MXR2312ML
MXR2312ML
    MEMSIC(美新)
    8-LCC
    加速计 X,Y 轴 ±2g 17Hz 8-LCC(5x5)
MXR2312ML 数据手册
Improved, Ultra Low Noise ±2 g Dual Axis Accelerometer with Ratiometric Outputs MXR2312G/M FEATURES Resolution better than 1 mg Dual axis accelerometer fabricated on a monolithic CMOS IC RoHS compliant On chip mixed mode signal processing No moving parts 50,000 g shock survival rating 17 Hz bandwidth expandable to >160 Hz 3.0V to 5.25V single supply continuous operation Continuous self test Independent axis programmability (special order) Ultra low initial Zero-g Offset Sck (optional) Internal Oscillator CLK GENERAL DESCRIPTION The MXR2312G/M is a low cost, dual axis accelerometer fabricated on a standard, submicron CMOS process. It is a complete sensing system with on-chip mixed mode signal processing. The MXR2312G/M measures acceleration with a full-scale range of ±2 g and a sensitivity of 312mV/g @5V at 25°C. It can measure both dynamic acceleration (e.g. vibration) and static acceleration (e.g. gravity). The MXR2312G/M design is based on heat convection and requires no solid proof mass. This eliminates stiction and particle problems associated with competitive devices and provides shock survival of 50,000 g, leading to significantly lower failure rate and lower loss due to handling during assembly. Information furnished by MEMSIC is believed to be accurate and reliable. However, no responsibility is assumed by MEMSIC for its use, nor for any infringements of patents or other rights of third parties which may result from its use. No license is granted by implication or otherwise under any patent or patent rights of MEMSIC. MEMSIC MXR2312G/M Rev.G Page 1 of 6 TOUT Voltage Reference VREF Continous Self Test Heater Control X axis Low Pass Filter AOUTX Low Pass Filter AOUTY Factory Adjust Offset & Gain APPLICATIONS Automotive – Vehicle Security/Vehicle Stability control/ Headlight Angle Control/Tilt Sensing Security – Gas Line/Elevator/Fatigue Sensing/Computer Security Information Appliances – Computer Peripherals/PDA’s/Cell Phones Gaming – Joystick/RF Interface/Menu Selection/Tilt Sensing GPS – Electronic compass tilt correction Consumer – LCD projectors, pedometers, blood pressure monitor, digital cameras Temperature Sensor Y axis 2-AXIS SENSOR VDD Gnd VDA MXR2312G/M FUNCTIONAL BLOCK DIAGRAM The MXR2312G/M provides two ratiometric analog outputs proportional to 50% of the supply voltage at zero g acceleration. The typical noise floor is 0.2 mg/ Hz allowing signals below 1 mg to be resolved at 1 Hz bandwidth. The 3dB rolloff of the device occurs at 17 Hz but is expandable to >160 Hz (reference Application Note AN-00MX-003). The MXR2312G/M is packaged in a hermetically sealed LCC surface mount package (5 mm x 5 mm x 2 mm height) and is operational over a -40°C to 105°C(ML) and 0°C to 70°C(GL) temperature range. ©MEMSIC, Inc. One Technology Drive Suite 325,Andover MA01810,USA Tel: +1 978 738 0900 Fax: +1 978 738 0196 www.memsic.com 2/26/2007 MXR2312G/M SPECIFICATIONS (Measurements @ 25°C, Acceleration = 0 g unless otherwise noted; VDD, VDA = 5.0V unless otherwise specified) Parameter SENSOR INPUT Measurement Range1 Nonlinearity Alignment Error2 Transverse Sensitivity3 SENSITIVITY Sensitivity, Analog Outputs at pins AOUTX and AOUTY5 Change over Temperature ZERO g BIAS LEVEL 0 g Offset5 0 g Voltage5 0 g Offset over Temperature Conditions Each Axis Min MXR2312G Typ ±2.0 Best fit straight line X Sensor to Y Sensor MXR2312M Typ Max Units ±2.0 1.0 312 328 296 +8 -25 0.0 2.50 ±1.5 ±0.47 +0.1 2.53 -0.1 2.47 0.2 0.4 15 17 >160 19 1.15 4.6 1.25 5.0 2.4 2.5 0.1 g 0.5 ±1.0 ±2.0 1.0 % of FS degrees % 312 328 mV/g +8 % 0.0 2.50 ±1.5 ±0.47 +0.1 2.53 g V mg/°C mV/°C 0.2 0.4 15 17 >160 19 Hz Hz 1.35 5.4 1.15 4.6 1.25 5.0 1.35 5.4 V mV/°K 2.65 2.4 2.5 0.1 2.65 V mV/°C μA Each Axis 296 -10 Each Axis -0.1 2.47 Without frequency compensation FREQUENCY RESPONSE 3dB Bandwidth - uncompensated 3dB Bandwidth – compensated4 TEMPERATURE OUTPUT Tout Voltage Sensitivity VOLTAGE REFERENCE OUTPUT VRef output @3.0V-5.25V supply Change over