MXC6655XA-B
MXC6655XA-B
    MEMSIC(美新)
    MXC6655 - 加速计,3 轴 评估板 - 传感器
MXC6655XA-B 数据手册
MXC6655-B User Guide MXC6655-B GENERAL DESCRIPTION The MXC6655-B provides a convenient and easy way to evaluate and prototype with MXC6655 the three axes accelerometer. The accelerometer and passive components are SMT mounted on the board. Each pin of the MXC6655 SMT device is brought out to standard 0.10 inch on center connections on the sides of the prototyping board. Wires can either be soldered directly to the prototyping board or the DIP pins can be used with widely available breadboard kits. For complete performance specifications of MXC6655 refer to MXC6655 datasheet. PIN DESCRIPTION Pin P1-1 P1-2 P1-3 P2-1 P2-2 P2-3 Name VDDIO VDD3V GND SDA SCL INT Description I2C Supply Voltage Power Ground I2C SDA I2C SCL Interrupt Output MXC6655-B PCB OUTLINE AND CONNECTION DIMENSIONS SCHEMATIC OF THE MXC6655-B MXC6655-B MXC6655-B Information furnished by MEMSIC is believed to be accurate and reliable. However, no responsibility is assumed by MEMSIC for its use, nor for any infringements of patents or other rights of third parties, which may result from its use. No license is granted by implication or otherwise under any patent or patent rights of MEMSIC. MXC6655-B User Guide Rev A MEMSIC Semiconductor (Wuxi) Co., Ltd. No.2 Xinhuihuan Road, Xinwu District, Wuxi, Jiangsu, China Tel: +86-510-66616668 Fax: +86-510-66616669 www.memsic.com Page 1of 1 Formal released date: 5/7/2019
MXC6655XA-B 价格&库存
很抱歉,暂时无法提供与“MXC6655XA-B”相匹配的价格&库存,您可以联系我们找货
