.7 11.4 45.7 45.7 45.7 11.4 45.7 45.7 45.7 11.4 45.7 30.5 45.7 30.5 45.7 30.5 45.7 11.4 114.3 45.7 30.5 45.799.0 114.3 45.7 45.7 45.7 45.7 45.7 45.7 99.0 61.0 11.4 45.7 45.7 45.7 30.5 45.761.0 45.7 30.5 129.5 11.4 45.7 30.5 45.7 129.5 45.7 11.4 45.7 45.7 45.7 30.5 45.7 45.7 45.7 30.5 45.7 45.7 45.7 45.7 11.4 45.7 45.7 45.7 11.4 45.7 45.7 11.4 45.7 45.7 45.7 45.7 61.0 45.7 30.5 45.7 61.0 30.5 45.715.3 Min. 15.2 68.5 53.3 11.4 45.7 45.7 41.9 57.1 41.9 68.5 68.5 68.5 68.5 68.5 68.5 68.5 68.5 68.5 mec a/s Jan. 2002 7.1 .953.3 68.5 68.5 68.5 68.5 68.5 68.5 68.5 68.5 .5 68.5 68.5 68.5 68.5 68.5 68.5 68.5 68.5 68.5 68.5 68.5 68.5 68.5 68.5 68.5 38.1 38.1 38.1 38.1 68.5 68.5 22.8 22.8 38.138.1 68.5 22.8 22.8 38.1 38.1 68.5 38.1 38.1 68.5 38.138.1 68.5 38.1 38.1 68.5 8.1 8.5 53.3 68.5 53.3 53.3 53.3 53.3 53.3 68.5 68.5 53.3 68.5 53.3 mec a/s Jan. 2002 mec a/s Jan. 2002 7.1 7.1 7.1 2.6 7.1 7.1 53.3 53.3 68.5 53.3 53.3 68.5 53.3 53.3 53.3 53.3 68.5 68.5 68.5 68.5 53.3 68.5 53.3 53.3 53.3 53.3 53.3 68.5 68.5 41.9 41.9 9 68.5 41.9 68.5 2.6 7.1 53.3 2.6 2.6 10.9 7.1 10.9 10.9 10.9 2.6 10.9 2.6 3.8 3.0 4.1 3.8 3.0 4.1 7.1 7.1 3.8 3.0 4.1 53.3 3.8 3.0 4.17.1 2.6 7.1 10.9 3.8 3.0 4.1 2.6 2.6 41.9 7.1 41.9 41.9 7.1 41.9 7.1 41.9 41.9 53.3 53.3 53.3 41.9 53.3 53.3 53.3 41.9 53.3 53.3 53.3 53.3 41.9 53.3 53.3 53.3 53.3 41.9 53.3 53.3 53.3 41.9 53.3 41.9 41.9 53.3 53.3 41.9 53.3 41.9 53.3 53.3 53.3 53.3 53.3 53.3 53.3 53.3 53.3 7.1 1.5 53.3 1.5 41.9 1.5 53.3 1.5 7.1 10.9 3.8 3.0 4.1 2.6 22.8 38.1 53.3 53.3 .8 3 53.3 53.3 38.1 38.1 38.1 38.1 38.1 53.3 53.3 53.3 53.3 38.1 53.3 22.8 22.8 22.822.8 22.8 22.8 53.3 53.3 53.3 53.3 53.3 53.3 38.1 38.1 38.1 38.1 38.1 53.3 53.3 53.3 38.1 22.8 22.8 22.822.8 22.8 22.8 53.3 53.3 53.3 53.3 53.3 53.3 53.3 53.3 53.3 53.3 53.3 53.3 38.1 38.1 38.1 38.1 38.1 53.3 53.3 53.3 38.1 22.8 22.8 22.822.8 22.8 22.8 53.3 53.3 53.3 53.3 53.3 53.3 38.1 38.1 38.1 53.3 .1 53.3 38.1 38.1 38.1 38.1 38.1 38.1 38.1 38.1 22.8 53.3 53.3 53.3 53.3 53.3 53.3 53.3 38.1 38.1 38.1 38.1 38.1 38.1 38.1 38.1 38.1 38.1 38.1 38.1 38.1 38.1 38.1 38.1 38.1 38.1 38.1 38.1 38.1 38.1 38.1 38.1 38.1 38.1 38.1 53.3 53.3 53.3 53.3 3.8 3.0 3.8 3.0 4.138.1 3.8 3.0 4.1 4.1 38.1 53.3 38.1 38.1 53.3 10.9 10.9 53.3 10.938.1 38.1 38.1 38.1 38.1 38.1 38.1 22.8 22.8 38.1 53.3 53.3 53.3 38.1 38.1 38.1 53.3 38.1 38.1 38.1 22.8 3.8 3.0 4.1 3.8 3.0 4.138.1 22.8 4.1 53.3 53.3 53.3 53.3 38.1 38.1 3.8 3.038.1 38.1 38.1 22.8 22.8 22.822.8 22.8 22.8 22.8 1.5 1.5 1.5 38.1 53.3 38.1 38.1 10.9 10.9 10.9 22.8 22.8 22.8 22.822.8 22.8 38.1 38.1 38.1 53.3 53.3 53.3 53.3 53.353.3 38.1 38.1 38.1 22.8 22.8 22.8 22.822.8 22.8 53.3 53.3 3.8 3.0 4.1 3.8 3.0 4.1 3.8 3.0 4.1 53.3 53.3 53.3 53.3 53.3 53.3 1.5 1.5 1.5 53.3 53.3 53.3 53.3 53.3 53.3 53.3 53.3 10.9 10.9 53.3 53.3 53.3 53.3 1.5 1.5 1.5 53.3 53.3 3.8 3.0 3.8 3.0 4.1 4.1 10.9 53.3 10.9 53.3 10.9 53.3 53.3 53.3 53.3 53.3 3.8 3.0 4.1 3.8 3.0 4.1 3.8 3.0 4.1 53.353.3 53.3 53.3 53.3 53.3 53.3 53.3 53.3 53.3 41.9 53.341.9 53.3 53.3 53.3 53.31.5 1.5 53.3 53.3 41.9 53.3 53.3 41.9 53.3 53.3 53.3 53.3 53.3 1.5 1.5 1.5 41.9 53.3 41.9 53.3 53.3 2.6 2.6 2.6 53.3 41.9 41.9 41.9 41.9 41.9 53.3 53.3 10.9 38.1 38.1 38.1 38.1 38.1 38.1 38.1 38.1 38.1 38.1 38.1 38.1 38.1 38.1 38.1 38.1 38.1 38.1 10.9 53.3 10.9 38.1 38.1 38.138.1 38.1 38.1 38.1 38.1 38.1 38.1 38.1 38.1 38.1 68.5 38.1 38.1 38.1 68.5 53.3 38.1 38.1 38.1 38.1 38.1 38.1 38.1 38.1 68.5 38.1 68.5 38.1 38.1 38.1 68.5 38.1 68.5 38.1 22.8 22.8 22.8 22.8 38.1 38.1 68.5 38.1 mec 38.1 38.1 68.5 38.1 68.5 53.3 38.1 38.1 38.1 38.1 38.1 38.1 38.1 38.1 38.1 38.1 68.5 38.1 38.1 38.1 38.1 38.1 68.5 38.1 68.5 38.1 38.1 22.8 38.1 22.8 68.538.1 22.8 38.1 22.8 38.1 22.8 22.8 22.8 22.8 22.8 22.8 22.8 22.8 68.5 38.1 38.1 38.1 38.1 38.1 38.1 38.1 38.1 38.1 38.1 38.1 38.1 68.5 68.5 68.5 38.138.1 38.1 38.1 68.5 38.1 38.1 38.1 38.1 38.1 38.1 38.1 38.1 38.1 22.8 22.8 22.8 38.1 22.8 22.8 38.1 38.1 38.1 22.8 22.8 38.1 22.8 22.8 22.8 22.8 38.1 38.1 22.8 22.8 38.1 22.8 22.8 22.8 22.8 38.1 38.1 2.8 8.1 38.1 38.1 38.1 38.138.1 38.1 68.5 38.1 22.8 22.8 22.8 22.8 22.8 53.3 38.1 38.1 38.1 1.5 38.1 38.1 38.1 38.1 3.8 3.0 4.1 22.8 38.1 22.8 22.8 38.1 38.1 22.8 38.1 22.8 22.8 22.8 22.8 22.8 22.8 22.8 22.8 22.8 22.8 22.8 22.8 22.8 22.8 22.8 22.8 22.8 22.8 22.8 22.8 22.8 22.8 22.8 22.8 22.8 22.8 22.8 22.8 