Temperature Current Drive Capability Source SELF TEST Continuous Voltage at AOUTX, @5.0V Supply, output AOUTY under Failure rails to supply voltage Continuous Voltage at AOUTX, @3.0V Supply, output AOUTY under Failure rails to supply voltage AOUTX and AOUTY OUTPUTS Normal Output Range @5.0V Supply Current Source or sink, @ 3.0V-5.25V supply Turn-On Time @5.0V Supply @3.0V Supply POWER SUPPLY Operating Voltage Range Supply Current @ 5.0V Supply Current @ 3.0V TEMPERATURE RANGE Operating Range NOTES 100 100 0 Guaranteed by measurement of initial offset and sensitivity. Alignment error is specified as the angle between the true and indicated axis of sensitivity. 3 Transverse sensitivity is the algebraic sum of the alignment and the inherent sensitivity errors. 4 External circuitry is required to extend the 3dB bandwidth (ref. Application Note: AN-00MX-003) Page 2 of 6 Hz 5.0 V 3.0 3.0 V 4.0 100 1.0 160 300 3.0 2.7 3.2 mg/ 5.0 1.0 2 MEMSIC MXR2312G/M Rev.G Min 0.5 ±1.0 ±2.0 Based on 312 mV/g NOISE PERFORMANCE Noise Density, rms 1 Max 3.3 4.0 4.0 100 160 300 5.25 4.1 4.8 3.0 2.7 3.2 +70 -40 3.3 4.0 V μA mS mS 5.25 4.1 4.8 V mA mA +105 °C 5 The device operates over a 3.0V to 5.25V supply range. Please note that sensitivity and zero g bias level will be slightly different at 3.0V operation. For devices to be operated at 3.0V in production, they can be trimmed at the factory specifically for this lower supply voltage operation, in which case the sensitivity and zero g bias level specifications on this page will be met. Please contact the factory for specially trimmed devices for low supply voltage operation. 2/26/2007 ABSOLUTE MAXIMUM RATINGS* Supply Voltage (VDD, VDA) ………………...-0.5 to +7.0V Storage Temperature ……….…………-65°C to +150°C Acceleration ……………………………………..50,000 g *Stresses above those listed under Absolute Maximum Ratings may cause permanent damage to the device. This is a stress rating only; the functional operation of the device at these or any other conditions above those indicated in the operational sections of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Package Characteristics Package θJA LCC-8 110°C/W Pin Description: Pin Name 1 TOUT 2 AOUTY 3 Gnd 4 VDA 5 AOUTX 6 Vref 7 Sck 8 VDD θJC 22°C/W Device Weight < 1 gram LCC-8 Package Description Temperature (Analog Voltage) Y-Axis Acceleration Signal Ground Analog Supply Voltage X-Axis Acceleration Signal 2.5V Reference Output Optional External Clock Digital Supply Voltage Ordering Guide Model Package Style MXR2312GL MXR2312GF MXR2312ML MXR2312MF LCC8, RoHS compliant LCC8, Pb-free RoHS compliant LCC8, RoHS compliant LCC8, Pb-free RoHS compliant I/O O O I I O O I I Temperature Range 0 to 70°C 0 to 70°C -40 to 105°C -40 to 105°C All parts are shipped in tape and reel packaging. Caution: ESD (electrostatic discharge) sensitive device. 8 7 M E M S IC 1 2 3 X +g 6 THEORY OF OPERATION The MEMSIC device is a complete dual-axis acceleration measurement system fabricated on a monolithic CMOS IC process. The device operation is based on heat transfer by natural convection and operates like other accelerometers having a proof mass except it is a gas in the MEMSIC sensor. A single heat source, centered in the silicon chip is suspended across a cavity. Equally spaced aluminum/polysilicon thermopiles (groups of thermocouples) are located equidistantly on all four sides of the heat source (dual axis). Under zero acceleration, a temperature gradient is symmetrical about the heat source, so that the temperature is the same at all four thermopiles, causing them to output the same voltage. Acceleration in any direction will disturb the temperature profile, due to free convection heat transfer, causing it to be asymmetrical. The temperature, and hence voltage output of the four thermopiles will then be different. The differential voltage at the thermopile outputs is directly proportional to the acceleration. There are two identical acceleration signal paths on the accelerometer, one to measure acceleration in the x-axis and one to measure acceleration in the y-axis. Please visit the MEMSIC website at www.memsic.com for a picture/graphic description of the free convection heat transfer principle. 