BCP-MH-E01
BCP-MH-E01
    MEGACHIPS(兆芯)
    EVB MULTI-HOP HIGH SPEED PLC
BCP-MH-E01 数据手册
BlueChip PLC Evaluation board Manual Dolphin BCP-STD for Multi-hop BCP-MH-E01 : Evaluation board (Dolphin STD) 2016/03/29 Proprietary MegaChips Corporation Copyright (C) 2016 MegaChips Corporation. All rights reserved. 1 Table of contents              2016/03/29 EVALUATION KIT IMPORTANT NOTICE BlueChip PLC Evaluation board contents OutlineView Detail Jumper-pin Setting Tx Power Setting AC/DC adapter BCP-COAX_CONV Board (Coupler) Connection Diagram (Ether Bridge Test with DC power line) Connection Diagram (Ether Bridge Test with Coax.) Connection Diagram (Ether Bridge Test with AC power line) Connection Diagram (RS485 Bridge Test) Connection Diagram (Multi-hop Test) Proprietary MegaChips Corporation 2 EVALUATION KIT IMPORTANT NOTICE MegaChips Corporation (MCC) provides these evaluation kits (EVKs) under the following AS IS conditions: The EVKs are intended for use for ENGINEERING DEVELOPMENT OR EVALUATION PURPOSES ONLY and are not for commercial use. Therefore, the EVKs are not fault-tolerant and are not designed or manufactured with protective considerations, including but not limited to product safety measures typically found in finished commercial goods. As a prototype, the EVKs do not fall within the scope of the European Union Directive on electromagnetic compatibility. Also be aware that the EVKs may not be regulatory compliant or agency certified (FCC, UL, CE, etc.). The EVKs have 110/220VAC POWER DIRECTLY CONNECTED TO THEIR CIRCUITS, which can cause PERSONAL INJURY, DEATH OR PHYSICAL DAMAGE. Therefore, caution should be exercised when testing these devices. The user must be a skilled person in the practice and art of high voltage circuitry in order to utilize the circuits in the EVKs. It is highly recommended that the user should have qualifications or any certificate for handling 110/220VAC Power, COMMON SENSE IS ENCOURAGED. The user agree not to use the EVKs in any situation where damage or injury to persons, property or business could occur. Furthermore, the EVKs are NOT FOR RESALE/COMMERCIAL USE AND MUST BE STRICTLY OPERATED IN A WELL-CONTROLLED LABORATORY ENVIRONMENTS. THE USER ASSUMES ALL RESPONSIBILITY AND LIABILITY FOR PROPER AND SAFE HANDLING OF THE EVKS. FURTHER, THE USER RELEASES MCC FROM ALL CLAIMS ARISING FROM THE HANDING OR USE OF THE EVKS. This notice contains important safety information as to handling EVKs. For further safety concerns, please contact a MCC application engineer. 2016/03/29 Proprietary MegaChips Corporation 3 BlueChip PLC Evaluation board contents(1/2) 1.Dolphin BCP-STD Master/Terminal set ① ① Packaging box :1pcs ② ③ ④ ⑤ ⑥ :1pcs :1pcs :1pcs :2pcs :2pcs ② ⑤ ⑥ ③ 2016/03/29 Proprietary ⑦ ④ ⑦ ⑦ ⑧ EVALUATION KIT IMPORTANT NOTICE Multi-hop Master unit Multi-hop Terminal unit AC adapter(DC12V) Connector Plug for RS485 Port Connector MC 1,5/ 3-ST-3,5(PhoenixContact) ⑦ Connector Plug for PLC Interface Connector MSTB 2,5/ 2-ST(PhoenixContact) ⑧ BCP-COAX_CONV Board :4pcs :2pcs MegaChips Corporation 4 BlueChip PLC Evaluation board contents(2/2) 2.Dolphin BCP-STD Terminal/Terminal set ① ① Packaging box :1pcs ② ③ ④ ⑤ ⑥ :1pcs :0pcs :2pcs :2pcs :2pcs ② ⑤ ⑥ ④ 2016/03/29 Proprietary ⑦ ④ ⑦ ⑦ ⑧ EVALUATION KIT IMPORTANT NOTICE Multi-hop Master unit Multi-hop Terminal unit AC adapter(DC12V) Connector Plug for RS485 Port Connector MC 1,5/ 3-ST-3,5(PhoenixContact) ⑦ Connector Plug for PLC Interface Connector MSTB 2,5/ 2-ST(PhoenixContact) ⑧ BCP-COAX_CONV Board :4pcs :2pcs MegaChips Corporation 5 OutlineView Master unit 2016/03/29 Proprietary Label : BCP-STD(Master) Label : BCP-STD(Terminal) MAC ADDRESS MAC ADDRESS M/T LED : Green ON M/T LED : Green OFF Terminal unit MegaChips Corporation 6 Detail DC Jack RS485 Port (Op.UART Port) + - GND MC 1,5/3-ST-3,5(PhoenixContact) 0.14mm2~1.5mm2/AWG28~16 LAN Port N/A PLC LED : PLC Link status LAN LED : LAN status M/T LED Case Size 32mm(H)×80mm(W)×125mm(D) : Master mode :Green ON Terminal mode :Green OFF SETUP button : Power-up with holding SETUP pressed will change the Master/Terminal mode. INIT button : Reset