22.8 53.3 38.1 68.5 38.1 22.8 38.1 22.8 38.1 10.9 38.1 22.8 22.8 (1x1) For16.410 all types switches with bezels - 16310-16315 and 16324-163 16.431 (3x4) of UNIMEC 16.440 (4x4) (2x4) 3 (1x4) 16.420 (2x2) 16.411 (1x2)16.422 16.431 (3x3) (3x4) 16.440 (4x4) 16.422 (5x5) (2x4) (1x4) 414 (1x5) 16.423 16.450 16.432 (3x5) 16.432 16.441 (4x5) 16.441 16.412 (1x3) 16.430 16.421 (2x3) 16.410 (1x1) r all types of switches with -16.413 16310-16315 and 16324-16326 16.414 (1x5) (2x5) 16.423 (2x5) 16.450 (5x5) (3x5) (4x5) For allUNIMEC types of UNIMEC switches with bezels and 16324-16326 16.500 (10x10) 16.420 (2x2) - 16310-16315 16.411 (1x2) bezels 16.433 (3x 16.424 (2x6) 16.415 (1x6) 16.417 (1x8) 16.426 16.442 (4x6) 16.433 (3x6) 16.424 (2x6) 16.451 (5x6) 16.460 (6x6) 16.415 (1x6) 16.410 (1x1) 16.410(3x3) (1x1) 16.430 16.421 (2x3) 16.433 (3x 16.424 (2x6) 16.415 (1x6) 16.461 (6x7) 16.452 (5x7) 16.434 (3x7) 16.443 (4x7) 16.416 (1x7) 16.425 (2x7) 16.500 (10x10) (1x1) 16.420 (2x2)16.410 16.411 (1x2) 16.431 (3x4) 16.440 (4x4) 16.422 (2x4) 16.413 (1x4) 16.452 (5x7) 16.434 (3x7) 16.443 (4x7) 16.416 (1x7) 16.425 (2x7) 16.410 (1x1) 16.420 (2x2) 16.411 (1x2) mec·· Industriparken Industriparken rl types all types of switches with bezels - 16310-16315 and 16324-16326 For allUNIMEC types switches of UNIMEC switches bezels 16310-16315 and 16324-16326mec 16.500 (10x10) 16.420 (2x2) - (4x4) 16.411 (1x2) of UNIMEC with bezels -with 16310-16315 and 16324-16326 16.431 (3x4) 16.440 16.422 (2x4) For all types of UNIMEC switches with bezels 16310-16315 and 16324-16326 Tel.: +45 44 97 33 66 ·· Fax: +45 16.442 (4x6) x6) 16.451 (5x6) 16.460 (6x6) (3x 16.424 (2x6) 16.415 (1x6) 16.417 (1x8) 16.426 16.410 (1x1) 16.442 (4x6) 16.433 (3x6) 16.424 (2x6) 16.451 (5x6) 16.460 (6x6) 16.415 (1x6) 16.420 (2x2) Tel.: +45 44 97 33 6616.433 Fax: +45 16.411 (1x2) 16.433 (3x 16.424 (2x6) 16.415 (1x6) 16.500 (10x10) 16.431 (3x4) 16.440 (4x4)(2x7) 16.422 (2x4)16.421 (2x3)16.416 (1x7) 1x4)16.412 (1x3) 16.452 (5x7) 16.434 (3x7) 16.443 (4x7) 16.425 16.430 (3x3) 3) 16.410 (1x1) 416.425 (1x5) 16.423 (2x5) 16.450 (5x5) 16.432(3x7) (3x5) 16.441 (4x5) 16.42016.434 (2x2)16.412 16.411 (1x2) 16.420 (2x2) 16.411 (1x2) 16.431 (3x4) 16.440 (4x4) 16.422 (2x4) 16.413 (1x4) 16.461 16.452 (5x7) 16.443 (4x7) (2x7) 16.410 (1x1) 16.434 (3x 16.416 (1x7) 16.425 (2x7)(1x9) 16.441 (1x3) 16.430 (3x3) 16.421 (2x3) 16.414 (1x5) 16.423 (2x5) 16.432 (3x5) (4x5) 16.418 (1x9) 16.445 (4x9) (2x9) 16.436 (3x9) 16.418 16.427 16.434 (3x 16.416 (1x7) 16.425 For alltypes types of(2x2) UNIMEC switches bezels 16310-16315 and16324-16326 16324-16326 l types of UNIMEC switches with bezels with -with 16310-16315 and 16.427 16324-16326 16.500 (10x10) 16.420 (2x2) --16310-16315 16.500(2x7) (10x10) 16.411 (1x2) 16.431 (3x4) 16.440 (4x4) 16.422 (2x4) 16.420 16.411 (1x2) For all of UNIMEC switches bezels and 16.442 (4x6) 16.442 16.433 (3x6) (3x3) 16.424 (2x6) (2x3) 16.451 (5x6) 16.451 16.460 (6x6) (10x10) 41516.412 (1x6) (1x3) 16.500 16.430 16.412 (1x3) 16.430 (3x3) 16.421 (2x3) (4x6) 16.433 (3x6) 16.424 (2x6) (5x6) 16.460 (6x6) 16.415 (1x6)16.421 3) 16.410 (1x1) 16.410 (1x1) 16.434 (3x 16.416 (1x7) 16.425 (2x7) 16.412 (1x3) 16.430 (3x3) 16.421 (2x3) 16.420 (2x2) 16.411 (1x2) 16.414 (1x5) 16.423 (2x5) 16.432 (3x5) 16.441 (4x5) 16.461 (6x7) 16.452 (5x7) 16.434 (3x7) 16.443 (4x7) 16.418 (1x9) 16.416 (1x7) 16.427 16.425 (2x7) 10 (1x1) (10x10) 16.434 (3x 16.416 (1x7)(5x8) 16.500 16.425 (2x7) 16.417 (1x8) 16.426 (2x8) 16.453 16.435 (3x8) 16.444 (4x8) 16.462 (6x8) types of UNIMEC switches with bezels 16310-16315 and 16324-16326 16.410 (1x1) l types of UNIMEC switches with bezels - 16310-16315 and 16324-16326 16.412 (1x3) 16.430 (3x3) 16.421 (2x3) 16.420 (2x2) 16.411 (1x2) 16.431 (3x4) 16.440 (4x4) 16.422 (2x4) For all types of UNIMEC switches with bezels 16310-16315 and 16324-16326 16.420 (2x2) 16.411 (1x2) 16.417 (1x8) 16.426 (2x8) 16.453 (5x8) 16.435 (3x8) 16.444 (4x8) 16.431 (3x4) 16.440 (4x4) 16.422 (2x4) 16.413 (1x4) 1x5) 16.423 (2x5)16.421 (2x3) 16.450 (5x5) 16.432 (3x5) 16.441 (4x5) 16.412 (1x3) 16.430 (3x3) 16.412 (1x3) 16.430 (3x3) 16.421 (2x3) 3) 16.431 (3x4) 16.440 (4x4) 16.422 (2x4) 16.413 (1x4) product updates and/or changes of specifications please see www.mec.dk 16.410 (1x1) 10For(1x1) 16.434 (3x 16.416 (1x7) 