CM422SG471N
CM422SG471N
    MNC(铭普光磁)
    SMD,7.5x6.4mm
    CMC 470UH 900MA 2LN SMD
CM422SG471N 数据手册
东莞铭普光磁股份有限公司 Dongguan Mentech Optical & Magnetic Co., Ltd. Product Specification for Approval WE ARE PLEASED IN SUBMITTING OUR SAMPLES WITH SPECIFICATION TO YOU FOR APPROVAL. CUSTOMER : DESCRIPTION : COMMON MODE CHOKE MNC P/N : CM422SG471N VERSION : A0 CUSTOMER P/N : ISSUED DATE : PHOTO OF PRODUCT : WEIGHT : MADE IN : 2020/4/26 : CHINA APPROVED BY MNC PREPARED BY CHECKED BY APPROVED BY APPROVED BY CUSTOMER SIGNATURE OR STAMP 1. PLEASE SEND BACK US A COPY OF THE SPECIFICATION WITH YOUR STAMP OR SIGNATURE ONCE THE SAMPLES APPROVED. 2. IT WILL BE DEEMED THE SAMPLES TO BE APPROVED IF NO FEEDBACK. 东莞铭普光磁股份有限公司 TEL: +86-769-86921000 Add:Shipai Town, Dongguan City,Guangdong Province,China FAX: +86-769-81701563 ----------------------------------------------------------------------------------------www.mnc-tek.com FORM-MT-0135REV.04 东莞铭普光磁股份有限公司 Dongguan Mentech Optical & Magnetic Co., Ltd. HISTORY FOR REVISED SPECIFICATION Part No. CM422SG471N INDEX 1. INDEX--------------------------------------------------------------------------------------------------------------------------1 2. CHANGE RECORD------------------------------------------------------------------------------------------------------1 3. MECHANICAL-----------------------------------------------------------------------------------------------------2 4. SCHEMATIC-------------------------------------------------------------------------------------------------------------------------------------3 5. PACKING--------------------------------------------------------------------------------------------------------------------------------------4 6. MATERIAL LIST-------------------------------------------------------------------------------------------------------5 7. RECOMMENDED SOLDERING PROFILE-------------------------------------------------------------------------6 CHANGE RECORD REV. A0 DESCRIPTION (Content or Reason For Change) INITIAL RELEASE DATE REVISOR 2020/4/26 Alakay ----------------------------------------------------------------------------------------www.mnc-tek.com 1/6 FORM-MT-0135REV.04 东莞铭普光磁股份有限公司 Dongguan Mentech Optical & Magnetic Co., Ltd. SPECIFICATION Part No. CM422SG471N A. MECHANICAL: 1 3 471 2 4 3 2 4 1 SUGGESTED PAD LAYOUT 1.UNITS: mm 2.Unless otherwise specifed all tolerances are: ±0.25mm 3.All pin length don't include tin icicles MILLIMETERS DIM A B1 B2 C E1 G1 E2 F G2 G3 INCHES MIN NOM MAX MIN NOM MAX / / 6.40 / / 0.252 / / 9.50 / / 0.374 / / 7.50 / / 0.295 / / 5.00 / / 0.197 2.24 2.54 2.84 0.088 0.100 0.112 / 0.40 / / 0.016 / / 2.54 / / 0.100 / / 7.50 / / 0.295 / / 2.72 / / 0.107 / / 1.20 / / 0.047 / ----------------------------------------------------------------------------------------www.mnc-tek.com 2/6 