G2488CE
G2488CE
    MNC(铭普光磁)
    SMD,15.8x14.2mm
    SINGLE LAN XFMR 1000 BASE-T
G2488CE 数据手册
东莞铭普光磁股份有限公司 Dongguan Mentech Optical & Magnetic Co., Ltd. Product Specification for Approval WE ARE PLEASED IN SUBMITTING OUR SAMPLES WITH SPECIFICATION TO YOU FOR APPROVAL. CUSTOMER : DESCRIPTION : 100/1000 BASE-T TRANSFORMER MNC P/N : G2488CE VERSION : A0 CUSTOMER P/N : ISSUED DATE : PHOTO OF PRODUCT : WEIGHT : 1.60g MADE IN : CHINA 2020/04/27 APPROVED BY MNC PREPARED BY CHECKED BY APPROVED BY 研发部 研发部 研发部 2020-04-27 2020-04-27 2020-04-27 符晶晶 肖明华 何校民 APPROVED BY CUSTOMER SIGNATURE OR STAMP 1. PLEASE SEND BACK US A COPY OF THE SPECIFICATION WITH YOUR STAMP OR SIGNATURE ONCE THE SAMPLES APPROVED. 2. IT WILL BE DEEMED THE SAMPLES TO BE APPROVED IF NO FEEDBACK. 东莞铭普光磁股份有限公司 TEL: +86-769-86921000 Add:Shipai Town, Dongguan City,Guangdong Province,China FAX: +86-769-81701563 ----------------------------------------------------------------------FORM-MT-0135REV.04 www.mnc-tek.com 东莞铭普光磁股份有限公司 Dongguan Mentech Optical & Magnetic Co., Ltd. HISTORY FOR REVISED SPECIFICATION Part No. G2488CE INDEX 1. INDEX-----------------------------------------------------------------------------------------------------------1 2. CHANGE RECORD-------------------------------------------------------------------------------------------1 3. MECHANICAL------------------------------------------------------------------------------------------------ 2 4. SCHEMATIC---------------------------------------------------------------------------------------------------3 5. PACKING-------------------------------------------------------------------------------------------------------4 6. MATERIAL LIST----------------------------------------------------------------------------------------------5 7. RECOMMENDED SOLDERING PROFILE--------------------------------------------------------------6 8. PRODUCT PHOTO------------------------------------------------------------------------------------------- 7 CHANGE RECORD REV. A0 DESCRIPTION (Content or Reason For Change) INITIAL RELEASE DATE REVISOR 2020-04-27 Jingjing Fu ----------------------------------------------------------------------FORM-MT-0135REV.04 www.mnc-tek.com 1/6 东莞铭普光磁股份有限公司 Dongguan Mentech Optical & Magnetic Co., Ltd. SPECIFICATION Part No. G2488CE A. MECHANICAL : A X Y B H G2488CE Z YYWWX G F SUGGESTED PAD LAYOUT C 0.10 24 SURFACES D I E Note:Laser printing marking YY WW X J 1.UNITS:mm/inch. 2.UNLESS OTHERWISE SPECIFIED ALL TOLERANCES ARE: TYPICAL 3.PIN LENGTH DON'T INCLUDE SOLDER POINT Production line code (A to Z) Week Year MILLIMETERS INCHES DIM MIN NOM MAX MIN NOM MAX A 13.20 13.70 14.20 0.520 0.539 0.559 B 14.80 15.30 15.80 0.583 0.602 0.622 C / / 6.70 / / 0.264 D / 10.89 / / 0.429 / E 0.10 0.25 0.40 0.004 0.010 0.016 F / 0.99 / / 0.039 / G / 0.40 / / 0.016 / H 18.10 18.60 19.10 0.713 0.732 0.752 I / 0.90 / / 0.035 / J 0° / 8° 0° / 8° X / 0.76 / / 0.030 / Y / 2.29 / / 0.090 / Z / 19.60 / / 0.772 / ----------------------------------------------------------------------FORM-MT-0135REV.04 www.mnc-tek.com 