16.452 16.425 (2x7) 16.412 (1x3) 16.430 (3x3) 16.421 (2x3) 16.500 (10x10) 16.414 (1x5) 16.423 (2x5) 16.432 (3x5) 16.441 (4x5) 16.418 (1x9) 16.427 53 16.461 (6x7) (5x7) 16.434 (3x7) 16.443 (4x7) 16.416 (1x7) types of UNIMEC switches with bezels 16310-16315 and 16324-16326 16.425 (2x7) 16.412 (1x3) 16.430 (3x3) 16.421 (2x3) 16.434 (3x 16.416 (1x7) 16.425 (2x7) 16.410 (1x1) 16.500 (10x10) 16.417 (1x8) 16.426 (2x8) 16.453 (5x8) 16.435 (3x8) 16.444 (4x8) 16.420 (2x2) 16.411 (1x2) 16.420 (2x2) 16.411 (1x2) 16.442 (4x6) 16.433 (3x6) 16.424 (2x6) 16.451 (5x6) 16.460 (6x6) 511(1x6) 16.420 (2x2) (1x2) 16.423 (2x5) 16.450 (5x5) 16.432 (3x5) 16.441 (4x5) 16.431 (3x4)16.422 16.440 (2x4) 16.413 (1x4) 16.417 (1x8) 16.426 (2x8) 16.435 (3x (4x6) 16.433 (3x6) 16.424 (2x6) 16.415 (1x6) 16.428 (2x10) 16.446 (4x10 16.419 (1x10) (4x4)16.430 16.437 (3x10) 16.428 16.419 (1x10) 16.442 16.431 (3x4) (4x4) (2x4) 16.413 (1x4) 16.420 (2x2) 16.411 (1x2) 16.422 16.417 (1x8) 16.440 16.426 (2x8) 16.435 (3x 4)(1x1) 16.440 (4x4) 16.412 (1x3) 16.421 16.431 (3x3) (3x4) 16.440 (4x4) 16.422 (2x3) (2x4) and 16324-16326 16.413 (1x4) pes of UNIMEC switches with bezels 16310-16315 10 (1x1) 16.500 (10x10) 16.412 (1x3) 16.430 (3x3) 16.421 (2x3) 16.500 (10x10) 16.461 (6x7) 16.452 (5x7) 16.434 (3x7) types of UNIMEC switches with bezels 16310-16315 and 16324-16326 16.443 (4x7) 416 (1x7) 16.425 (2x7) 16.410 (1x1) 16.500 (10x10) 16.412 (1x3) 16.430 (3x3) 16.421 (2x3) 16.431 (3x4) 16.440 (4x4) 16.422 (2x4) 16.413 (1x4) 16.461 16.452 (5x7) x7) 16.443 (4x7) 16.461 (6x7) 16.452 (5x7) 16.434 (3x7) 16.443 (4x7) (6x7) 16.416 (1x7) 16.425 (2x2) (2x7) 16.500 (10x10) 16.420 16.411 (1x2) 16.420 (2x2) (2x8) 11 (1x2) (1x8) 16.423 (2x5) 16.450 (5x5) 16.432 (3x5) 16.441 (4x5) 16.417 (1x8) 16.426 (2x8) 16.435 (3x 16.442 (4x6) 16.433 (3x6) 16.424 (2x6) 16.415 (1x6)(4x8) 16.417 16.426 16.453 (5x8) 16.435 (3x8) 16.444 16.428 16.462 (6x8) 16.419 (1x10) 16.431 (3x4) 16.440 (4x4) 16.422 (2x4) 16.413 (1x4) 16.431 (3x4) 16.440 (4x4) 16.422 (2x4) 16.413 (1x4) 16.420 (2x2) 16.411 (1x2) 16.417 (1x8) 16.426 (2x8) 16.435 (3x 4) 16.440 (4x4) 16.414 (1x5) 16.423 (2x5) 16.450 (5x5) 16.432 (3x5) 16.441 (4x5) 16.454 (5x9) 16.463 (6x9) 16.418 (1x9) 16.445 (4x9) 16.427 (2x9) 16.436 (3x9) 16.426 (2x8) 16.453 (5x8) 16.435 (3x8) 16.444 (4x8) 16.462 (1x1) pes of UNIMEC switches with bezels 16310-16315 and 16324-16326 16.431 (3x4) 16.440 (4x4) 16.422 (2x4) 16.413 (1x4) 16.414 (1x5) 16.423 (2x5) 16.450 (5x5) 16.432 (3x5) 16.441 (4x5) 16.454 (5x9) 16.418 (1x9) 16.445 (4x9) 16.427 (2x9) 16.436 (3x9) 16.431 (3x4) 16.440 (4x4) 16.422 (2x4) 16.413 (1x4) 16.412 (1x3) 16.430 (3x3) 16.421 (2x3) (10x10) 16.500 (10x10) 16.412 (1x3) 16.430 (3x3) 16.421 (2x3) mec · Industriparken 23 16.500 ·16.500 P.o. Box(10x10) 26 · DK-2750 16.442(3x3) (4x6) 16.433 (3x6)(3x3) 16.430 16.424 (2x6) 16.451 (5x6) 16.460 (6x6) 1x6) 12 (1x3) 16.412 16.430 16.421 (2x3) 16.421 16.420 (2x2) (1x2) (1x3) (2x3) 16.420 (2x2) 16.432 11 (1x2) (2x5) 16.423 16.450 (5x5) (3x5) 16.441 (4x5) 16.417 (1x8) 16.426 (2x8) 16.435 (3x Tel.: +45 44 97 33 66 · Fax: +45 44 68 15 14 · E-mail: danm Tel.: 16.442 (4x6) 16.433 (3x6) 16.424 (2x6) 16.415 (1x6) 16.428 16.419 (1x10) 16.414 (1x5) 16.423 (2x5) 16.450 (5x5) 16.432 (3x5) 16.431 (3x4) 16.440 (4x4) 16.441 (4x5) 16.422 (2x4) 16.413 (1x4) 16.420 (2x2) 16.411 (1x2) 16.417 (1x8) 16.426 (2x8) 16.453 (5x8) 16.435 (3x8) 16.444 (4x8) 16.462 (6x8) 16.417 16.426 16.435 (3x 4) x1) 16.440 (4x4)with 16.414 16.423 (5x5) 16.432 (3x5) (4x5) 16.454 (5x9) 16.418(1x5) (1x9) 16.445 (4x9)(2x8) 16.450 16.427(2x5) (2x9) 16.436 (3x9)(1x8) 16.441 pes of (1x4) UNIMEC switches bezels 16310-16315 and 16324-16326 16.414 (1x5) 16.423 (2x5) 16.450 (5x5) 16.432 (3x5) 16.441 (4x5) 16.431 (3x4) 16.440 (4x4) 16.422 (2x4) 16.413 16.461 (6x7) 16.452 (5x7) 16.434 (3x7) 16.443 (4x7) 6(1x1) (1x7) 16.425 (2x7) 16.500 (10x10) 16.431 (3x4) 16.440 (4x4) 16.422 (2x4) 16.413 (1x4) 16.418 (1x9) 16.427 (2x9) 16.436 16.434 (3x7) 16.443 (4x7) 16.416 (1x7) 16.425 (2x7) 16.500 (10x10) 16.412 (1x3) 16.430 (3x3) (3x3) 16.421 (2x3) 12 (1x3) (1x5) 16.430 (3x3) (3x5) 16.421 (2x3) (2x5) 16.418 (1x9) 16.427 (2x9) 16.436 (3x (3x 16.414 16.423 16.450 (5x5) 16.432 16.441 (4x5) 16.420 (2x2) (1x2) 16.500 (10x10) 16.412 (1x3) 16.430 16.421 (2x3) Tel.: x1) 16.414 (1x5) 