5 4 Y +g Top View Note: The MEMSIC logo’s arrow indicates the +X sensing direction of the device. The +Y sensing direction is rotated 90° away from the +X direction following the right-hand rule. Small circle indicates pin one (1). MEMSIC MXR2312G/M Rev.G Page 3 of 6 2/26/2007 MXR2312G/M PIN DESCRIPTIONS VDD – This is the supply input for the digital circuits and the sensor heater in the accelerometer. The DC voltage should be between 3.0 and 5.25 volts. Refer to the section on PCB layout and fabrication suggestions for guidance on external parts and connections recommended. A MEMSIC accelerometer is most sensitive to changes in position, or tilt, when the accelerometer’s sensitive axis is perpendicular to the force of gravity, or parallel to the Earth’s surface. Similarly, when the accelerometer’s axis is parallel to the force of gravity (perpendicular to the Earth’s surface), it is least sensitive to changes in tilt. VDA – This is the power supply input for the analog amplifiers in the accelerometer. Refer to the section on PCB layout and fabrication suggestions for guidance on external parts and connections recommended. Table 1 and Figure 2 help illustrate the output changes in the X- and Y-axes as the unit is tilted from +90° to 0°. Notice that when one axis has a small change in output per degree of tilt (in mg), the second axis has a large change in output per degree of tilt. The complementary nature of these two signals permits low cost accurate tilt sensing to be achieved with the MEMSIC device (reference application note AN-00MX-007). Gnd – This is the ground pin for the accelerometer. AOUTX – This pin is the output of the x-axis acceleration sensor. The user should ensure the load impedance is sufficiently high as to not source/sink >100μA. While the sensitivity of this axis has been programmed at the factory to be the same as the sensitivity for the y-axis, the accelerometer can be programmed for non-equal sensitivities on the x- and y-axes. Contact the factory for additional information on this feature. X M E M SIC +900 gravity 00 Y AOUTY – This pin is the output of the y-axis acceleration Top View sensor. The user should ensure the load impedance is sufficiently high as to not source/sink >100μA. While the sensitivity of this axis has been programmed at the factory to be the same as the sensitivity for the x-axis, the accelerometer can be programmed for non-equal sensitivities on the x- and y-axes. Contact the factory for additional information on this feature. TOUT – This pin is the buffered output of the temperature sensor. The analog voltage at TOUT is an indication of the die temperature. This voltage is useful as a differential measurement of temperature from ambient and not as an absolute measurement of temperature Figure 2: Accelerometer Position Relative to Gravity X-Axis X-Axis Orientation To Earth’s Surface (deg.) Sck – The standard product is delivered with an internal clock option (800kHz). This pin should be grounded when operating with the internal clock. An external clock option can be special ordered from the factory allowing the user to input a clock signal between 400kHz and 1.6MHz. Vref – This pin is the output of a reference voltage. It is set at 2.50V typical and has 100μA of drive capability. DISCUSSION OF TILT APPLICATIONS AND RESOLUTION Tilt Applications: One of the most popular applications of the MEMSIC accelerometer product line is in tilt/inclination measurement. An accelerometer uses the force of gravity as an input to determine the inclination angle of an object. 