G2462CE
G2462CE
    MNC(铭普光磁)
    SMD-24P,18x12.7mm
    SINGLE LAN XFMR 1000 BASE-T
G2462CE 数据手册
东莞铭普光磁股份有限公司 Dongguan Mentech Optical & Magnetic Co., Ltd. Product Specification for Approval WE ARE PLEASED IN SUBMITTING OUR SAMPLES WITH SPECIFICATION TO YOU FOR APPROVAL. CUSTOMER : DESCRIPTION : 100/1000BASE-T TRANSFORMER (POE+) MNC P/N : G2462CE VERSION : A0 CUSTOMER P/N : ISSUED DATE : PHOTO OF PRODUCT : WEIGHT : 2.22g MADE IN : CHINA 2020/04/27 APPROVED BY MNC PREPARED BY CHECKED BY APPROVED BY 研发部 研发部 研发部 2020-04-27 2020-04-27 2020-04-27 符晶晶 肖明华 何校民 APPROVED BY CUSTOMER SIGNATURE OR STAMP 1. PLEASE SEND BACK US A COPY OF THE SPECIFICATION WITH YOUR STAMP OR SIGNATURE ONCE THE SAMPLES APPROVED. 2. IT WILL BE DEEMED THE SAMPLES TO BE APPROVED IF NO FEEDBACK. 东莞铭普光磁股份有限公司 TEL: +86-769-86921000 Add:Shipai Town, Dongguan City,Guangdong Province,China FAX: +86-769-81701563 ----------------------------------------------------------------------FORM-MT-0135REV.04 www.mnc-tek.com 东莞铭普光磁股份有限公司 Dongguan Mentech Optical & Magnetic Co., Ltd. HISTORY FOR REVISED SPECIFICATION Part No. G2462CE INDEX 1. INDEX----------------------------------------------------------------------------------------------------------1 2. CHANGE RECORD------------------------------------------------------------------------------------------1 3. MECHANICAL----------------------------------------------------------------------------------------------- 2 4. SCHEMATIC--------------------------------------------------------------------------------------------------3 5. PACKING------------------------------------------------------------------------------------------------------4 6. MATERIAL LIST---------------------------------------------------------------------------------------------5 7. RECOMMENDED SOLDERING PROFILE-------------------------------------------------------------6 CHANGE RECORD REV. A0 DESCRIPTION (Content or Reason For Change) INITIAL RELEASE DATE REVISOR 2020-04-27 Jingjing Fu ----------------------------------------------------------------------FORM-MT-0135REV.04 www.mnc-tek.com 1/6 东莞铭普光磁股份有限公司 Dongguan Mentech Optical & Magnetic Co., Ltd. SPECIFICATION Part No. G2462CE A. MECHANICAL : A X Y B H G2462CE Z YYWWX F G SUGGESTED PAD LAYOUT C D 0.10 24 SURFACES E I J 1.UNITS:mm/inch. 2.UNLESS OTHERWISE SPECIFIED ALL TOLERANCES ARE: TYPICAL 3.PIN LENGTH DON'T INCLUDE SOLDER POINT Note:Laser printing marking YY WW X Production line code (A to Z) Week Year INCHES MILLIMETERS DIM MIN NOM MAX MIN NOM MAX A 17.63 18.13 18.63 0.694 0.714 0.733 B 11.70 12.20 12.70 0.461 0.480 0.500 C / / 6.80 / / 0.268 D 13.47 13.97 14.47 0.530 0.550 0.570 E 0.15 0.30 0.45 0.006 0.012 0.018 F 1.17 1.27 1.37 0.046 0.050 0.054 G 0.36 0.46 0.56 0.014 0.018 0.022 H 15.50 16.00 16.50 0.610 0.630 0.650 I / 1.25 / / 0.049 / J 0° / 8° 0° / 8° X / 0.76 / / 0.030 / Y / 2.29 / / 0.090 / Z / 17.20 / / 0.677 / ----------------------------------------------------------------------FORM-MT-0135REV.04 www.mnc-tek.com 2/6 东莞铭普光磁股份有限公司 Dongguan Mentech Optical & Magnetic Co., Ltd. SPECIFICATION Part No. G2462CE B. SCHEMATIC : 15 10 12 11 1CT:1CT 13 16 9 14 17 18 1CT:1CT 7 6 5 8 19 21 4 20 22 3 1CT:1CT 23 2 1 1CT:1CT 24 CABLE SIDE CHIP SIDE C. ELECTRICAL SPECIFICATION @25℃ ITEM SPECIFICATION TEST CONDITION TEST EQUIPMENT 300uH MIN. 100KHz 0.2V 21mA DC Bias (-40℃ & +85℃) TH2819XB OR EQU. 350uH MIN. 100KHz 0.2V 21mA DC Bias (25℃) LEAKAGE INDUCTANCE : 0.50uH MAX. 100KHz 0.2V TH2819XB OR EQU. INTERWINDING CAPACITANCE : 25pF TYP. 100KHz 0.2V TH2819XB OR EQU. DC RESISTANCE : PRI 1.6Ω MAX. DC RESISTANCE : SEC 0.8Ω MAX. AT 25 ℃ TOS 8020 OR EQU. TURNS RATIO : 1CT:1CT±5% POLARITY : 2-23,5-20,8-17,11-14 IN-PHASE INSERTION LOSS : -0.2-0.002* f ^1.4 dB MAX. 1-125 MHz -16dB MIN. 1-40MHz -10+20*log(f/80 MHz)dB MIN. 40-100MHz -50dB MIN. 1MHz -55+22*log(f/10)dB MIN. 10-100MHz -50dB MIN. 2MHz -15+20*log(f/200)dB MIN. 30-200MHz 1500VAC 1mA,60S 1650VAC 1mA,6S INDUCTANCE : RETURN LOSS : CROSS TALK : CMRR : HI-POT: PRI TO SEC OPERATING TEMPERATURE TH2819XB OR EQU. E5061A OR EQU. E5061A OR EQU. E5061A OR EQU. E5061A OR EQU. 7152AB OR EQU. -40℃ TO 85℃ ----------------------------------------------------------------------FORM-MT-0135REV.04 www.mnc-tek.com 3/6 东莞铭普光磁股份有限公司 Dongguan Mentech Optical & Magnetic Co., Ltd. PACKAGE Part No. G2462CE D. PACKING: a. PACKAGING AS BELOW (ONLY FOR A REFERENCE): M部详图 0 3 3 Ф 6 . 0 1 Ф CARRIER TAPE COVER TAPE PUT THE REEL INTO THE CARTON ONE REEL b. Q'TY: c. LABEL: 400 PCS PER REEL 6 REELS PER CARTON 2400 PCS PER CARTON REMARK: ABOVE PACKING IS FOR YOUR REFERENCE ONLY, WHICH MIGHT BE CHANGED WITHOUT NOTICE. ----------------------------------------------------------------------FORM-MT-0135REV.04 www.mnc-tek.com 4/6 东莞铭普光磁股份有限公司 Dongguan Mentech Optical & Magnetic Co., Ltd. MATERIAL LIST Part No. G2462CE E.BOM MATERIAL LIST NO. ITEM RATING SUPPLIER OF MATERIAL UL ------ YEAN SHING N/A ------ ZHONGSHAN CRC ELECTRONICS FACTORY N/A ------ YEAN SHING N/A ------ ZHONGSHAN CRC ELECTRONICS FACTORY N/A QPN180 180℃ ZHUHAI SUNTEK WIRE CO.,LTD E234867 Polysol 180 180℃ ELEKTRISOLA(MALAYSIA) SDN.BHD. E258243 MATERIAL Mn-Zn 1 CORE Ni-Zn 2 COPPER WIRE 3 CASE WH-9100 V-0 WAH HONG INDUSTRIAL CORP E150608 4 PIN C5191 ------ SHENZHEN MINGSCHIN INDUSTRIAL MATERIAL CO.,LTD N/A ----------------------------------------------------------------------FORM-MT-0135REV.04 www.mnc-tek.com 5/6 东莞铭普光磁股份有限公司 Dongguan Mentech Optical & Magnetic Co., Ltd. RECOMMENDED SOLDERING PROFILE Part No. G2462CE a. RECOMMENDED REFLOW SOLDERING PROFILE: below content is only for your reference tp Tp Critical Zone TL to TP Ramp up Temperature TL Tsmax tl Tsmin Ramp-down ts Preheat 25℃ tt25 25℃totopeak peak Time TL= 217℃ Tp = 245℃ ts=60-180s Ts max=200℃ Ts min=150℃ t L=60-150s tp=20-40s Ramp up rate=3℃/s max T25℃ to peak=8min max Ramp down rate=6℃/s max *RoHS Compliant *Solder Paste SAC 305 Sn 96.5/Ag 3.0/Cu 0.5 *Silkscreen thickness: 0.15mm Min b. MOISTURE SENSITIVE LEVEL: b.1. LEVEL: 1 b.2. SHELF LIFE: UNLIMITED b.3. STORAGE CONDITION: ≦30℃/85% RH ----------------------------------------------------------------------FORM-MT-0135REV.04 www.mnc-tek.com 6/6
G2462CE 价格&库存
很抱歉,暂时无法提供与“G2462CE”相匹配的价格&库存,您可以联系我们找货