16.423 (2x5) 16.450 (5x5) 16.432 (3x5) 16.414 (1x5) 16.423 (2x5) 16.441 (4x5) 16.450 (5x5) 16.432 (3x5) 16.441 (4x5) 417 (1x8) 16.426 (2x8) 16.453 (5x8) 16.435 (3x8) 16.444 (4x8) 16.462 (6x8) 16.450 (5x5) 5) (1x4)16.413 16.441 16.417 (1x8) (4x5)16.426 (2x8) 16.453 (5x8) 16.435 (3x8) 16.444 (4x8) 16.462 (6x8) 16.414 (1x5) 16.423 (2x5) 16.450 (5x5) 16.432 (3x5) 16.441 (4x5) 16.500 (10x10) 16.431 (3x4) 16.440 (4x4) 16.422 (2x4) 16.413 16.431 (3x4) 16.440 (4x4) 16.422 (2x4) (1x4) 16.418 (1x9) 16.427 (2x9) 16.436 (3x 16.434 (3x7) 16.443 (4x7) 16.416 (1x7) 16.425 (2x7) 16.414 (1x5) 16.423 (2x5) 16.450 (5x5) 16.432 (3x5) (1x3) 16.430 (3x3) 16.421 (2x3) 16.441 (4x5) 16.454 (5x9) 16.463 (6x9) 16.418 (1x9) 16.445 (4x9) 16.427 (2x9) 16.436 (3x9) 16.420 (2x2) x2) 16.431 (3x4) 16.440 (4x4) 16.422 (2x4) 13 (1x4) 16.418 (1x9) 16.427 (2x9) 16.436 (3x 16.442 (4x6) 16.433 (3x6) 16.424 (2x6) 16.451 (5x6) 16.460 (6x6) 16.415 (1x6) 16.464 (6x10) 16.428 (2x10) 16.446 (4x10) 16.419 (1x10) 16.455 (5x10) 16.437 (3x10) 12 (1x3) 16.430 (3x3) 16.421 (2x3) 16.431 (3x3) (3x4) 16.440 (4x4) 16.422 (2x3) (2x4) 16.413 (1x4) 16.442 (4x6) (3x6) 16.424 (2x6) 16.451 (5x6) 16.460 16.420 (2x2) 16.433 (1x2) 16.412 (1x3) 16.430 16.421 or all types of UNIMEC switches with bezels 16310-16315 and 16324-16326 16.442 (4x6) 16.433 (3x6) 16.424 (2x6) 16.451 (5x6) 16.415 (1x6) 16.428 (2x10) 16.446 (4x10) 16.419 (1x10) 16.455 (5x10) 16.437 (3x10) Tel.: x1) 16.414 (1x5) 16.423 (2x5) 16.450 (5x5) 16.432 (3x5) 16.441 (4x5) 16.450 (5x5) 5) 16.441 16.461 (6x7) 16.452 (5x7) (3x7) 16.443 (4x7) 1x7) 16.425 (2x7) (4x5)16.434 16.500 (10x10) 16.500 (10x10) LED COMPONENT SPECIFICATIONS 16.414 16.423 (2x5) 16.450 (5x5) 16.432 (3x5) (1x3) 16.430 (3x3) 16.421 (2x3) 16.441 (4x5) 16.420 (2x2) x2) 16.453 (5x8) x8) 16.444 (4x8) 16.431 (3x4) 16.440 (4x4) 16.422 (2x4) 16.413 (1x4) 16.431 (3x4) 16.462 (6x8) 16.440 (4x4) 16.422 (2x4) 13 (1x4)(1x5) 16.418 (1x9) 16.427 (2x9) 16.436 (3x 16.434 (3x7) 16.443 (4x7) 16.416 (1x7) 16.425 (2x7) 16.442 (4x6) 16.414 (1x5) 16.433 (3x6) 16.423 (2x5) 16.424 (2x6) 16.450 (5x5) 16.451 (5x6) 16.432 (3x5) 16.460 (6x6) 16.415 (1x6) 16.441 (4x5) 16.454 (5x9) (6x9) 16.418(1x4) (1x9) 16.445 (4x9) 16.427 (2x9) 16.436 (3x9) 16.418 16.427 16.436 (3x 16.431 (3x4) 16.440 (4x4) 16.422 (2x4) 16.413 16.442 (4x6) 16.433 (3x6) 16.424 (2x6) 16.451 (5x6) 16.415 (1x6) 16.428 (2x10) (4x6) 16.442 16.446 (4x10)(2x9) 16.463 16.433 (3x6) 16.424 (2x6) 16.419 (1x10) 16.455 (5x10) 16.451 (5x6) 16.437 (3x10)(1x9) 16.460 or all types of UNIMEC switches with bezels 16310-16315 and 16324-16326 16.442 (4x6) 16.433 (3x6) 16.424 (2x6) 16.451 (5x6) 16.415 (1x6) 7 (1x8) 16.426 (2x8) 16.453 (5x8) 16.435 (3x8) 16.444 (4x8) 16.462 (6x8) 16.454 (5x9) 16.463 16.445 (4x9) 16.427 (2x9) 16.436 (3x9) 16.428 (2x10) 16.419 (1x10) 16.437 (3x1 16.417 (1x8) 16.426 (2x8) 16.435 (3x8) 16.444 (4x8) 16.428 (2x10) 16.419 (1x10) 16.437 (3x1 16.500 16.450 (5x5) 5) 16.441 (4x5) 16.442 (4x6) Ballerup 16.433 (3x6)23 mec(3x3) · Industriparken · P.o. Box 26 · DK-2750 · Denmark 16.424 (2x6) 16.451 (5x6) (10x10) 16.460 (6x6) 16.415 (1x6) x3) 16.430 16.421 (2x3) 16.431 (3x4) 16.440 (4x4) 16.422 (2x4) (1x4) 16.414 (1x5) 16.423 (2x5) 16.450 (5x5) 16.432 (3x5) (1x3) 16.430 (3x3) 16.421 (2x3) 16.441 (4x5) 16.420 (2x2) x2) 16.414 (1x5) 16.423 (2x5) 16.450 (5x5) 16.432 (3x5) 16.431 (3x4) 16.440 (4x4) 16.441 (4x5) 16.422 (2x4) 13 (1x4) mec · Industriparken 23 · P.o. Box 26 · DK-2750 Ballerup · Denmark Tel.: +45 44 97 33 66 · Fax: +45 44 68 15 14 · E-mail: danmec@mec.dk · www.mec.dk 16.442 (4x6) 16.433 (3x6) 16.424 (2x6) 16.451 (5x6) 16.460 (6x6) 16.415 (1x6) 16.442 (4x6) 14 (1x5) 16.423 (2x5) 16.433 (3x6) 16.424 (2x6) 16.450 (5x5) 16.451 (5x6) 16.432 (3x5) 16.415 (1x6) 16.441 (4x5) 16.454 (5x9) 16.463 (6x9) 418 (1x9) 16.445 (4x9) 16.427 (2x9) 16.436 (3x9) 16.431 (3x4) 16.410 (1x1) 16.440 (4x4) 16.422 (2x4) 16.413 (1x4) 16.442 (4x6) 16.433 (3x6) 16.424 (2x6) 16.451 (5x6) 16.460 16.414 (1x5) 16.423 (2x5) 16.450 (5x5) 16.432 (3x5) 16.441 (4x5) 16.454 (5x9) 16.463 (6x9) 16.418 (1x9) 16.445 (4x9) 16.427 (2x9) 16.436 (3x9) Tel.: +45 44 97 33 66 · Fax: +45 44 68 15 14 · E-mail: danmec@mec.dk · www.mec.dk or all types of UNIMEC switches with bezels 16310-16315 and 16324-16326 16.442 (4x6) 16.433 (3x6) 16.424 (2x6) 16.451 (5x6) 