90 85 80 70 60 45 30 20 10 5 0 X Output (g) Change per deg. of tilt (mg) Y-Axis Change per deg. of tilt (mg) Y Output (g) 1.000 0.15 0.000 0.996 1.37 0.087 0.985 2.88 0.174 0.940 5.86 0.342 0.866 8.59 0.500 0.707 12.23 0.707 0.500 15.04 0.866 0.342 16.35 0.940 0.174 17.16 0.985 0.087 17.37 0.996 0.000 17.45 1.000 Table 1: Changes in Tilt for X- and Y-Axes 17.45 17.37 17.16 16.35 15.04 12.23 8.59 5.86 2.88 1.37 0.15 Resolution: The accelerometer resolution is limited by noise. The output noise will vary with the measurement bandwidth. With the reduction of the bandwidth, by applying an external low pass filter, the output noise drops. Reduction of bandwidth will improve the signal to noise ratio and the resolution. The output noise scales directly with the square root of the measurement bandwidth. The maximum amplitude of the noise, its peak- to- peak value, approximately defines the worst case resolution of the measurement. With a simple RC low pass filter, the rms noise is calculated as follows: Noise (mg rms) = Noise(mg/ Hz ) * ( Bandwidth( Hz) *1.6) MEMSIC MXR2312G/M Rev.G Page 4 of 6 2/26/2007 EXTERNAL FILTERS AC Coupling: For applications where only dynamic accelerations (vibration) are to be measured, it is recommended to ac couple the accelerometer output as shown in Figure 3. The advantage of ac coupling is that variations from part to part of zero g offset and zero g offset versus temperature can be eliminated. Figure 3 is a HPF (high pass filter) with a –3dB breakpoint given by the equation: f = 1 . In many applications it may be 2πRC desirable to have the HPF –3dB point at a very low frequency in order to detect very low frequency accelerations. Sometimes the implementation of this HPF may result in unreasonably large capacitors, and the designer must turn to digital implementations of HPFs where very low frequency –3dB breakpoints can be achieved. AOUTX R AOUTX The peak-to-peak noise is approximately equal to 6.6 times the rms value (for an average uncertainty of 0.1%). C AOUTY Filtered Output R AOUTY Figure 4: Low Pass Filter POWER SUPPLY NOISE REJECTION Two capacitors and a resistor are recommended for best rejection of power supply noise (reference Figure 5 below). The capacitors should be located as close as possible to the device supply pins (VDA, VDD). The capacitor lead length should be as short as possible, and surface mount capacitors are preferred. For typical applications, capacitors C1 and C2 can be ceramic 0.1 μF, and the resistor R can be 10 Ω. V SUPPLY C R AOUTX Filtered Output C1 AOUTY C AOUTX Filtered Output C R AOUTY Filtered Output R VDA C2 VDD MEMSIC Accelerometer Figure 5: Power Supply Noise Rejection Figure 3: High Pass Filter Low Pass Filter: An external low pass filter is useful in low frequency applications such as tilt or inclination. The low pass filter limits the noise floor and improves the resolution of the accelerometer. When designing with MEMSIC ratiometric output accelerometers (MXRxxxx series), it is highly recommended that an external, 20 Hz low pass filter be used to eliminate internally generated periodic noise that is coupled to the output of the accelerometer. The low pass filter shown in Figure 4 has a . For –3dB breakpoint given by the equation: f = 1 2πRC the 200 Hz ratiometric output device filter, C=0.2μF and R=39kΩ, ±5%, 1/8W. MEMSIC MXR2312G/M Rev.G Page 5 of 6 PCB LAYOUT AND FABRICATION SUGGESTIONS 1. The Sck pin should be grounded to minimize noise. 2. Liberal use of ceramic bypass capacitors is recommended. 3. Robust low inductance ground wiring should be used. 4. Care should be taken to ensure there is “thermal symmetry” on the PCB immediately surrounding the MEMSIC device and that there is no significant heat source nearby. 5. A metal ground plane should be added directly beneath the MEMSIC device. The size of the plane should be similar to the MEMSIC device’s footprint and be as thick as possible. 6. Vias can be added symmetrically around the ground plane. Vias increase thermal isolation of the device from the rest of the PCB. 2/26/2007 PACKAGE DRAWING Figure 8: Hermetically Sealed Package Outline MEMSIC MXR2312G/M Rev.G Page 6 of 6 2/26/2007
MXR2312ML 价格&库存
很抱歉,暂时无法提供与“MXR2312ML”相匹配的价格&库存,您可以联系我们找货
MXR2312ML
  • 1+158.583361+20.58123
  • 5+144.505295+18.75415
  • 10+139.2635710+18.07387
  • 25+132.9892725+17.25958
  • 50+128.6985250+16.70272
  • 100+124.76393100+16.19208
  • 500+116.83469500+15.16301
库存:1591