FORM-MT-0135REV.04 东莞铭普光磁股份有限公司 Dongguan Mentech Optical & Magnetic Co., Ltd. SPECIFICATION Part No. CM422SG471N B. SCHEMATIC : C. ELECTRICAL SPECIFICATION @25℃ ITEM SPECIFICATION TEST CONDITION TEST EQUIPMENT INDUCTANCE: 1-4 = 2-3 470uH +50%/-30% DC RESISTANCE: 1-4 = 2-3 200mΩ Max TH2512B OR EQU. TURNS RATIO: 1-4 : 2-3 1:1 ±5% TH2819XB OR EQU. HI-POT: 1-4 to 2-3 500Vac 1mA,1S,50Hz TOS7200 OR EQU. RATED CURRENT △T≤40℃ 0.9A Max WK3260B+WK3265B OPERATING TEMPERATURE RANGE -40℃ to 125℃(Including self temperature rise) STORAGE TEMPERATURE RANGE -40℃ to 125℃ 100KHz,0.1V TH2819XB OR EQU. ----------------------------------------------------------------------------------------www.mnc-tek.com 3/6 FORM-MT-0135REV.04 东莞铭普光磁股份有限公司 Dongguan Mentech Optical & Magnetic Co., Ltd. PACKAGE Part No. CM422SG471N 1. PACKING: a. PACKAGING AS BELOW (ONLY FOR REFERENCE): W F E P0 P2 471 471 ITEM DIM. D0 P 16.0±0.3 7.5±0.1 1.75±0.1 4.0±0.1 2.0±0.1 1.5±0.1 12.0±0.1 330 13 Carrier tape Cover tape Put the reel into the carton one reel b. Q'TY: c. LABEL: 1000 pcs/reel 8 reel/carton 8000 pcs/carton REMARK: ABOVE PACKING IS FOR YOUR REFERENCE ONLY, WHICH MIGHT BE CHANGED WITHOUT NOTICE. ----------------------------------------------------------------------------------------www.mnc-tek.com 4/6 FORM-MT-0135REV.04 东莞铭普光磁股份有限公司 Dongguan Mentech Optical & Magnetic Co., Ltd. MATERIAL LIST Part No. CM422SG471N BOM MATERIAL LIST NO. ITEM MATERIAL RATING 1 CASE PM 9630 150℃ SUMITOMO BAKELITE CO LTD OR EQU. Ferrite Mn-Zn ------ YEAN SHING TECHNOLOGY (DONGGUAN) LIMITED N/A Ferrite Mn-Zn ------ ZHONGSHAN CITY TANZHOU TOWN CHUANGRICI ELECTRONIC FACTORY OR EQU. N/A *xUEW180 180℃ ZHUHAI SUNTEK WIRE CO LTD OR QUU. E234867 UEWH/U@ 180℃ PACIFIC ELECTRIC WIRE & CABLE CO., LTD. OR QUU. E201757 V1630FS 150℃ ELANTAS ELECTRICAL INSULATION ELANTAS PDG INC OR EQU. E213437 ------ ELECTROLOY METAL(SHENZHEN)CO.,LTD. OR EQU. 2 3 4 CORE COPPER WIRE VARNISH HN72512VG 5 SOLDER Sn99.3Cu0.7 LF-303 SUPPLIER OF MATERIAL UL E41429 N/A ----------------------------------------------------------------------------------------www.mnc-tek.com 5/6 FORM-MT-0135REV.04 东莞铭普光磁股份有限公司 Dongguan Mentech Optical & Magnetic Co., Ltd. RECOMMENDED SOLDERING PROFILE Part No. CM422SG471N 1. RECOMMENDED REFLOW SOLDERING PROFILE: TL = 217℃ HN72512VG Tp = 260℃ ts=60-120s Ts max=200℃ Ts min=150℃ tl=60-150s tp=20-40s T25℃ to peak=8min max Ramp up rate=3℃/s max Ramp down rate=6℃/s max *RoHS Compliant HN72512VG *Solder Paste SAC 305 Sn 96.5/Ag 3.0/Cu 0.5 *Silkscreen thickness: 0.15mm Min 2. MOISTURE SENSITIVE LEVEL: 2.1. Level: 1 2.2. Shelf Life: Unlimited 2.3. Storage Condition: ≦30℃/85% RH ----------------------------------------------------------------------------------------www.mnc-tek.com 6/6 FORM-MT-0135REV.04
CM422SG471N 价格&库存
很抱歉,暂时无法提供与“CM422SG471N”相匹配的价格&库存,您可以联系我们找货