16.415 (1x6) 16.428 (2x10) 16.419 (1x10) 16.437 (3x1 16.417 (1x8) 16.426 (2x8) 16.442 (4x6) 16.435 (3x8) 16.433 (3x6) 16.424 (2x6) 16.444 (4x8) 16.451 (5x6) 16.460 (6x6) 16.415 (1x6) 16.464 (6x10) 16.428 (2x10) 16.446 (4x10) 16.419 (1x10) 16.455(1x10) (5x10) 16.437 (3x10) 16.428 (2x10) 16.419 16.437 (3x1 16.461 (6x7) · Denmark (5x7) 16.434 (3x7) 16.443 16.416 (1x7) 16.425 (2x7) 16.500 (10x10) x3) 16.430 (3x3) 16.421 (2x3) mec(4x7) · Industriparken16.452 23 · P.o. Box 26 · DK-2750 Ballerup 16.431 (3x4) 16.440 (4x4) 16.422 (2x4) (1x4) 16.452 (5x7) 16.434 (3x7) 16.443 (4x7) 16.416 (1x7) 16.425 (2x7) 16.414 (1x5) 16.423 (2x5) 16.450 (5x5) 16.432 (3x5) 14 (1x5) 16.423 (2x5) 16.450 (5x5) 16.441 (4x5) 16.432 (3x5) 16.441 (4x5) 16.410 (1x1) Tel.: +45 44 97 33 6616.433 · Fax: +45 44 68 1516.450 1416.442 · E-mail: danmec@mec.dk · www.mec.dk mec ·· Industriparken (4x6) (3x6) 16.424 (2x6) (5x6) 22 16.415 (1x6) 1x8) 16.414 16.426(1x5) (2x8) 16.423 (2x5) (5x5) 16.453 (5x8) 16.435 (3x8) 16.444 (4x8) 16.432 (3x5) 16.441 (4x5) 16.462 (6x8) mec16.451 Industriparken 16.442 (4x6) 16.433 (3x6) 16.424 (2x6) 16.451 (5x6) 16.460 (6x6) 16.415 (1x6) Tel.: +45 44 97 33 66 · Fax: +45 4 16.442 (4x6) 6) 16.451 (5x6) 16.460 (6x6) 16.428 (2x10) 16.419 (1x10) 16.437 (3x1 16.417 (1x8) 16.426 (2x8) 16.435 (3x8) 16.444 (4x8) 16.461 (6x7) 16.452 (5x7) 16.434 (3x7) 16.443 (4x7) 16.416(1x2) (1x7) 16.442 (4x6) 16.433 (3x6) 16.424 (2x6) 16.425(2x2) (2x7) 16.451 (5x6) 16.460 (6x6) 16.415 (1x6) 16.420 Tel.: +45 44 97 16.452 33 6616.437 · Fax: +45 4 16.411 16.464 (6x10) 16.428 (2x10) 16.446 (4x10) 16.419(2x3) (1x10) 16.455 (5x10) 16.437 (3x10) 16.428 (2x10) 16.419 (1x10) (3x1 16.431 (3x4) 16.440 (4x4) 16.422 (2x4) x4) (5x7) 16.434 (3x7) 16.443 (4x7) 16.416 (1x7) 16.425 (2x7) x3) 16.430 (3x3) 16.421 16.431 (3x4) 16.440 (4x4) 16.422 (2x4) (1x4) 16.452 (5x7) 16.434 (3x7) 16.443 (4x7) 16.416 (1x7) 16.425 (2x7) (1x5) 16.423 (2x5) 16.450 (5x5) 16.432 (3x5) 16.441 (4x5) 16.454 (5x9) 16.463 (6x9) 8 (1x9) 16.445 (4x9) 16.427 (2x9) 16.436 (3x9) 16.461 16.452 (5x7) 16.434 (3x7) 16.443 (4x7) 16.425 (2x7) mec · Industriparken 14 (1x5) 16.423 (2x5) 16.450 (5x5) 16.432 (3x5) 16.441 (4x5) 16.418 (1x9) 16.445 (4x9) 16.427 (2x9) 16.436 (3x9) mec · Industriparken 23 · P.o. Box 26 · DK-2750 Ballerup · Denmark 16.410 mec· Industriparken 22 16.414 (1x5)16.425 (2x7) 16.423 (2x5)16.434 (3x7) 16.450 (5x5) 16.432 (3x5) 16.441 (4x5) 16.461 (6x7) 16.452 (5x7) 16.443 (4x7) 16.416(1x1) (1x7) 16.500 (10x10) Tel.: +45 44 97 33 ·· Fax: +45 16.442 (4x6) 6) 16.451 (5x6) 16.460 (6x6) Tel.: +45 44 97 33 66 · Fax: +45 44 68 15 14 · E-mail: danmec@mec.dk · www.mec.dk 16.442 (4x6) 16.433 (3x6) 16.424 (2x6) 16.451 (5x6) 16.460 (6x6) 16.415 (1x6) 16.442 (4x6) 16.433 (3x6) 16.424 (2x6) 16.451 (5x6) 16.460 16.415 (1x6) 16.420 (2x2) Tel.: +45 44 97 16.452 33 66 66(6x6) Fax: +45 4 4 16.411 16.431 (3x4) 16.440 (4x4) 16.422 (2x4) x4) 16.461 (6x7) 16.452 (5x7) 16.434 (3x7) 16.443 16.416 (1x7) (5x7) 16.434 (3x7) 16.443 (4x7) 16.425 (2x7) 16.416 (1x7) 16.442 (4x6) 16.433 (3x6) 16.424 (2x6) 16.425 (2x7) 16.451 (5x6) 16.460 (6x6) 15 (1x6) 16.464 (6x10) 16.428 (2x10) 16.446 (4x10) (4x7) 419 (1x10)(1x2) 16.455 (5x10) 16.437 (3x10) 16.454 (5x9) 16.442 (4x6) 16.463 (6x9) 16.433 (3x6) 16.424 (2x6) 16.445 (4x9) 16.451 (5x6) 16.460 (6x6) x9) 16.415 (1x6) 16.464 (6x10) 16.428 (2x10) 16.446 (4x10) 16.419 (1x10) 16.455 (5x10) 16.437 (3x10) (1x5) 16.423 (2x5) 16.450 (5x5) 16.432 (3x5) 16.441 (4x5) 16.452 (5x7) 16.434 (3x7) 16.443 (4x7) 16.416 (1x7) 16.425 (2x7) 16.461 16.452 (5x7) 16.434 (3x7) 16.443 (4x7) 16.425 (2x7) 16.418 (1x9) 16.445 (4x9) 16.461 (6x7) 16.452 (5x7) 16.434 (3x7) 16.443 (4x7) 16.416 (1x7) 16.425 (2x7) (2x9) 16.436 (3x9) mec 2 16.417 (1x8) 16.426 (2x8) 16.453 (5x8) 16.435 (3x8) 16.444 (4x8) 16.462 (6x8) ·· Industriparken mec · (3x3) Industriparken 23 · P.o. Box 26 · 16.427 DK-2750 Ballerup · Denmark mec Industriparken 2 16.500 (10x10) 16.464 16.428 (2x10) 16.446 (4x10) 16.455 (5x10) 16.437 16.412 (1x3) 16.430 16.421 (2x3) 16.417(3x10) Tel.: +45 44 97 33 66 · Fax: +45 4 16.442 (4x6) 6) 16.451 (5x6) 16.460 (6x6) (1x8) 16.426 (2x8) 16.453 (5x8) 16.435 (3x8) 16.444 (4x8) Tel.: +45 44 97 33 66 · Fax: +45 44 68 15 14 · E-mail: danmec@mec.dk · www.mec.dk 16.442 (4x6) 16.433 (3x6) 16.424 (2x6) 16.451 (5x6) 