MXC4xx5-B Prototyping Board
MXC4xx5-B
re
vi
ew
GENERAL DESCRIPTION
The MXC4xx5-B provides a convenient and easy way to
evaluate and prototype with MXC4xx5 the three axes
accelerometer. The accelerometer and passive components
are SMT mounted on the board. Each pin of the MXC4xx5
SMT device is brought out to standard 0.10 inch on center
connections on the sides of the prototyping board. Wires
can either be soldered directly to the prototyping board or
the DIP pins can be used with widely available breadboard
kits.
al
For complete performance specifications of MXC4xx5 refer
to MXC4xx5 datasheet.
Name
VDDIO
VDD3V
GND
SDA
SCL
INT
Description
I2C Supply Voltage
Power
Ground
I2C SDA
I2C SCL
Interrupt Output
PCB CONNECTION DIMENSIONS
MS
I
C
in
SCHEMATIC OF THE MXC4xx5-B
MXC4xx5-B
te
Pin
P1-1
P1-2
P1-3
P2-1
P2-2
P2-3
rn
PIN DESCRIPTION
MXC4xx5-B
ME
MXC4xx5-B
Information furnished by MEMSIC is believed to be accurate and reliable.
However, no responsibility is assumed by MEMSIC for its use, nor for any
infringements of patents or other rights of third parties, which may result from
its use. No license is granted by implication or otherwise under any patent or
patent rights of MEMSIC.
MEMSIC MXC4xx5-B Prototyping Board User's Guide
MEMSIC Semiconductor (Wuxi) Co., Ltd.
No.2 Xinhuihuan Road, Xinwu District, Wuxi, Jiangsu, China
Tel: +86-510-66616668
Fax: +86-510-66616669
www.memsic.com
Page 1of 1
Rev A
很抱歉,暂时无法提供与“MXC4005XC-B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+184.538831+23.90424