to factory default (push at least 1second) PLC Interface Connector (Op. AC Input Connector) MSTB 2,5/ 2-ST(PhoenixContact) 0.2mm2~2.5mm2/AWG24~12 2016/03/29 Proprietary MegaChips Corporation 7 Jumper-pin Setting(1/2) (1)Power Input Source Setting No. Power Input Source JP100/JP101 1* DC12V from CN200(DC-JACK) OPEN 2 AC100~AC240V from CN100 SHORT *Default Setting High voltage area(primary side) JP100 JP101 CN200 CN100 When JP100/101 is short, this area is directly connected to the input power (high voltage : AC100VAC240V). Therefore, please do NOT touch this area while connected to the AC power line. 2016/03/29 Proprietary MegaChips Corporation 8 Case silk Jumper-pin Setting(2/2) (2)CN401 Interface Setting No. CN401 Interface JP400 JP401 JP402 JP403 R410 1* RS485 OPEN SHORT 22Ω 2 UART SHORT OPEN Nonmounted *Default Setting 1pin 2pin 3pin CN401 1pin R410 U401 CN401 JP400 JP402 JP403 JP401 2pin 3pin CN401 Pin assignment 2016/03/29 Proprietary Pin Case Silk RS485 mode UART Mode 1 G GND GND 2 - TxD-/RxD- RXD (input) 3 + TxD+/RxD+ TXD (output) MegaChips Corporation 9 Tx Power Setting(1/2) This unit has two power control tables as below. Refer to next page about how to change the tables. 【Table index 0】(Default) 2016/03/29 Proprietary 【Table index 1】 MegaChips Corporation 10 Tx Power Setting(2/2) How to change the table index by “HD-PLC ToolManager” (1)Start the “HD-PLC Tool Manager” *Refer to “PTT-D0013E_ToolManager [Power Control] Manual (NDA Required).pdf” for the detailed usage. (2)Click “Option” button. (3)Select the table index, and Click “OK” button. ・index 0* : for Japan (*:Default Setting) ・index 1 : Full power setting ・index 2-7 : N/A ・index 8,9 : Reserved (4)Input password “1234567890”, and click “OK” button. >The following message is displayed. (5)If you want to restart, click “OK” button. >Then restart will be started. 2016/03/29 Proprietary MegaChips Corporation 11 AC/DC adapter Maker : CUI ModelNo : SMI6-12-V-P5 INPUT : 100-240V(47Hz-63Hz) OUTPUT : DC12V/0.5A 2016/03/29 Proprietary MegaChips Corporation 12 BCP-COAX_CONV Board (Coupler) 2016/03/29 Proprietary MegaChips Corporation 13 Connection Diagram (Ether Bridge Test with DC power line) (1)Connect Ethernet Devices (2)Start Test IP Camera AC/DC Adapter DC12V Master unit Ethernet AC/DC Adapter DC12V Ethernet Terminal unit Twist pair cable Communication & DC power line 2016/03/29 Proprietary MegaChips Corporation 14 Connection Diagram (Ether Bridge Test with Coax.) (1)Connect Ethernet Devices (2)Start Test IP Camera AC/DC Adapter AC/DC Adapter DC12V Ethernet Master unit BCP-COAX_CONV (Coupler) DC12V Ethernet Terminal unit BCP-COAX_CONV (Coupler) Coaxial Cable Communication line (including DC power line) 2016/03/29 Proprietary MegaChips Corporation 15 Connection Diagram (Ether Bridge Test with AC power line) (1)Connect Ethernet Devices (2)Start Test IP Camera Ethernet Ethernet Terminal unit* Master unit * AC Cable (VCTF, VVF, etc.) Communication & AC power line(AC100V-AC240V) * Change Power Input Source Setting (See P.7) 2016/03/29 Proprietary MegaChips Corporation 16 Connection Diagram (RS485 Bridge Test) (1)Connect RS485 Devices (2)Set RS485 parameters(Baud Rate, Address, etc.) by BCPNM (Default : Baud rate:115200bps, Data:8bit, Parity:None, Stop:1bit) (3)Start Test RS485 RS485 Slave Master AC/DC Adapter DC12V + - GND + - GND RS485 RS485 + - GND + - GND Master unit * Communication line, Power line (DC,AC100-AC240V) 2016/03/29 Proprietary Terminal unit* * : Change jumper-pin Setting depending on the cable. (See P.7-8). MegaChips Corporation 17 Connection Diagram (Multi-hop Test) (1)Connect devices such as below (2)Start Test Device1 Device2 Device3 PC Ethernet Communication line, Power line (DC,AC100-AC240V) Master unit * Ethernet or Serial Ethernet or Serial Ethernet or Serial (UART/RS485) (UART/RS485) (UART/RS485) Terminal unit 1 * Terminal unit 2 * Terminal unit 3 * ATT, Filter, Long distance, etc. * : Change jumper-pin Setting depending on the cable and serial interface.(See P.7-8). 2016/03/29 Proprietary MegaChips Corporation
BCP-MH-E01 价格&库存
很抱歉,暂时无法提供与“BCP-MH-E01”相匹配的价格&库存,您可以联系我们找货