16.460 (6x6) 16.415 (1x6) 16.442 (4x6) 16.433 (3x6) 16.424 (2x6) 16.451 (5x6) 16.420 (2x2) Tel.: +45 44 97 33 66 · Fax: +45 4 16.460 (6x6) 15 (1x6) 16.411 (1x2) 16.431 (3x4) 16.440 (4x4) 16.422 (2x4) x4) 16.452 (5x7) 16.434 (3x7) 16.443 (4x7) 16.416 (1x7) 16.425 (2x7) x5) 16.423 (2x5) 16.450 16.432 16.441 16.442 (4x6) 16.454(5x5) (5x9) 16.433 (3x6) 16.424 (2x6) 16.451 16.463 (5x6) (6x9) 16.460 (6x6) 1x9) 16.445(4x5) (4x9) 16.415 16.427(1x6) (2x9) 16.436(3x5) (3x9) (1x5) 16.423 (2x5) 16.450 (5x5)(2x9) 16.43216.434 (3x5) see(3x7) 16.441 (4x5) 16.461 16.452 (5x7) 16.434 (3x7) 16.443 (4x7) 16.425 (2x7) 16.461 (6x7) 16.452 (5x7) 16.443 (4x7) 16.416 (1x7) For16.417 product updates and/or changes of specifications please www.mec.dk 16.425 (2x7) 16.418 (1x9) 16.445 16.427 16.436 (3x9) 53 (4x9) (1x8) 16.426 (2x8) 16.453 (5x8) 16.435 (3x8) 16.444 (4x8) 16.461 (6x7) 16.452 (5x7) 16.434 (3x7) 16.443 (4x7) 16.462 (6x8) 16.416 (1x7) 16.425 (2x7) 16.417 (1x8) 16.426 (2x8) 16.453 (5x8) 16.435 (3x8) 16.444 (4x8) · Industriparken ·(3x3) P.o. Box 26 · 23 DK-2750 Ballerup · DenmarkBallerup · Denmark16.500 (10x10) 16.412 (1x3) 16.430 16.421mec (2x3) mec23· Industriparken · P.o. Box 26 · DK-2750 16.417 (1x8) 16.426 (2x8) 16.453 (5x8) 16.435 (3x8) 16.444 (4x8) 16.442 (4x6) 16.433 (3x6) 16.424 (2x6) 16.451 (5x6) 16.460 (6x6) (1x6) 16.464 (6x10) 16.428 (2x10) 16.446 (4x10) 915 (1x10) 16.455 (5x10) 16.437 (3x10) Tel.: +45 44 9716.432 33Tel.: 6616.433 · +45 Fax: +45 15 1416.442 · +45 E-mail: danmec@mec.dk · www.mec.dk (4x6) (3x6) 16.424 (2x6) 16.451 (5x6) 16.428 (2x10) (5x8) 16.460 (6x6) (1x6) (1x8) 16.446 16.419 (1x10) 16.437 (3x10) (6x8) x5)16.417 16.423 (2x5) 16.450 (5x5) (3x5) 16.441 (4x5) 44 9744 3368 66 · Fax: 4416.444 68 15 14 · E-mail: danmec@mec.dk · www.mec.dk 16.442 (4x6) 16.433 (3x6) 16.424 (2x6) 16.451 (5x6)16.462 16.460 (6x6) (4x10) 16.415 (1x6) 16.426 (2x8) 16.453 16.435 (3x8) (4x8) For product updates and/or changes of specifications please see www.mec.dk 16.461 16.452 (5x7) 16.434 (3x7) 16.443 16.416 16.425 (2x7) 53 16.461 (6x7) 16.452 (5x7) 16.434 (3x7) 16.443 (4x7) 16.416 (1x7) 16.425 (2x7) 16.417 (1x8) 16.426 (2x8) 16.453 (5x8) 16.435 (3x8) 16.444 (4x8) 16.417 (1x8) 16.426 (2x8) 16.453 (5x8) 16.435 (3x8) 16.462 (6x8) 16.444 (4x8) 16.461 (6x7)(6x7) 16.452 (5x7) 16.434 (3x7) 16.443 (4x7)(4x7) 16 (1x7)(1x7) 16.425 (2x7) 16.431 (3x4) 16.440 (4x4) 16.422 (2x4) 16.413 (1x4) 16.461 (6x7) 16.452 (5x7) 7) 16.443 (4x7) 16.461 (6x7) 16.452 (5x7) 16.434 (3x7) 16.443 (4x7) 16.416 (1x7) 16.425 (2x7) 16.412 (1x3) 16.430 (3x3) 16.421 (2x3) 16.442 (4x6) 16.433 (3x6) 16.424 (2x6) 16.451 (5x6) 16.460 (6x6) (1x6) 16.417 (1x8) 16.426 (2x8) 16.453 (5x8) 16.435 (3x8) 16.444 (4x8) (2x10) (4x10) 16.419 (1x10) 16.437 (3x10) 16.417 (1x8) 16.426 (2x8) 16.453 (5x8) 16.435 16.444 (4x8) 16.462 (6x8) · Industriparken 23(3x8) · P.o. Box 2616.445 · DK-2750 Ballerup ·(5x9) Denmark x5)16.418 16.423 (2x5) 16.45016.428 (5x5) 16.432 (3x5) 16.454 16.441 (4x5) 16.463 (6x9) 16.446 (1x9) (4x9) 16.427 (2x9) 16.436 (3x9) 16.426 (2x8) 16.453 (5x8) 16.435 (3x8) 16.444 (4x8) 16.462 For product updates and/or changes of specifications please see www.mec.dk 16.454 (5x9) 16.418 (1x9) 16.445 (4x9) 16.427 (2x9) 16.436 (3x9) 53 mec ··Industriparken 23 · 68 P.o. Box 26 · DK-2750 · Denmark 16.461 (6x7) 16.452 (5x7) 16.434 (3x7) 16.443 (4x7) 16.416 (1x7) 16.461 (6x7) 16.452 (5x7) 16.434 (3x7) 16.443 (4x7)Ballerup 16.425 (2x7) 16 (1x7) +45 16.425 (2x7) 16.431 (3x4) 16.440 (4x4) 16.422 16.413 (1x4) 16.417 (1x8) 16.426 (2x8) 16.453 (5x8) 16.435 (3x8) 16.444 (4x8) mec · ·Industriparken 23 · P.o. Box 26 · DK-2750 Tel.: 44 97 33 66(2x4) Fax: +45 44 15 14 · E-mail: danmec@mec.dk www.mec.dk 16.461 (6x7) 16.452 (5x7) 7) 16.443 (4x7) 16.442 (4x6) 16.433 (3x6) 16.424 (2x6) 16.451 (5x6) 16.460 (6x6) x6) 16.461 (6x7) 16.452 (5x7) 16.434 (3x7) 16.443 (4x7) 16.416 (1x7) 16.464 (6x10) 16.428 (2x10) 16.425 (2x7) 16.446 (4x10) 1x10) 16.455 (5x10) 16.437 (3x10) Tel.:16.426 +45 44(4x10) 97 33 6616.433 · Fax: +45 44 68 15 1416.442 · E-mail: danmec@mec.dk · www.mec.dk (4x6) (3x6) (2x6) 16.451 (5x6) 16.460 (6x6) (1x6) (1x8) 16.424 16.417 (2x8) 16.453 (5x8) 16.435 (3x8) 16.444 (4x8) 16.462 (6x8) 16.464 (6x10) Tel.: +45 44 97 33 66 · Fax: +45 44 68 15 14 · E-mail: danme 16.446 16.455 (5x10) 10) 16.428 (2x10) 16.446 (4x10) 16.419 (1x10) 16.437 (3x10) 16.45416.453 (5x9) 16.417 (1x8)16.42716.435 16.426 (2x8) 16.453 (5x8) 16.435 (3x8) 16.444 (4x8) 16.463 (6x9) 16.418 (2x8) (1x9) 16.445 (4x8) (4x9) (2x9) 16.436 (3x9) 16.462 (6x8) 16.454 (5x9) 16.418 (1x9) 16.445 (4x9) 16.427 (2x9) 16.436 (3x9) 16.426 (5x8) (3x8) 16.444 16.462 16.454 (5x9) 16.418 (1x9) 16.445 (4x9) 16.427 (2x9) 16.436 (3x9) 16.461 (6x7) 16.452 (5x7) 16.434 (3x7) 16.443 (4x7) (1x7) 16.425 (2x7) 16.461 (6x7) 16.452 (5x7) 16.434 (3x7) 16.443 (4x7) (4x5) 16 (1x7) (1x4) 16.425 (2x7) mec · Industriparken 23 · (6x9) P.o. Box 26 · DK-2750 16.442 (4x6) 16.433 (3x6) 16.424 (2x6) 16.451 (5x6) 16.460 (6x6) x6) 16.431 (3x4) 16.440 (4x4) 16.422 (2x4) 16.413 16.461 (6x7) 16.452 (5x7) 7) 16.443 (4x7) 16.461 (6x7) 16.452 (5x7)16.463 16.434 (3x7) 16.443 (4x7) 16.416 (1x7) 16.414 (1x5) 16.423 (2x5) 16.450 (5x5) 16.432 (3x5) 16.425 (2x7) 16.441 16.454 (5x9) 16.418 (1x9) 16.445 (4x9) 16.427 (2x9) 16.436 (3x9) Tel.: +45 44 97 16.453 33 66 · Fax: +45 44 68 15 14 · E-mail: danme 16.417 (1x8) 16.426 (2x8) 16.453 (5x8) 16.435 (3x8) 16.444 (4x8) 16.462 (6x8) 16.417 (1x8) 16.426 (2x8) (5x8) 16.435 (3x8) 16.444 (4x8) 16.462 (6x8) 16.454 (5x9) 16.463 (1x9) 16.445 (4x9) 16.427 (2x9) 16.454 (5x9) 17 16.418 (1x8) (2x8) 16.436 (3x9) 16.426 (2x8)· Industriparken 16.453 (5x8) 16.453 16.435 (3x8) 16.444 (4x8) 16.418 (1x9) 16.445 (4x9) 16.427 (2x9) 16.436 (3x9) 16.462 (6x8) (6x9) 16.426 (5x8) 16.435 (3x8) 16.444 (4x8) 16.462 16.417 (1x8) 16.426 (2x8) 16.453 (5x8) 16.435 (3x8) 16.444 (4x8) 16.462 (6x8) mec 23 · P.o. Box 26 · DK-2750 Ballerup · Denmark (6x7) (5x7) (3x7) (4x7) (1x7) (1x9) 16.42516.427 (2x7) (2x9) 16.434 16.41816.436 (1x9) (3x9) 16.443 16.445 (4x9) (6x9) 16.454 (5x9) 16.427 (2x9) (4x9) 16.452 16.436 (3x9) (5x9) 16.461 16.454 16.463 16.418 16.445 mec · Industriparken 23 · (6x10) P.o. Box 26 · DK-2750 Tel.: +45 44 97 33 (2x5) 66 · Fax: +45 44 68 15 14 · E-mail:(4x6) danmec@mec.dk · www.mec.dk 16.442 16.433 (3x6) 16.424 (2x6) 16.464 16.451 (5x6) 16.428 (2x10) 16.460 (6x6) x6) 16.446(4x5) (4x10) 16.419(1x5) (1x10) 16.455 (5x10) 16.437 (3x10) 16.414 16.423 16.450 (5x5) 16.432 (3x5) 16.441 16.428 (2x10) 16.446 (4x10) 16.419 (1x10) 16.455 (5x10) 16.437 (3x10) Tel.: +45 44 97 33 66 · Fax: +45 44 68 15 14 · E-mail: danme 16.417 (1x8) (2x8) 16.434 16.426 (2x8) 16.453 (5x8) 16.435 (3x8) 16.444 (4x8) 17 (1x8) 16.417 16.426 16.453 (5x8) 16.461 16.435 (3x8) 16.443 16.462 (6x8) 16.444 (4x8) 16.452 16.462 (6x8) 16.462 16.454 (5x9) 16.418 (1x9) 16.445 (4x9) 16.427 (2x9) 16.436 (3x9) (6x7) (5x7) (3x7) (4x7) x7) 16.425 (2x7) (1x8) 16.426 (2x8) 16.453 (5x8) 16.435 (3x8) 16.444 (4x8) (6x8) 23 · P.o. Box 26 · DK-2750 Ballerup · Denmark 16.461 (6x7) 16.452 (5x7) 16.434 (3x7) 16.443 (4x7) (1x7) 16.425 (2x7)(4x8) 16.454 (5x9) 16.463 (6x9) 16.418 (1x9) 16.445 (4x9) 16.427 (2x9) 16.436 (3x9) 16.453 (5x8) 8)16.414 16.444 16.462 (6x8) 16.464 (6x10) 16.428 (2x10) 16.454 (5x9) 16.446 (4x10) 16.419 (1x10) 16.463 (6x9) 16.455 (5x10) 16.418 (1x9) 16.445 (4x9) 16.437 (3x10) 16.427 16.436 (3x9) 16.428 (2x10) 16.446 (4x10) 16.419(2x9) (1x10) 16.455 (5x10) 16.437 (3x10) (1x5) 16.423 (2x5) 16.450 (5x5) 16.432 (3x5) 16.441 (4x5) */F=20mA, **Pulse width 1ms Duty cycle 1:5, ***/F=50mA, ****Luminous Flux mlm 44 68 15 14 · E-mail: danmec@mec.dk · www.mec.dk 16.428 (2x10) 16.446 (4x10) 16.419 (1x10) 16.455 (5x10) 16.437 (3x10) (1x8) 16.426 (2x8) 16.453 (5x8) 16.435 (3x8) 16.444 (4x8) 16.462 (6x8) 16.454 (5x9) 16.463 16.445 (4x9) 16.427 (2x9) 16.436 (3x9) 17 (1x8) 16.426 (2x8) 16.453 (5x8) 16.435 (3x8) 16.444 (4x8) 16.462 (6x8) 16.461 (6x7) 16.452 (5x7) 16.434 (3x7) 16.443 (4x7) x7) 16.425 (2x7) 16.417 (1x8) 16.426 16.453 (5x8) 16.435 16.444 (4x8) 16.462 (6x8) 16.442 (4x6) 16.433 mec·(2x8) Industriparken 23 · P.o.(3x8) Box 26 · DK-2750 Ballerup · Denmark 16.424 16.451 (5x6) 16.460 16.415 16.464 (6x6) (6x10) 16.428 (2x6) (2x10) 16.446 (4x10) 16.419 (1x6) (1x10) 16.455 (5x10) 16.437 (3x6) (3x10) 16.453 (5x8) 8) 16.444 (4x8) 16.462 16.454 16.463 (6x9) 16.418 16.445 (4x9) 16.427 (2x9) 16.436 16.454 (5x9) 16.463 (6x9) 16.418 (1x9) 16.445 (4x9) 16.427 16.436 mec ·(4x10) Industriparken 23·(6x8) · (5x9) P.o.