2/6 东莞铭普光磁股份有限公司 Dongguan Mentech Optical & Magnetic Co., Ltd. SPECIFICATION Part No. G2488CE B. SCHEMATIC : 13 15 10 14 16 9 12 11 1CT:1 17 8 18 1CT:1 6 1CT:1 5 7 21 4 19 22 3 20 23 2 1 1CT:1 24 LINE SIDE PHY SIDE C. ELECTRICAL SPECIFICATION @25℃ ITEM SPECIFICATION TEST CONDITION TEST EQUIPMENT INDUCTANCE : 350uH MIN. 100KHz 0.2V 8mA TH2819XB OR EQU. DC Bias LEAKAGE INDUCTANCE : 0.50uH MAX. 100KHz 0.2V TH2819XB OR EQU. INTERWINDING CAPACITANCE : 25pF TYP. 100KHz 0.2V TH2819XB OR EQU. DC RESISTANCE : 1.2Ω MAX. AT 25 ℃ TOS 8020 OR EQU. TURNS RATIO : 1CT:1CT±5% POLARITY : 2-23,5-20,8-17, 11-14 IN-PHASE INSERTION LOSS : -1.1dB MAX. 0.5-100 MHz -18dB MIN. 0.5-40 MHz RETURN LOSS : CROSS TALK : CMRR : ISOLATION HI-POT :PRI TO SEC OPERATING TEMPERATURE TH2819XB OR EQU. -12+20log(f/80)dB MIN. 40.1-100 MHz -35dB MIN. 0.5-40 MHz -33+20*log(f/50)dB MIN. 40.1-100 MHz -30dB MIN. 0.5-100 MHz 1500VAC 1mA,60S 1650VAC 1mA,6S E5061A OR EQU. E5061A OR EQU. E5061A OR EQU. E5061A OR EQU. 7152AB OR EQU. -40℃ TO 85℃ ----------------------------------------------------------------------FORM-MT-0135REV.04 www.mnc-tek.com 3/6 东莞铭普光磁股份有限公司 Dongguan Mentech Optical & Magnetic Co., Ltd. PACKAGE Part No. G2488CE D. PACKING: a. PACKAGING AS BELOW (ONLY FOR A REFERENCE): 330 10.6 CARRIER TAPE COVER TAPE PUT THE REEL INTO THE ONE REEL b. Q'TY: c. LABEL: 400 PCS PER REEL 6 REELS PER CARTON 2400 PCS PER CARTON REMARK: ABOVE PACKING IS FOR YOUR REFERENCE ONLY, WHICH MIGHT BE CHANGED WITHOUT NOTICE. ----------------------------------------------------------------------FORM-MT-0135REV.04 www.mnc-tek.com 4/6 东莞铭普光磁股份有限公司 Dongguan Mentech Optical & Magnetic Co., Ltd. MATERIAL LIST Part No. G2488CE E.BOM MATERIAL LIST NO. ITEM MATERIAL RATING SUPPLIER OF MATERIAL UL ------ YEAN SHING N/A ------ ZHONGSHAN CRC ELECTRONICS FACTORY N/A ------ YEAN SHING N/A ------ ZHONGSHAN CRC ELECTRONICS FACTORY N/A QPN180 180℃ ZHUHAI SUNTEK WIRE CO.,LTD E234867 Polysol 180 180℃ ELEKTRISOLA(MALAYSIA) SDN.BHD. E258243 Mn-Zn 1 CORE Ni-Zn 2 COPPER WIRE 3 CASE WH-9100 V-0 WAH HONG INDUSTRIAL CORP E150608 4 PIN C5191 ------ SHENZHEN MINGSCHIN INDUSTRIAL MATERIAL CO.,LTD N/A ----------------------------------------------------------------------FORM-MT-0135REV.04 www.mnc-tek.com 5/6 东莞铭普光磁股份有限公司 Dongguan Mentech Optical & Magnetic Co., Ltd. RECOMMENDED SOLDERING PROFILE Part No. G2488CE a. RECOMMENDED REFLOW SOLDERING PROFILE: below content is only for your reference tp Tp Critical Zone TL to TP Ramp up Temperature TL Tsmax tl Tsmin ts Preheal Ramp-down 25℃ t25 to peak t 25℃ to Time TL = 217℃ Tp = 245℃ ts=60-180s Ts max=200℃ Ts min=150℃ tL =60-150s tp=20-40s T25℃ to peak=8min max Ramp up rate=3℃/s max Ramp down rate=6℃/s max *RoHS Compliant *Solder Paste SAC 305 Sn 96.5/Ag 3.0/Cu 0.5 *Silkscreen thickness: 0.15mm Min b. MOISTURE SENSITIVE LEVEL: b.1. LEVEL: 1 b.2. SHELF LIFE: UNLIMITED b.3. STORAGE CONDITION: ≦30℃/85% RH ----------------------------------------------------------------------FORM-MT-0135REV.04 www.mnc-tek.com 6/6
G2488CE 价格&库存
很抱歉,暂时无法提供与“G2488CE”相匹配的价格&库存,您可以联系我们找货