(5x10) Box 26 · DK-2750 · Denmark 4 Tel.: +45 44 97 33(2x9) 66 ·(3x9) Fax:(3x9) +45 4416.428 6816.445 15(3x9) 14(2x10) · (4x9) E-mail: danmec@mec.dk www.mec.dk 16.464 (6x10) 16.428 (2x10) 16.446 (1x10) 16.455 16.437 (3x10) 16.454 (5x9) 16.446 (4x10) 16.419 (1x10) 16.463 (6x9)Ballerup 1816.419 (1x9)(1x9) 16.455 (5x10) 16.437 (3x10) 16.427 (2x9) 16.436 16.454 (5x9) 16.463 (6x9) 16.418 (1x9) 16.445 (4x9) 16.427 (2x9) 16.436 (3x9) (1x8) 16.42616.428 (2x8) (2x10) (5x8) 16.435(3x9) (3x8) 16.444 (4x8) (6x8) Tel.:16.445 +45 44 97 33 6616.453 · Fax: +45 44 68 15 14 16.462 · E-mail: danmec@mec.dk · www.mec.dk 16.428 (2x10) 16.446 (4x10) 16.419 (1x10) 16.455 (5x10) 16.437 (3x10) 16.454 (5x9) 16.463 (4x9) 16.427 (2x9) 16.436 16.464 (6x10) 8 contact functions • 2 pole • distinct tactile feel USAGE GUIDELINES HOW TO GET THE BEST RESULTS WITH MEC SWITCHES ? spray the switch during cleaning. The switch must be protected at all times to prevent contamination by flux or cleaning liquids. These guidelines are offered to users of MEC Switches as an aid to ensure successful and reliable switch operation. Please see the technical specifications for details on operating and storage temperatures and soldering guidelines to make sure you select the best switch for your application. When wave soldering is taking place, MEC strongly recommend that the temperature profile is analyzed and compared with the temperature rating of the switch. It is also important to monitor the accumulated heat buildup from both the pre-heat zones and the solder zone. For unimec™ latching versions we recommend to leave the actuator in the released upper position during soldering. This makes the switch more resistant to overheating. All standard accessories for unimec™ switches are made from ABS plastic with a maximum operating temperature of 65°C. It is strongly recommended that accessories are mounted after soldering of the switch. Wave soldering: Heat built up in the switch during pre-heating and soldering must not exceed the maximum operating temperature of the switch. Peak temperature must not exceed 260°C, and soldering time is max 10 sec. (IEC-68-2-20) LEDs have their own temperature specifications. When fitted in a switch the LED will determine the max. operating temperature, i.e. 16923 has an upper temperature limit of 85°C! MOUNTING AND DISMOUNTING If switches are to be mounted in rows it is essential that the recommendations regarding spacing are followed. PC board thickness should be 1.4±0.2 mm and terminal hole diameter should be 0.9 mm. All unimec™ caps and bezels are easily snapped onto the switch modules and can be changed at a later time with the exception of the unimec 16.700 cap. Once this cap is installed it is not designed to be removed. To do so may cause damage to the switch and the PC board if not done very carefully. If the 16.300 or 16.700 cap must be removed from a unimec™ latching switch, make sure that the switch actuator is in the released, upper position before attempting to remove the cap. This will prevent possible damage to the internal latching pin. SOLDERING - THROUGH HOLE VERSIONS Hand soldering: Max. 350°C for max. 3 sec. ROHS COMPLIANCE As of 1 July 2006 MEC has completed the conversion to RoHS compliance. For more info please see our homepage www.apem.com TEMPERATURE LIMITS: Switch LEDs Accessories 160 °C 85/100 °C 65 °C PACKAGING Unimec™ switches are packed in rigid tubes of 50 pieces each. A box contains 1.000 pcs. SOLDERING AND CLEANING UNIMEC™ SERIES Most assembly and field problems experienced by users of unsealed switches are caused by the contamination of the contacts during soldering and cleaning. Contact contamination may be recognized by an increase in contact resistance and possible intermittent operation of the switch, especially in low power applications. Care must be taken not to submerge the switch in cleaning agents or 5 PANEL PCB SWITCHES Unimec™
1630034
物料型号:文档中没有明确列出具体的物料型号,但提到了多种型号的LED组件,例如16920/16921、16922、16923、16924等。
器件简介:Unimec™系列开关具有8个接触功能、2个极点和独特的触感。它们可以是瞬时的、锁定的或静音的,具有长达1000万次的循环寿命。
引脚分配:文档中提供了PCB布局和安装孔尺寸,但没有具体说明引脚分配
参数特性:环境规格包括IP54密封、工作温度范围为-40°C至+160°C、存储温度范围为-65°C至+160°C。电气规格包括推荐负载、接触电阻、绝缘电阻、接触反弹、相邻接触的介电强度和电容等。
功能详解:Unimec™开关可以提供8种接触功能,包括瞬时、锁定或静音操作。
应用信息:文档中提到了LED组件的不同颜色和规格,以及它们的绝对最大额定值和电气-光学特性。
封装信息:文档中提供了关于LED组件的封装规格,包括颜色代码、正向电压、工作温度范围、存储温度范围和焊接温度。
1630034 价格&库存
很抱歉,暂时无法提供与“1630034”相匹配的价格&库存,您可以联系我们找货
